Executing Thread Migrating Due to Affinity Change
Sebastian Huber
Fri May 30 13:33:55 UTC 2014
On 05/29/2014 09:28 PM, Joel Sherrill wrote:
> Hi
> The priority affinity algorithm appears to be behaving as
> we expect from a decision making standpoint. However,
> Jennifer and I think that when a scheduled thread must
> be migrated to another core, we have a case for a new
> state in the Thread Life Cycle.
I hope we can avoid this. Which problem do you want to address with
this new state?
> I am thinking that the thread needs to have a blocking state
> set, have its context saved and be taken out of the scheduled
> set. Then a life cycle state change handler van run as an
> extension to unblock it so it can be potentially scheduled to
> execute on another processor.
The scheduler is not responsible for the thread context. This is
_Thread_Dispatch(). A post-switch handler can only do actions for the
executing thread. It would be extremely difficult to perform actions on
behalf of another thread. We have to keep also fine grained locking
into account. The _Thread_Dispatch() function is on the critical path
for average and worst-case performance, so we should keep it as simple
as possible.
As I wrote already in another thread you can use something like this to
allocate an exact processor for a thread:
static inline void _Scheduler_SMP_Allocate_processor_exact(
Scheduler_SMP_Context *self,
Thread_Control *scheduled,
Thread_Control *victim
Scheduler_SMP_Node *scheduled_node = _Scheduler_SMP_Node_get(
scheduled );
Per_CPU_Control *cpu_of_scheduled = _Thread_Get_CPU( scheduled );
Per_CPU_Control *cpu_of_victim = _Thread_Get_CPU( victim );
Per_CPU_Control *cpu_self = _Per_CPU_Get();
_Scheduler_SMP_Node_change_state(
scheduled_node,
SCHEDULER_SMP_NODE_SCHEDULED
_Thread_Set_CPU( scheduled, cpu_of_victim );
_Scheduler_SMP_Update_heir( cpu_self, cpu_of_victim, scheduled );
You can even use this function to do things like this:
_Scheduler_SMP_Allocate_processor_exact(self, executing, other);
_Scheduler_SMP_Allocate_processor_exact(self, other, executing);
This works because the is executing indicator moved to the thread
context and is maintained at the lowest context switch level. For
proper migration the scheduler must ensure that,
1. an heir thread other than the migrating thread exists on the source
processor, and
2. the migrating thread is the heir thread on the destination processor.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
