Rtems_fsmount dosfs hanging
Andre Marques
andre.lousa.marques at gmail.com
Tue May 13 10:03:50 UTC 2014
On 05/12/14 19:25, Andrey Mozzhuhin wrote:
> I think you need start with simple tests without file systems and
> block device driver.
> Try read and write blocks with known patterns and check it on PC and
> Raspberry Pi.
I have checked the data read by my emmc driver from the first two blocks
(the ones it reads) on the RPi, and compared with an hexdump of those
same two blocks on Linux, and there is a small mismatch at the middle of
the first block.
Not sure how to approach this problem, as the logic seems right. Will do
more testing in the meanwhile.
> What are you use for MMC/SD protocol? Can I see it and block device
> driver somewhere?
I'm porting the following code
https://github.com/jncronin/rpi-boot/blob/master/emmc.c
and using the following SD card documentation
Physical Layer Simplified Specification (3.01) -
https://www.sdcard.org/downloads/pls/simplified_specs/archive/part1_301.pdf
Host Controller Simplified Specification (2.00) -
https://www.sdcard.org/downloads/pls/simplified_specs/archive/partA2_200.pdf
and the raspberry soc datasheet: Broadcom BCM2835 Peripherals Guide
(Chapter 5 - EMMC)
> 2014-05-12 20:23 GMT+04:00 Andre Marques
> <andre.lousa.marques at gmail.com <mailto:andre.lousa.marques at gmail.com>>:
> Hello,
> I have used the pc386 BSP to mount the card (before your
> suggestions) using the fileio sample and it could read the card
> contents perfectly.
> Then I filled the card with zeros using dd on Linux, modified the
> fileio sample to format the card with msdos_format(dev, NULL) and
> then mounted it on the pc 386 BSP fileio sample and I could write
> and read the card.
> On Linux I set the card with the necessary files for Raspberry,
> and when my driver tries to mount the card on the Raspberry Pi it
> reads the first 2 blocks (now 0 and 1, because the card has no
> partition table) and hangs, just as before.
> I guess my driver is having some reading problems.
> On 05/05/14 19:30, Andrey Mozzhuhin wrote:
>> You can try to use SD Card in opposite direction:
>> 0) fill SD Card with zeroes;
>> 1) format partition under RTEMS with msdos_format() function;
>> 2) check that PC can read/write this SD Card;
>> 3) if PC fails to mount this partition - dump SD Card and check
>> that all data is on right sectors.
>> 2014-05-05 22:28 GMT+04:00 Andrey Mozzhuhin <nopscmn at gmail.com
>> <mailto:nopscmn at gmail.com>>:
>> Hi, Andre
>> check that all data is on right sectors.
>> 2014-05-05 13:52 GMT+04:00 Andre Marques
>> Hello,
>> Following the problem in
>> http://www.rtems.org/pipermail/rtems-devel/2014-April/006585.html
>> I am now trying to mount the SD card partitions on RTEMS.
>> Summarizing the process:
>> 1. rtems_io_register_driver (by calling my driver with
>> CONFIGURE_APPLICATION_EXTRA_DRIVERS on hello sample)
>> 2. rtems_filesystem_make_dev_t (to get the device file)
>> 3. rtems_disk_io_initialize
>> 4. rtems_disk_create_phys (to create the disk, at /dev/sdc0)
>> 5. rtems_bdpart_register_from_disk (to read and register
>> the partitions)
>> 6. rtems_fsmount (to mount the partitions)
>> For rtems_fsmount I am providing the following fs_table:
>> rtems_fstab_entry fs_table [] = {
>> .source = "/dev/sdc0",
>> .target = "/mnt/p1",
>> .type = "dosfs",
>> .options = RTEMS_FILESYSTEM_READ_WRITE,
>> .report_reasons = RTEMS_FSTAB_ANY,
>> .abort_reasons = RTEMS_FSTAB_OK
>> .source = "/dev/sdc01",
>> .target = "/mnt/p2",
>> .type = "dosfs",
>> .abort_reasons = RTEMS_FSTAB_NONE
>> The SD card has only one partition starting at block
>> number 8192.
>> After I call rtems_fsmount it calls my driver to read
>> block 8192 and 8193 and then hangs.
>> I have tested the driver and It seems to have no problem
>> reading single or multiple blocks.
>> Any tips?
>> Also I am using the following confdefs configuration
>> (some values are exaggerated):
>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
>> #define CONFIGURE_FILESYSTEM_DOSFS
>> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>> #define CONFIGURE_APPLICATION_EXTRA_DRIVERS
>> SD_CARD_DRIVER_TABLE_ENTRY
>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
>> #define CONFIGURE_MAXIMUM_TASKS 2
>> #define CONFIGURE_MAXIMUM_DRIVERS 10
>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
>> #define CONFIGURE_INITIAL_EXTENSIONS
>> RTEMS_TEST_INITIAL_EXTENSION
>> --André Marques
>> rtems-devel mailing list
>> rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
>> http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140513/0fd776a9/attachment-0001.html>
