Scheduler Priority Cleanup
Mon May 19 06:19:22 UTC 2014
On 2014-05-16 19:48, Joel Sherrill wrote:
> Hi
> In reviewing the _Thread_Change_priority and associated
> changes in anticipation of using them as a pattern for the
> set affinity code, I have spotted a few things:
> + _Scheduler_Update() is only called from _Thread_Change_priority()
> and _Thread_Set_priority().  It should be renamed to reflect priority.
> This would change _Scheduler_Update() to _Scheduler_Update_priority()
> as well as the associated Scheduler_Context element and implementations
> since they should be renamed.
Yes, this sounds good.
> + The change_priority, update(_priority), and priority_compare
> entries in Scheduler_Context are not next to each other. They
> are also not consistent in naming. They need to be at least
> reordered.
> Comments?
The scheduler operations should be reordered to increase cache efficiency, e.g.
operations used frequently or are critical should move to the begin of the
structure to be next to the context pointer.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
