Rtems_fsmount dosfs hanging
Andrey Mozzhuhin
nopscmn at gmail.com
Mon May 12 18:25:55 UTC 2014
I think you need start with simple tests without file systems and block
device driver.
Try read and write blocks with known patterns and check it on PC and
Raspberry Pi.
What are you use for MMC/SD protocol? Can I see it and block device driver
somewhere?
2014-05-12 20:23 GMT+04:00 Andre Marques <andre.lousa.marques at gmail.com>:
> Hello,
> I have used the pc386 BSP to mount the card (before your suggestions)
> using the fileio sample and it could read the card contents perfectly.
> Then I filled the card with zeros using dd on Linux, modified the fileio
> sample to format the card with msdos_format(dev, NULL) and then mounted it
> on the pc 386 BSP fileio sample and I could write and read the card.
> On Linux I set the card with the necessary files for Raspberry, and when
> my driver tries to mount the card on the Raspberry Pi it reads the first 2
> blocks (now 0 and 1, because the card has no partition table) and hangs,
> just as before.
> I guess my driver is having some reading problems.
> On 05/05/14 19:30, Andrey Mozzhuhin wrote:
> You can try to use SD Card in opposite direction:
> 0) fill SD Card with zeroes;
> 1) format partition under RTEMS with msdos_format() function;
> 2) check that PC can read/write this SD Card;
> 3) if PC fails to mount this partition - dump SD Card and check that all
> data is on right sectors.
> 2014-05-05 22:28 GMT+04:00 Andrey Mozzhuhin <nopscmn at gmail.com>:
>> Hi, Andre
>> 2014-05-05 13:52 GMT+04:00 Andre Marques <andre.lousa.marques at gmail.com>:
>> Hello,
>>> Following the problem in
>>> http://www.rtems.org/pipermail/rtems-devel/2014-April/006585.html
>>> I am now trying to mount the SD card partitions on RTEMS.
>>> Summarizing the process:
>>> 1. rtems_io_register_driver (by calling my driver with
>>> CONFIGURE_APPLICATION_EXTRA_DRIVERS on hello sample)
>>> 2. rtems_filesystem_make_dev_t (to get the device file)
>>> 3. rtems_disk_io_initialize
>>> 4. rtems_disk_create_phys (to create the disk, at /dev/sdc0)
>>> 5. rtems_bdpart_register_from_disk (to read and register the partitions)
>>> 6. rtems_fsmount (to mount the partitions)
>>> For rtems_fsmount I am providing the following fs_table:
>>> rtems_fstab_entry fs_table [] = {
>>> .source = "/dev/sdc0",
>>> .target = "/mnt/p1",
>>> .type = "dosfs",
>>> .options = RTEMS_FILESYSTEM_READ_WRITE,
>>> .report_reasons = RTEMS_FSTAB_ANY,
>>> .abort_reasons = RTEMS_FSTAB_OK
>>> .source = "/dev/sdc01",
>>> .target = "/mnt/p2",
>>> .type = "dosfs",
>>> .abort_reasons = RTEMS_FSTAB_NONE
>>> The SD card has only one partition starting at block number 8192.
>>> After I call rtems_fsmount it calls my driver to read block 8192 and
>>> 8193 and then hangs.
>>> I have tested the driver and It seems to have no problem reading single
>>> or multiple blocks.
>>> Any tips?
>>> Also I am using the following confdefs configuration (some values are
>>> exaggerated):
>>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>> #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
>>> #define CONFIGURE_FILESYSTEM_DOSFS
>>> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>>> #define CONFIGURE_APPLICATION_EXTRA_DRIVERS SD_CARD_DRIVER_TABLE_ENTRY
>>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
>>> #define CONFIGURE_MAXIMUM_TASKS 2
>>> #define CONFIGURE_MAXIMUM_DRIVERS 10
>>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>> #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
>>> #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>>> --André Marques
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
> rtems-devel mailing listrtems-devel at rtems.orghttp://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140512/4a5d7486/attachment-0001.html>
