Rtems_fsmount dosfs hanging
Andre Marques andre.lousa.marques at gmail.com
Tue May 13 19:00:24 UTC 2014
On 05/13/14 12:15, Andrey Mozzhuhin wrote:
> Do you not forget to call rtems_blkdev_request_done in read routine of
> block device driver?
> Also try to increase CONFIGURE_MAXIMUM_TASKS - bdbuf need some worker
> tasks.
I call rtems_blkdev_request_done after each read request, and changing
CONFIGURE_MAXIMUM_TASKS to 20 (instead of 2) did not had any impact.
> >> https://github.com/jncronin/rpi-boot/blob/master/emmc.c
> Hmm. Implementation specific to Raspberry Pi is not good idea. It is
> better to separate MMC/SD protocol implementation and hardware support
> like in FreeBSD or Linux.
Yes, the point in the end is probably to have the MMC/SD protocol
somewhere else, just like the spi-sd-card driver (SD card access through
SPI interface protocol, at c/src/libchip/i2c/spi-sd-card*).
> >> Not sure how to approach this problem, as the logic seems right.
> Will do more testing in the meanwhile.
Today I have re-formated the card (under Linux), and the block data read
on RPi checks with the card hexdump on Linux.
So far I tested:
- The block data that is being read, and compared with the same block
data read on Linux (small mismatch (4 bits) at the middle of a 512 byte
block before, no mismatch now)
- The request buffer contents
(http://www.rtems.org/onlinedocs/doxygen/cpukit/html/structrtems__blkdev__sg__buffer.html).
Looking at this I don't know what the User pointer is. I'm using the
buffer pointer to store my readings.
- Reading the partition table from the first block. I can read the first
block and register the card partition as a logical disk, so reading and
registering the partition table is no problem.
- Tried also a busy wait between block readings.
The result is always the same: when mounting the card partition, it
reads the first two partition blocks and then hangs.
> If you get stuck share your sources and let me know.
Will try to get the code to github soon.
> 2014-05-13 14:03 GMT+04:00 Andre Marques
> <andre.lousa.marques at gmail.com <mailto:andre.lousa.marques at gmail.com>>:
>     On 05/12/14 19:25, Andrey Mozzhuhin wrote:
>>     I think you need start with simple tests without file systems and
>>     block device driver.
>>     Try read and write blocks with known patterns and check it on PC
>>     and Raspberry Pi.
>     I have checked the data read by my emmc driver from the first two
>     blocks (the ones it reads) on the RPi, and compared with an
>     hexdump of those same two blocks on Linux, and there is a small
>     mismatch at the middle of the first block.
>>     What are you use for MMC/SD protocol? Can I see it and block
>>     device driver somewhere?
>     I'm porting the following code
>     and using the following SD card documentation
>     Physical Layer Simplified Specification (3.01)  -
>     https://www.sdcard.org/downloads/pls/simplified_specs/archive/part1_301.pdf
>     Host Controller Simplified Specification (2.00) -
>     https://www.sdcard.org/downloads/pls/simplified_specs/archive/partA2_200.pdf
>     and the raspberry soc datasheet: Broadcom BCM2835 Peripherals
>     Guide (Chapter 5 - EMMC)
>>     2014-05-12 20:23 GMT+04:00 Andre Marques
>>         Hello,
>>         I have used the pc386 BSP to mount the card (before your
>>         suggestions) using the fileio sample and it could read the
>>         card contents perfectly.
>>         Then I filled the card with zeros using dd on Linux, modified
>>         the fileio sample to format the card with msdos_format(dev,
>>         NULL) and then mounted it on the pc 386 BSP fileio sample and
>>         I could write and read the card.
>>         On Linux I set the card with the necessary files for
>>         Raspberry, and when my driver tries to mount the card on the
>>         Raspberry Pi it reads the first 2 blocks (now 0 and 1,
>>         because the card has no partition table) and hangs, just as
>>         before.
>>         I guess my driver is having some reading problems.
>>         On 05/05/14 19:30, Andrey Mozzhuhin wrote:
>>>         You can try to use SD Card in opposite direction:
>>>         0) fill SD Card with zeroes;
>>>         1) format partition under RTEMS with msdos_format() function;
>>>         2) check that PC can read/write this SD Card;
>>>         3) if PC fails to mount this partition - dump SD Card and
>>>         check that all data is on right sectors.
>>>         2014-05-05 22:28 GMT+04:00 Andrey Mozzhuhin
>>>         <nopscmn at gmail.com <mailto:nopscmn at gmail.com>>:
>>>             Hi, Andre
>>>             function;
>>>             and check that all data is on right sectors.
>>>             2014-05-05 13:52 GMT+04:00 Andre Marques
>>>                 Hello,
>>>                 Following the problem in
>>>                 http://www.rtems.org/pipermail/rtems-devel/2014-April/006585.html
>>>                 I am now trying to mount the SD card partitions on
>>>                 RTEMS.
>>>                 Summarizing the process:
>>>                 1. rtems_io_register_driver (by calling my driver
>>>                 with CONFIGURE_APPLICATION_EXTRA_DRIVERS on hello
>>>                 sample)
>>>                 2. rtems_filesystem_make_dev_t (to get the device file)
>>>                 3.  rtems_disk_io_initialize
>>>                 4. rtems_disk_create_phys (to create the disk, at
>>>                 /dev/sdc0)
>>>                 5. rtems_bdpart_register_from_disk (to read and
>>>                 register the partitions)
>>>                 6. rtems_fsmount (to mount the partitions)
>>>                 For rtems_fsmount I am providing the following fs_table:
>>>                 rtems_fstab_entry fs_table [] = {
>>>                      .source = "/dev/sdc0",
>>>                      .target = "/mnt/p1",
>>>                      .type = "dosfs",
>>>                      .options = RTEMS_FILESYSTEM_READ_WRITE,
>>>                      .report_reasons =  RTEMS_FSTAB_ANY,
>>>                      .abort_reasons = RTEMS_FSTAB_OK
>>>                      .source = "/dev/sdc01",
>>>                      .target = "/mnt/p2",
>>>                      .type = "dosfs",
>>>                      .abort_reasons = RTEMS_FSTAB_NONE
>>>                 The SD card has only one partition starting at block
>>>                 number 8192.
>>>                 After I call rtems_fsmount it calls my driver to
>>>                 read block 8192 and 8193 and then hangs.
>>>                 I have tested the driver and It seems to have no
>>>                 problem reading single or multiple blocks.
>>>                 Any tips?
>>>                 Also I am using the following confdefs configuration
>>>                 (some values are exaggerated):
>>>                 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>>                 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>>                 #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
>>>                 #define CONFIGURE_FILESYSTEM_DOSFS
>>>                 #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>>>                 #define CONFIGURE_APPLICATION_EXTRA_DRIVERS
>>>                 SD_CARD_DRIVER_TABLE_ENTRY
>>>                 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
>>>                 #define CONFIGURE_MAXIMUM_TASKS 2
>>>                 #define CONFIGURE_MAXIMUM_DRIVERS 10
>>>                 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>>                  #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
>>>                 #define CONFIGURE_INITIAL_EXTENSIONS
>>>                 RTEMS_TEST_INITIAL_EXTENSION
>>>                 --André Marques
>>>                 _______________________________________________
>>>                 rtems-devel mailing list
>>>                 rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
>>>                 http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140513/72d16c7f/attachment-0001.html>
