psim fails to link with --enable-smp
Sebastian Huber
Thu May 15 12:00:56 UTC 2014
On 2014-05-15 13:49, Sebastian Huber wrote:
> On 2014-05-14 20:38, Joel Sherrill wrote:
>> Hi
>> All of the SPARC BSPs are OK with --enable-smp but at least
>> psim doesn't link when it is enabled. I haven't checked ARM
>> but I suspect that some default magic needs to be in place
>> in the Makefile.am's.
> You can use something like the attached patch. If you want SMP support for
> every BSP, then we need a solution with less copy and paste.
PSIM needs also an ability to get the current processor since it apparently
doesn't support the Book E PIR.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
