psim fails to link with --enable-smp
Sebastian Huber
Thu May 15 11:49:46 UTC 2014
On 2014-05-14 20:38, Joel Sherrill wrote:
> Hi
> All of the SPARC BSPs are OK with --enable-smp but at least
> psim doesn't link when it is enabled. I haven't checked ARM
> but I suspect that some default magic needs to be in place
> in the Makefile.am's.
You can use something like the attached patch. If you want SMP support for
every BSP, then we need a solution with less copy and paste.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140515/72de5a31/attachment-0001.bin>
