[GSoC] Porting RTEMS to OpenRISC - Status Report 1
Fri May 2 21:40:51 UTC 2014
On 5/1/2014 10:17 PM, Hesham Moustafa wrote:
> Hi,
> This is a status report of the project during last week.
> 1- newlib: is ported and gcc builds successfully. The only feedback I
> got when I posted the newlib patch [1] is about licence of setjmp.S
> file. I contacted Damjan Lampret, the author of the file, asking him
> to change the licence as Ralf suggested but I got no reply yet. If
> changing the licence has not been feasible, can I write a similar
> setjmp.S one?
As Chris points out, this needs to be discussed on the newlib mailing list.
I suppose given a working simulator and or1k-elf toolset w/o setjmp,
anyone could write one.
But setjmp is not a requirement for building RTEMS. It can be deferred
for a while while this is worked through.  [NOTE: there may be one
or two tests which use setjmp. Can't remember.]
Damjan may have an old mailing list post for the code originally which
makes the license clear.
Also please cc me on all correspondence like that. It may not help much
but I at least show up in Google and have some FLOSS credibility via RTEMS,
 the GCC Steering Committee, and the Network Time Foundation.
If it has been more than a week, then it may be worth a second ping.
Did you use damjanl at lampret.com?
> 2- toolchain: is all built now providing or1k-rtems4.11-* tools. GDB
> is built too but from or1k-src repo. Should I create a patch for it
> against upsteam binutils-gdb cvs? If yes, there are two options: the
> first is to add a patch for or1ksim library to be embedded into gdb
> and used when typing "target sim" command, the other option is to
> connect gdb remotely to or1ksim simulator (target remote :xxxxx).
> Which one to implement?
This is really the decision of the or1k tools folks plus the gdb folks.
Whatever
they think is the way they want it to work is what we will end up stuck with
long term.
Either way, the RSB must give you a GDB and simulator.
Help or1k folks push to their solution here. Your effort is on the port.
> 3- RTEMS: I started investigating the old or32 port for RTEMS, that
> led me to add few files and configurations for or1k cpu and or1ksim
> BSP for testing purposes. I was trying to get a libbspstart.a and link
> it with other standalone bare-metal main.c program, thus, I
> familiarize my self with the process of adding a new architecture, and
> have some code to debug.
In the past when doing BSPs for simulators, I have used the linker
script, start
assembly and other helper bits and pieces from the bare metal examples.
But if the license is unacceptable, then it can only be used as reference.
As a first cut, look at the h8sim or shsim. Both as VERY simple and may
be good starting points for polled console, simple clock tick BSP to get
started with. For those, I can show you the code in libgloss they
leveraged.
> I would appreciate your feedback and guidance.
> [1] http://www.rtems.org/pipermail/rtems-devel/2014-April/006598.html
> Thanks,
> Hesham
