[PATCH 05/12] bsp/altera-cyclone-v: Enable L2 cache for network driver
Tue May 27 14:55:00 UTC 2014
On Tue, May 27, 2014 at 10:45 AM, Ralf Kirchner
<ralf.kirchner at embedded-brains.de> wrote:
>  c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c |   15 ++++++++++++++-
>  1 Datei geändert, 14 Zeilen hinzugefügt(+), 1 Zeile entfernt(-)
> diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c b/c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c
> index d2f669a..d591e4e 100644
> --- a/c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c
> +++ b/c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c
> @@ -40,6 +40,7 @@
>  #include <bsp/alt_generalpurpose_io.h>
>  #include <bsp/nocache-heap.h>
>  #include "socal/alt_rstmgr.h"
> +#include "socal/alt_sysmgr.h"
>  #include "socal/hps.h"
>  #include "socal/socal.h"
>  #include <libchip/dwmac.h>
> @@ -1082,7 +1083,19 @@ static int network_if_bus_setup( void *arg )
>    (void) arg;
I think we usually put the (void) unused_arguments; after the
declarations of local variables.
> -  /* Nothing to be done */
> +  uint32_t reg = *((uint32_t*)ALT_SYSMGR_EMAC_L3MST_ADDR);
Is there not something like alt_read_word()?
> +  reg &= ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_CLR_MSK;
> +  reg &= ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_CLR_MSK;
> +  reg |= ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_SET(
> +    ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_ALLOC
> +  reg |= ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_SET(
> +    ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_ALLOC
> +  alt_write_word( ALT_SYSMGR_EMAC_L3MST_ADDR, reg );
>    return 0;
> 1.7.10.4
> rtems-devel mailing list
> rtems-devel at rtems.org
