[PATCH 16/17] score: Use thread life protection for API mutexes
Wed Mar 26 15:11:33 UTC 2014
Hi Sebastian,
I think your solution here would be cleaner if you just store the
'previous_thread_life_protection' field in the API_Mutex_Control so
the implementation detail about life state would not bleed into the
code surrounding critical sections.
More generally, if any smp lock will need to protect the thread life
state of the acquiring thread, then the smp lock context would need to
store the previous_thread_life_protection. Propagating this stored
state across fine-grained critical sections will become quite a mess.
Gedare
On Tue, Mar 25, 2014 at 8:49 AM, Sebastian Huber
> This prevents that asynchronous thread deletion can lead to an unusable
> allocator or once mutex.
>  .../arm/altera-cyclone-v/startup/nocache-heap.c    |   10 ++--
>  c/src/lib/libbsp/shared/src/irq-generic.c          |   47 ++++++++++-------
>  cpukit/libcsupport/src/malloc_get_statistics.c     |    8 ++-
>  cpukit/libcsupport/src/rtems_heap_greedy.c         |   16 ++++--
>  cpukit/rtems/src/regioncreate.c                    |    6 ++-
>  cpukit/rtems/src/regiondelete.c                    |    6 ++-
>  cpukit/score/include/rtems/score/apimutex.h        |   56 ++++++++++---------
>  cpukit/score/src/apimutexlock.c                    |   11 +++--
>  cpukit/score/src/apimutexunlock.c                  |    6 ++-
>  cpukit/score/src/once.c                            |    4 +-
>  cpukit/score/src/pheapallocate.c                   |    5 +-
>  cpukit/score/src/pheapextend.c                     |    5 +-
>  cpukit/score/src/pheapfree.c                       |    8 ++-
>  cpukit/score/src/pheapgetblocksize.c               |    6 ++-
>  cpukit/score/src/pheapgetfreeinfo.c                |    4 +-
>  cpukit/score/src/pheapgetinfo.c                    |    6 ++-
>  cpukit/score/src/pheapiterate.c                    |    4 +-
>  cpukit/score/src/pheapresizeblock.c                |    6 ++-
>  cpukit/score/src/pheapwalk.c                       |    4 +-
>  19 files changed, 129 insertions(+), 89 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c b/c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c
> index 0f01989..bf85c8f 100644
> --- a/c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c
> +++ b/c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c
> @@ -62,10 +62,11 @@ void altera_cyclone_v_nocache_init_heap( void )
>  void *altera_cyclone_v_nocache_malloc( const size_t size )
>    void* ret = NULL;
> +  bool previous_thread_life_protection;
> -  _RTEMS_Lock_allocator();
> +  previous_thread_life_protection = _RTEMS_Lock_allocator();
>    ret = _Heap_Allocate( &nocache_heap, size );
> -  _RTEMS_Unlock_allocator();
> +  _RTEMS_Unlock_allocator( previous_thread_life_protection );
>    return ret;
> @@ -79,10 +80,11 @@ void altera_cyclone_v_nocache_free( void *ptr )
>    if ( ptr != NULL ) {
>      bool ok;
>      ok = _Heap_Free( &nocache_heap, ptr );
>      assert( ok );
> diff --git a/c/src/lib/libbsp/shared/src/irq-generic.c b/c/src/lib/libbsp/shared/src/irq-generic.c
> index e30372d..777454d 100644
> --- a/c/src/lib/libbsp/shared/src/irq-generic.c
> +++ b/c/src/lib/libbsp/shared/src/irq-generic.c
> @@ -153,17 +153,23 @@ static void bsp_interrupt_free_handler_entry(bsp_interrupt_handler_entry *e)
>    #endif
> -static void bsp_interrupt_lock(void)
> +static bool bsp_interrupt_lock(void)
>    if (_System_state_Is_up(_System_state_Get())) {
> +  } else {
> +    previous_thread_life_protection = false;
> +  return previous_thread_life_protection;
> -static void bsp_interrupt_unlock(void)
> +static void bsp_interrupt_unlock(bool previous_thread_life_protection)
> +    _RTEMS_Unlock_allocator(previous_thread_life_protection);
> @@ -208,6 +214,7 @@ static rtems_status_code bsp_interrupt_handler_install(
>    rtems_status_code sc = RTEMS_SUCCESSFUL;
>    rtems_interrupt_level level;
>    rtems_vector_number index = 0;
>    bsp_interrupt_handler_entry *head = NULL;
> @@ -226,7 +233,7 @@ static rtems_status_code bsp_interrupt_handler_install(
>    /* Lock */
> -  bsp_interrupt_lock();
> +  previous_thread_life_protection = bsp_interrupt_lock();
>    /* Get handler table index */
>    index = bsp_interrupt_handler_index(vector);
> @@ -237,7 +244,7 @@ static rtems_status_code bsp_interrupt_handler_install(
>    if (bsp_interrupt_is_empty_handler_entry(head)) {
>      if (replace) {
>        /* No handler to replace exists */
> -      bsp_interrupt_unlock();
> +      bsp_interrupt_unlock(previous_thread_life_protection);
>        return RTEMS_UNSATISFIED;
> @@ -257,7 +264,7 @@ static rtems_status_code bsp_interrupt_handler_install(
>        bsp_interrupt_handler_table [index].info = info;
>      } else {
>        /* Handler table is full */
>        return RTEMS_NO_MEMORY;
> @@ -278,7 +285,7 @@ static rtems_status_code bsp_interrupt_handler_install(
>         * Tried to install a unique handler on a not empty
>         * list or there is already a unique handler installed.
>        return RTEMS_RESOURCE_IN_USE;
> @@ -301,7 +308,7 @@ static rtems_status_code bsp_interrupt_handler_install(
>      if (replace) {
>        /* Ensure that a handler to replace exists */
>        if (match == NULL) {
> @@ -311,7 +318,7 @@ static rtems_status_code bsp_interrupt_handler_install(
>        /* Ensure the handler is not already installed */
>        if (match != NULL) {
>          /* The handler is already installed */
>          return RTEMS_TOO_MANY;
> @@ -319,7 +326,7 @@ static rtems_status_code bsp_interrupt_handler_install(
>        current = bsp_interrupt_allocate_handler_entry();
>        if (current == NULL) {
>          /* Not enough memory */
> @@ -348,13 +355,13 @@ static rtems_status_code bsp_interrupt_handler_install(
>    if (enable_vector) {
>      sc = bsp_interrupt_vector_enable(vector);
>      if (sc != RTEMS_SUCCESSFUL) {
>        return sc;
>    /* Unlock */
>    return RTEMS_SUCCESSFUL;
> @@ -376,6 +383,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
> @@ -395,7 +403,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
>    /* Lock */
> @@ -461,7 +469,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
>        /* Check status code */
>          return sc;
>      } else {
> @@ -478,12 +486,12 @@ static rtems_status_code bsp_interrupt_handler_remove(
>    } else {
>      /* No matching entry found */
>    /* Unlock */
> @@ -504,6 +512,7 @@ static rtems_status_code bsp_interrupt_handler_iterate(
>    void *arg
>    bsp_interrupt_handler_entry *current = NULL;
>    rtems_option options = 0;
> @@ -518,7 +527,7 @@ static rtems_status_code bsp_interrupt_handler_iterate(
>    /* Lock */
>    /* Interate */
> @@ -533,7 +542,7 @@ static rtems_status_code bsp_interrupt_handler_iterate(
>    /* Unlock */
> diff --git a/cpukit/libcsupport/src/malloc_get_statistics.c b/cpukit/libcsupport/src/malloc_get_statistics.c
> index a54a4c1..039baca 100644
> --- a/cpukit/libcsupport/src/malloc_get_statistics.c
> +++ b/cpukit/libcsupport/src/malloc_get_statistics.c
> @@ -25,11 +25,15 @@ int malloc_get_statistics(
>    rtems_malloc_statistics_t *stats
>    if ( !stats )
>      return -1;
>    *stats = rtems_malloc_statistics;
>    return 0;
> diff --git a/cpukit/libcsupport/src/rtems_heap_greedy.c b/cpukit/libcsupport/src/rtems_heap_greedy.c
> index 9a55e39..083a8e4 100644
> --- a/cpukit/libcsupport/src/rtems_heap_greedy.c
> +++ b/cpukit/libcsupport/src/rtems_heap_greedy.c
> @@ -31,10 +31,11 @@ void *rtems_heap_greedy_allocate(
>    void *opaque;
>    opaque = _Heap_Greedy_allocate( RTEMS_Malloc_Heap, block_sizes, block_count );
>    return opaque;
> @@ -44,20 +45,23 @@ void *rtems_heap_greedy_allocate_all_except_largest(
>    void *opaque;
>    opaque = _Heap_Greedy_allocate_all_except_largest(
>      RTEMS_Malloc_Heap,
>      allocatable_size
>    return opaque;
>  void rtems_heap_greedy_free( void *opaque )
>    _Heap_Greedy_free( RTEMS_Malloc_Heap, opaque );
> diff --git a/cpukit/rtems/src/regioncreate.c b/cpukit/rtems/src/regioncreate.c
> index 3b4325e..23d42fc 100644
> --- a/cpukit/rtems/src/regioncreate.c
> +++ b/cpukit/rtems/src/regioncreate.c
> @@ -56,6 +56,7 @@ rtems_status_code rtems_region_create(
>    rtems_status_code  return_status;
>    Region_Control    *the_region;
>    if ( !rtems_is_name_valid( name ) )
>      return RTEMS_INVALID_NAME;
> @@ -66,7 +67,7 @@ rtems_status_code rtems_region_create(
>    if ( !id )
>      return RTEMS_INVALID_ADDRESS;
> -  _RTEMS_Lock_allocator();                      /* to prevent deletion */
>      the_region = _Region_Allocate();
> @@ -111,6 +112,7 @@ rtems_status_code rtems_region_create(
>    return return_status;
> diff --git a/cpukit/rtems/src/regiondelete.c b/cpukit/rtems/src/regiondelete.c
> index 5144db0..b793dc6 100644
> --- a/cpukit/rtems/src/regiondelete.c
> +++ b/cpukit/rtems/src/regiondelete.c
> @@ -33,8 +33,9 @@ rtems_status_code rtems_region_delete(
>    Objects_Locations   location;
>      the_region = _Region_Get( id, &location );
>      switch ( location ) {
> @@ -61,6 +62,7 @@ rtems_status_code rtems_region_delete(
>          break;
> diff --git a/cpukit/score/include/rtems/score/apimutex.h b/cpukit/score/include/rtems/score/apimutex.h
> index 380f054..80ccabb 100644
> --- a/cpukit/score/include/rtems/score/apimutex.h
> +++ b/cpukit/score/include/rtems/score/apimutex.h
> @@ -66,20 +66,26 @@ void _API_Mutex_Initialization( uint32_t maximum_mutexes );
>  void _API_Mutex_Allocate( API_Mutex_Control **mutex );
> - *  @brief Acquires the specified API mutex.
> + * @brief Acquires the specified API mutex.
> + * @param[in] mutex The API mutex.
> + * @return The previous life protection of the executing thread.
> -void _API_Mutex_Lock(
> -   API_Mutex_Control *mutex
> +bool _API_Mutex_Lock( API_Mutex_Control *mutex );
> - *  @brief Releases the specified API mutex.
> + * @brief Releases the specified API mutex.
> - *  Releases the specified @a mutex.
> - *  @param[in] mutex is the mutex to be removed.
> + * @param[in] previous_thread_life_protection The previous life protection of
> + * the executing thread.  Must be the value returned by the corresponding
> + * _API_Mutex_Lock() call.
> -void _API_Mutex_Unlock( API_Mutex_Control *mutex );
> +void _API_Mutex_Unlock(
> +  API_Mutex_Control *mutex,
> @@ -104,32 +110,28 @@ void _API_Mutex_Unlock( API_Mutex_Control *mutex );
>  SCORE_EXTERN API_Mutex_Control *_RTEMS_Allocator_Mutex;
> - *  @brief Macro to ease locking the allocator mutex.
> - *  This macro makes it explicit that one is locking the allocator mutex.
> -#define _RTEMS_Lock_allocator() \
> -  _API_Mutex_Lock( _RTEMS_Allocator_Mutex )
> +static inline bool _RTEMS_Lock_allocator( void )
> +  return _API_Mutex_Lock( _RTEMS_Allocator_Mutex );
> - *  @brief Macro to ease unlocking the allocator mutex.
> - *  This macro makes it explicit that one is unlocking the allocator mutex.
> -#define _RTEMS_Unlock_allocator() \
> -  _API_Mutex_Unlock( _RTEMS_Allocator_Mutex )
> +static inline void _RTEMS_Unlock_allocator(
> +  _API_Mutex_Unlock( _RTEMS_Allocator_Mutex, previous_thread_life_protection );
>  SCORE_EXTERN API_Mutex_Control *_Once_Mutex;
> -static inline void _Once_Lock( void )
> +static inline bool _Once_Lock( void )
> -  _API_Mutex_Lock( _Once_Mutex );
> +  return _API_Mutex_Lock( _Once_Mutex );
> -static inline void _Once_Unlock( void )
> +static inline void _Once_Unlock( bool previous_thread_life_protection )
> -  _API_Mutex_Unlock( _Once_Mutex );
> +  _API_Mutex_Unlock( _Once_Mutex, previous_thread_life_protection );
> diff --git a/cpukit/score/src/apimutexlock.c b/cpukit/score/src/apimutexlock.c
> index d943bdd..e506245 100644
> --- a/cpukit/score/src/apimutexlock.c
> +++ b/cpukit/score/src/apimutexlock.c
> @@ -19,16 +19,17 @@
>  #include "config.h"
>  #endif
> -#include <rtems/system.h>
>  #include <rtems/score/apimutex.h>
>  #include <rtems/score/coremuteximpl.h>
> +#include <rtems/score/threadimpl.h>
> -  API_Mutex_Control *the_mutex
> +bool _API_Mutex_Lock( API_Mutex_Control *the_mutex )
>    ISR_Level level;
> +  previous_thread_life_protection = _Thread_Set_life_protection( true );
>    #if defined(RTEMS_SMP)
>      _Thread_Disable_dispatch();
>    #endif
> @@ -47,4 +48,6 @@ void _API_Mutex_Lock(
>      _Thread_Enable_dispatch();
>    #endif
> diff --git a/cpukit/score/src/apimutexunlock.c b/cpukit/score/src/apimutexunlock.c
> index 43bdfe8..3814004 100644
> --- a/cpukit/score/src/apimutexunlock.c
> +++ b/cpukit/score/src/apimutexunlock.c
> @@ -19,12 +19,12 @@
>  #include "config.h"
>  #endif
> +  API_Mutex_Control *the_mutex,
> @@ -34,4 +34,6 @@ void _API_Mutex_Unlock(
>        NULL
> +  _Thread_Set_life_protection( previous_thread_life_protection );
> diff --git a/cpukit/score/src/once.c b/cpukit/score/src/once.c
> index 60ae7a7..e51719c 100644
> --- a/cpukit/score/src/once.c
> +++ b/cpukit/score/src/once.c
> @@ -25,7 +25,7 @@ int _Once( int *once_state, void ( *init_routine )( void ) )
>    int eno = 0;
>    if ( *once_state != ONCE_STATE_COMPLETE ) {
> -    _Once_Lock();
> +    bool previous_thread_life_protection = _Once_Lock();
>       * Getting to here means the once_control is locked so we have:
> @@ -49,7 +49,7 @@ int _Once( int *once_state, void ( *init_routine )( void ) )
>          break;
> -    _Once_Unlock();
> +    _Once_Unlock( previous_thread_life_protection );
>    return eno;
> diff --git a/cpukit/score/src/pheapallocate.c b/cpukit/score/src/pheapallocate.c
> index 4fefb85..057c2e9 100644
> --- a/cpukit/score/src/pheapallocate.c
> +++ b/cpukit/score/src/pheapallocate.c
> @@ -30,15 +30,16 @@ void *_Protected_heap_Allocate_aligned_with_boundary(
>    void *p;
>      p = _Heap_Allocate_aligned_with_boundary(
>        heap,
>        size,
>        alignment,
>        boundary
>    return p;
> diff --git a/cpukit/score/src/pheapextend.c b/cpukit/score/src/pheapextend.c
> index 18f1992..89c44c4 100644
> --- a/cpukit/score/src/pheapextend.c
> +++ b/cpukit/score/src/pheapextend.c
> @@ -29,10 +29,11 @@ bool _Protected_heap_Extend(
>    uintptr_t amount_extended;
>      amount_extended = _Heap_Extend( the_heap, starting_address, size, 0 );
>    return amount_extended != 0;
> diff --git a/cpukit/score/src/pheapfree.c b/cpukit/score/src/pheapfree.c
> index f87b824..f98fc77 100644
> --- a/cpukit/score/src/pheapfree.c
> +++ b/cpukit/score/src/pheapfree.c
> @@ -27,10 +27,12 @@ bool _Protected_heap_Free(
>    void         *start_address
> -  bool    status;
> +  bool status;
>      status = _Heap_Free( the_heap, start_address );
>    return status;
> diff --git a/cpukit/score/src/pheapgetblocksize.c b/cpukit/score/src/pheapgetblocksize.c
> index 5a6f703..367e8a3 100644
> --- a/cpukit/score/src/pheapgetblocksize.c
> +++ b/cpukit/score/src/pheapgetblocksize.c
> @@ -29,9 +29,11 @@ bool _Protected_heap_Get_block_size(
>    bool status;
>      status = _Heap_Size_of_alloc_area( the_heap, starting_address, size );
>    return status;
> diff --git a/cpukit/score/src/pheapgetfreeinfo.c b/cpukit/score/src/pheapgetfreeinfo.c
> index e442ba9..72bdb3e 100644
> --- a/cpukit/score/src/pheapgetfreeinfo.c
> +++ b/cpukit/score/src/pheapgetfreeinfo.c
> @@ -31,9 +31,9 @@ bool _Protected_heap_Get_free_information(
>     * TBD: _Heap_Get_free_information does not error check or return status.
> +  bool previous_thread_life_protection = _RTEMS_Lock_allocator();
>      _Heap_Get_free_information( the_heap, info );
>    return true;
> diff --git a/cpukit/score/src/pheapgetinfo.c b/cpukit/score/src/pheapgetinfo.c
> index 6ece4e4..a0d0a3e 100644
> --- a/cpukit/score/src/pheapgetinfo.c
> +++ b/cpukit/score/src/pheapgetinfo.c
> @@ -27,15 +27,17 @@ bool _Protected_heap_Get_information(
>    Heap_Information_block  *the_info
>    if ( !the_heap )
>      return false;
>    if ( !the_info )
>      return false;
>      _Heap_Get_information( the_heap, the_info );
>    return true;
> diff --git a/cpukit/score/src/pheapiterate.c b/cpukit/score/src/pheapiterate.c
> index 9b6d945..6bea29f 100644
> --- a/cpukit/score/src/pheapiterate.c
> +++ b/cpukit/score/src/pheapiterate.c
> @@ -32,7 +32,7 @@ void _Protected_heap_Iterate(
>    void *visitor_arg
>    _Heap_Iterate( heap, visitor, visitor_arg );
> diff --git a/cpukit/score/src/pheapresizeblock.c b/cpukit/score/src/pheapresizeblock.c
> index c733ddc..416485e 100644
> --- a/cpukit/score/src/pheapresizeblock.c
> +++ b/cpukit/score/src/pheapresizeblock.c
> @@ -31,11 +31,13 @@ bool _Protected_heap_Resize_block(
>    Heap_Resize_status status;
>    uintptr_t          old_mem_size;
>    uintptr_t          avail_mem_size;
>      status = _Heap_Resize_block(
>        the_heap, starting_address, size, &old_mem_size, &avail_mem_size );
>    return (status == HEAP_RESIZE_SUCCESSFUL);
> diff --git a/cpukit/score/src/pheapwalk.c b/cpukit/score/src/pheapwalk.c
> index 5605470..6b18c77 100644
> --- a/cpukit/score/src/pheapwalk.c
> +++ b/cpukit/score/src/pheapwalk.c
> @@ -38,9 +38,9 @@ bool _Protected_heap_Walk(
>     * NOTE: Dispatching is also disabled during initialization.
>    if ( _Thread_Dispatch_is_enabled() ) {
>        status = _Heap_Walk( the_heap, source, do_dump );
>    } else {
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
