[PATCH 1/1] sparc: Change asm to __asm__ to compile with -std=c99.
Wed May 14 08:34:06 UTC 2014
On 2014-05-14 10:17, Daniel Cederman wrote:
>   cpukit/score/cpu/sparc/rtems/score/cpu.h |    2 +-
>   1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> index b931d2f..532d882 100644
> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> @@ -1181,7 +1181,7 @@ void _CPU_Context_restore(
>    * @brief The pointer to the current per-CPU control is available via register
>    * g6.
> -register struct Per_CPU_Control *_SPARC_Per_CPU_current asm( "g6" );
> +register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__( "g6" );
>   #define _CPU_Get_current_per_CPU_control() ( _SPARC_Per_CPU_current )
Thanks, patch applied.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
