[PATCH] [RSB] Add support for building rtems-or1k tool-chain - fixed
Hesham ALMatary
heshamelmatary at gmail.com
Mon May 26 01:40:22 UTC 2014
Configuration files get the following releases:
- binutils-2.24
- newlib-2.1.0
- gcc-4.8.2
- gdb-7.7
Patches to tool-chain are mix of OpenRISC original patches and other
additions to build the previous releases for RTEMS.
rtems/config/4.11/rtems-or1k.bset | 49 +++++++++++++++++++++++++++++++++++++++
source-builder/config/gdb-7-1.cfg | 6 ++++-
2 files changed, 54 insertions(+), 1 deletion(-)
create mode 100644 rtems/config/4.11/rtems-or1k.bset
diff --git a/rtems/config/4.11/rtems-or1k.bset b/rtems/config/4.11/rtems-or1k.bset
new file mode 100644
index 0000000..83a4a8d
--- /dev/null
+++ b/rtems/config/4.11/rtems-or1k.bset
@@ -0,0 +1,49 @@
+# Tools Set for RTEMS or1k 4.11 Stable
+%define release 1
+%define rtems_arch or1k
+# The RTEMS 4.11 BSP to build and test
+%define rtems_bsps all
+# The RTEMS 4.11 base defines.
+%include rtems-4.11-base.bset
+# Tools configuration.
+4.11/rtems-autotools
+devel/expat-2.1.0-1
+tools/rtems-binutils-2.24-1
+tools/rtems-gcc-4.8.2-newlib-2.1.0-1
+tools/rtems-gdb-7.7-1
+# or1k specific patches
+#binutils
+%patch add binutils -p1 https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/binutils-2.24-or1k-rtems.diff
+#newlib
+%patch add newlib -p1 https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/newlib-cvs-or1k-rtems-29-4-2014.diff
+#gcc
+%patch add gcc -p1 https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gcc-4.8.2-or1k-rtems-29-4-2014.diff
+#gdb
+%patch add gdb -p1 https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gdb-7.7-or1k-rtems.diff
+# or1k specific configurations
+#gdb
+%define gdb-disable-sim 1
diff --git a/source-builder/config/gdb-7-1.cfg b/source-builder/config/gdb-7-1.cfg
index 28f19b2..343bd04 100644
--- a/source-builder/config/gdb-7-1.cfg
+++ b/source-builder/config/gdb-7-1.cfg
@@ -4,6 +4,10 @@
# This configuration file configure's, make's and install's gdb.
+%if %{gdb-disable-sim} == %{nil}
+%define gdb-disable-sim 0
+%endif
%include %{_configdir}/checks.cfg
@@ -73,7 +77,7 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
--without-included-gettext \
--disable-win32-registry \
--disable-werror \
- --enable-sim \
+ %{!?gdb-disable-sim:--enable-sim}%{?gdb-disable-sim:--disable-sim} \
--without-zlib \
--with-expat \
%{!?without_python:--with-python} \
1.8.3.1
