Rtems_fsmount dosfs hanging
Andrey Mozzhuhin
nopscmn at gmail.com
Mon May 5 18:30:33 UTC 2014
You can try to use SD Card in opposite direction:
0) fill SD Card with zeroes;
1) format partition under RTEMS with msdos_format() function;
2) check that PC can read/write this SD Card;
3) if PC fails to mount this partition - dump SD Card and check that all
data is on right sectors.
2014-05-05 22:28 GMT+04:00 Andrey Mozzhuhin <nopscmn at gmail.com>:
> Hi, Andre
> 2014-05-05 13:52 GMT+04:00 Andre Marques <andre.lousa.marques at gmail.com>:
> Hello,
>> Following the problem in
>> http://www.rtems.org/pipermail/rtems-devel/2014-April/006585.html
>> I am now trying to mount the SD card partitions on RTEMS.
>> Summarizing the process:
>> 1. rtems_io_register_driver (by calling my driver with
>> CONFIGURE_APPLICATION_EXTRA_DRIVERS on hello sample)
>> 2. rtems_filesystem_make_dev_t (to get the device file)
>> 3. rtems_disk_io_initialize
>> 4. rtems_disk_create_phys (to create the disk, at /dev/sdc0)
>> 5. rtems_bdpart_register_from_disk (to read and register the partitions)
>> 6. rtems_fsmount (to mount the partitions)
>> For rtems_fsmount I am providing the following fs_table:
>> rtems_fstab_entry fs_table [] = {
>> .source = "/dev/sdc0",
>> .target = "/mnt/p1",
>> .type = "dosfs",
>> .options = RTEMS_FILESYSTEM_READ_WRITE,
>> .report_reasons = RTEMS_FSTAB_ANY,
>> .abort_reasons = RTEMS_FSTAB_OK
>> .source = "/dev/sdc01",
>> .target = "/mnt/p2",
>> .type = "dosfs",
>> .abort_reasons = RTEMS_FSTAB_NONE
>> The SD card has only one partition starting at block number 8192.
>> After I call rtems_fsmount it calls my driver to read block 8192 and 8193
>> and then hangs.
>> I have tested the driver and It seems to have no problem reading single
>> or multiple blocks.
>> Any tips?
>> Also I am using the following confdefs configuration (some values are
>> exaggerated):
>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
>> #define CONFIGURE_FILESYSTEM_DOSFS
>> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>> #define CONFIGURE_APPLICATION_EXTRA_DRIVERS SD_CARD_DRIVER_TABLE_ENTRY
>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
>> #define CONFIGURE_MAXIMUM_TASKS 2
>> #define CONFIGURE_MAXIMUM_DRIVERS 10
>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
>> #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> --André Marques
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140505/9c55cbd2/attachment.html>
