Rtems_fsmount dosfs hanging
Andrey Mozzhuhin
nopscmn at gmail.com
Tue May 13 11:15:40 UTC 2014
Do you not forget to call rtems_blkdev_request_done in read routine of
block device driver?
Also try to increase CONFIGURE_MAXIMUM_TASKS - bdbuf need some worker tasks.
>> https://github.com/jncronin/rpi-boot/blob/master/emmc.c
Hmm. Implementation specific to Raspberry Pi is not good idea. It is better
to separate MMC/SD protocol implementation and hardware support like in
FreeBSD or Linux.
>> Not sure how to approach this problem, as the logic seems right. Will do
more testing in the meanwhile.
If you get stuck share your sources and let me know.
2014-05-13 14:03 GMT+04:00 Andre Marques <andre.lousa.marques at gmail.com>:
> On 05/12/14 19:25, Andrey Mozzhuhin wrote:
> I think you need start with simple tests without file systems and block
> device driver.
> Try read and write blocks with known patterns and check it on PC and
> Raspberry Pi.
> I have checked the data read by my emmc driver from the first two blocks
> (the ones it reads) on the RPi, and compared with an hexdump of those same
> two blocks on Linux, and there is a small mismatch at the middle of the
> first block.
> What are you use for MMC/SD protocol? Can I see it and block device
> driver somewhere?
> I'm porting the following code
> and using the following SD card documentation
> Physical Layer Simplified Specification (3.01) -
> https://www.sdcard.org/downloads/pls/simplified_specs/archive/part1_301.pdf
> Host Controller Simplified Specification (2.00) -
> https://www.sdcard.org/downloads/pls/simplified_specs/archive/partA2_200.pdf
> and the raspberry soc datasheet: Broadcom BCM2835 Peripherals Guide
> (Chapter 5 - EMMC)
> 2014-05-12 20:23 GMT+04:00 Andre Marques <andre.lousa.marques at gmail.com>:
>> Hello,
>> I have used the pc386 BSP to mount the card (before your suggestions)
>> using the fileio sample and it could read the card contents perfectly.
>> Then I filled the card with zeros using dd on Linux, modified the fileio
>> sample to format the card with msdos_format(dev, NULL) and then mounted it
>> on the pc 386 BSP fileio sample and I could write and read the card.
>> On Linux I set the card with the necessary files for Raspberry, and when
>> my driver tries to mount the card on the Raspberry Pi it reads the first 2
>> blocks (now 0 and 1, because the card has no partition table) and hangs,
>> just as before.
>> I guess my driver is having some reading problems.
>> On 05/05/14 19:30, Andrey Mozzhuhin wrote:
>> You can try to use SD Card in opposite direction:
>> 0) fill SD Card with zeroes;
>> 1) format partition under RTEMS with msdos_format() function;
>> 2) check that PC can read/write this SD Card;
>> 3) if PC fails to mount this partition - dump SD Card and check that all
>> data is on right sectors.
>> 2014-05-05 22:28 GMT+04:00 Andrey Mozzhuhin <nopscmn at gmail.com>:
>>> Hi, Andre
>>> all data is on right sectors.
>>> 2014-05-05 13:52 GMT+04:00 Andre Marques <andre.lousa.marques at gmail.com>:
>>> Hello,
>>>> Following the problem in
>>>> http://www.rtems.org/pipermail/rtems-devel/2014-April/006585.html
>>>> I am now trying to mount the SD card partitions on RTEMS.
>>>> Summarizing the process:
>>>> 1. rtems_io_register_driver (by calling my driver with
>>>> CONFIGURE_APPLICATION_EXTRA_DRIVERS on hello sample)
>>>> 2. rtems_filesystem_make_dev_t (to get the device file)
>>>> 3. rtems_disk_io_initialize
>>>> 4. rtems_disk_create_phys (to create the disk, at /dev/sdc0)
>>>> 5. rtems_bdpart_register_from_disk (to read and register the partitions)
>>>> 6. rtems_fsmount (to mount the partitions)
>>>> For rtems_fsmount I am providing the following fs_table:
>>>> rtems_fstab_entry fs_table [] = {
>>>> .source = "/dev/sdc0",
>>>> .target = "/mnt/p1",
>>>> .type = "dosfs",
>>>> .options = RTEMS_FILESYSTEM_READ_WRITE,
>>>> .report_reasons = RTEMS_FSTAB_ANY,
>>>> .abort_reasons = RTEMS_FSTAB_OK
>>>> .source = "/dev/sdc01",
>>>> .target = "/mnt/p2",
>>>> .type = "dosfs",
>>>> .abort_reasons = RTEMS_FSTAB_NONE
>>>> The SD card has only one partition starting at block number 8192.
>>>> After I call rtems_fsmount it calls my driver to read block 8192 and
>>>> 8193 and then hangs.
>>>> I have tested the driver and It seems to have no problem reading single
>>>> or multiple blocks.
>>>> Any tips?
>>>> Also I am using the following confdefs configuration (some values are
>>>> exaggerated):
>>>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>>> #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
>>>> #define CONFIGURE_FILESYSTEM_DOSFS
>>>> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>>>> #define CONFIGURE_APPLICATION_EXTRA_DRIVERS SD_CARD_DRIVER_TABLE_ENTRY
>>>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
>>>> #define CONFIGURE_MAXIMUM_TASKS 2
>>>> #define CONFIGURE_MAXIMUM_DRIVERS 10
>>>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>>> #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
>>>> #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>>>> --André Marques
>>>> _______________________________________________
>>>> rtems-devel mailing list
>>>> rtems-devel at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>> rtems-devel mailing listrtems-devel at rtems.orghttp://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140513/354178e1/attachment-0001.html>
