[PATCH 14/17] score: Thread life cycle re-implementation
Sebastian Huber
Wed Mar 26 16:45:55 UTC 2014
On 03/26/2014 03:56 PM, Gedare Bloom wrote:
> On Tue, Mar 25, 2014 at 8:49 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> >--- a/cpukit/score/include/rtems/score/thread.h
>> >+++ b/cpukit/score/include/rtems/score/thread.h
>> >@@ -11,6 +11,8 @@
>> > * COPYRIGHT (c) 1989-2014.
>> > * On-Line Applications Research Corporation (OAR).
>> >+ * Copyright (c) 2014 embedded brains GmbH.
>> > * The license and distribution terms for this file may be
>> > * found in the file LICENSE in this distribution or at
>> > *http://www.rtems.org/license/LICENSE.
>> >@@ -412,8 +414,47 @@ typedef struct {
>> > Chain_Control Chain;
>> > } Thread_Action_control;
>> >+ * @brief Thread life states.
>> >+ * The thread life states are orthogonal to the thread states used for
>> >+ * synchronization primitives and blocking operations. They reflect the state
>> >+ * changes triggered with thread restart and delete requests.
>> >+typedef enum {
>> >+ THREAD_LIFE_NORMAL = 0x0,
>> >+ THREAD_LIFE_PROTECTED = 0x1,
>> >+ THREAD_LIFE_RESTARTED = 0x2,
>> >+ THREAD_LIFE_PROTECTED_RESTARTED = 0x3,
>> >+ THREAD_LIFE_TERMINATED = 0x4,
>> >+ THREAD_LIFE_PROTECTED_TERMINATED = 0x5,
>> >+ THREAD_LIFE_RESTARTED_TERMINATED = 0x6,
>> >+ THREAD_LIFE_PROTECTED_RESTARTED_TERMINATED = 0x7
>> >+} Thread_Life_state;
> I would prefer the present tense (restarting, terminating) instead of
> the past tense for restarted and terminated. I think it is easier to
> follow then, because the life state flags are set while the
> restart/terminate is happening. Protected is fine.
Ok.
>> >+ * @brief Thread life control.
>> > typedef struct {
>> >+ * @brief Thread life action used to react upon thread restart and delete
>> >+ * requests.
>> > Thread_Action Action;
>> >+ * @brief The current thread life state.
>> >+ Thread_Life_state state;
>> >+ * @brief The terminator thread of this thread.
>> >+ * In case the thread is terminated and another thread (the terminator) waits
>> >+ * for the actual termination completion, then this field references the
>> >+ * terminator thread.
>> >+ Thread_Control *terminator;
>> > } Thread_Life_control;
>> >@@ -486,9 +527,10 @@ struct Thread_Control_struct {
>> > * thread and thread dispatching is necessary. On SMP a thread dispatch on a
>> > * remote processor needs help from an inter-processor interrupt, thus it
>> > * will take some time to complete the state change. A lot of things can
>> >- * happen in the meantime.
>> >+ * happen in the meantime. This field is volatile since it is polled in
>> >+ * _Thread_Kill_zombies().
>> >- bool is_executing;
>> >+ volatile bool is_executing;
>> > #if __RTEMS_HAVE_SYS_CPUSET_H__
>> >diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
>> >index 2e31753..9166e9d 100644
>> >--- a/cpukit/score/include/rtems/score/threadimpl.h
>> >+++ b/cpukit/score/include/rtems/score/threadimpl.h
>> >@@ -11,6 +11,8 @@
>> > * COPYRIGHT (c) 1989-2008.
>> >@@ -194,6 +196,8 @@ bool _Thread_Restart(
>> > Thread_Entry_numeric_type numeric_argument
>> >+bool _Thread_Set_life_protection( bool protect );
>> > void _Thread_Life_action_handler(
>> > Thread_Control *executing,
>> > Thread_Action *action,
>> >@@ -201,17 +205,9 @@ void _Thread_Life_action_handler(
>> > ISR_Level level
>> >- * @brief Frees all memory associated with the specified thread.
>> >- * This routine frees all memory associated with the specified
>> >- * thread and removes it from the local object table so no further
>> >- * operations on this thread are allowed.
>> >-void _Thread_Close(
>> >- Objects_Information *information,
>> >- Thread_Control *the_thread
>> >+void _Thread_Kill_zombies( void );
>> >+void _Thread_Close( Thread_Control *the_thread, Thread_Control *executing );
> Add doxygen for these two functions. Can be done in separate patch.
Ok.
>> > * @brief Removes any set states for @a the_thread.
>> >@@ -710,6 +706,34 @@ RTEMS_INLINE_ROUTINE void _Thread_Add_post_switch_action(
>> > _Thread_Action_release_and_ISR_enable( cpu, level );
>> >+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_restarted(
>> >+ Thread_Life_state life_state
>> >+ return ( life_state & THREAD_LIFE_RESTARTED ) != 0;
>> >+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_terminated(
>> >+ return ( life_state & THREAD_LIFE_TERMINATED ) != 0;
>> >+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_protected(
>> >+ return ( life_state & THREAD_LIFE_PROTECTED ) != 0;
>> >+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_change_requested(
>> >+ return ( life_state & THREAD_LIFE_RESTARTED_TERMINATED ) != 0;
> And also doxygen for these functions, and consider using the present
> tense for restarting, terminating
Why would you document functions like this?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
