[PATCH] [RSB] Add support for building rtems-or1k tool-chain - fixed
Hesham Moustafa heshamelmatary at gmail.com
Mon May 26 19:31:33 UTC 2014
Hi Chris,
Please have a look at this patch when you have sometime. I have fixed it
according to your comments.
Thanks,
- Hesham
On Mon, May 26, 2014 at 3:40 AM, Hesham ALMatary
<heshamelmatary at gmail.com>wrote:
> Configuration files get the following releases:
> - binutils-2.24
> - newlib-2.1.0
> - gcc-4.8.2
> - gdb-7.7
> Patches to tool-chain are mix of OpenRISC original patches and other
> additions to build the previous releases for RTEMS.
>  rtems/config/4.11/rtems-or1k.bset | 49
>  source-builder/config/gdb-7-1.cfg |  6 ++++-
>  2 files changed, 54 insertions(+), 1 deletion(-)
>  create mode 100644 rtems/config/4.11/rtems-or1k.bset
> diff --git a/rtems/config/4.11/rtems-or1k.bset
> b/rtems/config/4.11/rtems-or1k.bset
> new file mode 100644
> index 0000000..83a4a8d
> --- /dev/null
> +++ b/rtems/config/4.11/rtems-or1k.bset
> @@ -0,0 +1,49 @@
> +# Tools Set for RTEMS or1k 4.11 Stable
> +%define release 1
> +%define rtems_arch or1k
> +# The RTEMS 4.11 BSP to build and test
> +%define rtems_bsps      all
> +# The RTEMS 4.11 base defines.
> +%include rtems-4.11-base.bset
> +# Tools configuration.
> +4.11/rtems-autotools
> +devel/expat-2.1.0-1
> +tools/rtems-binutils-2.24-1
> +tools/rtems-gcc-4.8.2-newlib-2.1.0-1
> +tools/rtems-gdb-7.7-1
> +# or1k specific patches
> +#binutils
> +%patch add binutils -p1
> https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/binutils-2.24-or1k-rtems.diff
> +#newlib
> +%patch add newlib -p1
> https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/newlib-cvs-or1k-rtems-29-4-2014.diff
> +#gcc
> +%patch add gcc -p1
> https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gcc-4.8.2-or1k-rtems-29-4-2014.diff
> +#gdb
> +%patch add gdb -p1
> https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gdb-7.7-or1k-rtems.diff
> +# or1k specific configurations
> +#gdb
> +%define gdb-disable-sim 1
> diff --git a/source-builder/config/gdb-7-1.cfg
> b/source-builder/config/gdb-7-1.cfg
> index 28f19b2..343bd04 100644
> --- a/source-builder/config/gdb-7-1.cfg
> +++ b/source-builder/config/gdb-7-1.cfg
> @@ -4,6 +4,10 @@
>  # This configuration file configure's, make's and install's gdb.
> +%if %{gdb-disable-sim} == %{nil}
> +%define gdb-disable-sim 0
> +%endif
>  %include %{_configdir}/checks.cfg
> @@ -73,7 +77,7 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
>      --without-included-gettext \
>      --disable-win32-registry \
>      --disable-werror \
> -    --enable-sim \
> +    %{!?gdb-disable-sim:--enable-sim}%{?gdb-disable-sim:--disable-sim} \
>      --without-zlib \
>      --with-expat \
>      %{!?without_python:--with-python} \
> 1.8.3.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140526/8adbbfc1/attachment-0001.html>
