raspberry pi and dl01
Tue Nov 4 20:58:57 UTC 2014
Hi
Looks like a weak symbol issue with the loader:
arm-rtems4.11-gcc -B../../../../../raspberrypi/lib/ -specs bsp_specs
-qrtems -mcpu=arm1176jzf-s -O2 -g -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
-mcpu=arm1176jzf-s   \
        -o dl01.exe init.o dl-load.o dl-tar.o dl-sym.o
../../../../../raspberrypi/lib/librtemsbsp.a(libbsp_a-irq.o): In
function `bsp_interrupt_handler_default':
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-arm-raspberrypi-rtems/arm-rtems4.11/c/raspberrypi/lib/libbsp/arm/raspberrypi/../../../../../../../../rtems/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c:116:
multiple definition of `bsp_interrupt_handler_default'
../../../../../raspberrypi/lib/librtemsbsp.a(libbsp_a-irq-default-handler.o):/users/joel/rtems-4.11-work/rtems-testing/rtems/build-arm-raspberrypi-rtems/arm-rtems4.11/c/raspberrypi/lib/libbsp/arm/raspberrypi/../../../../../../../../rtems/c/src/lib/libbsp/arm/raspberrypi/../../shared/src/irq-default-handler.c:20:
first defined here
collect2: error: ld returned 1 exit status
