Is there plan for stable 4.10.3 release branching?
Thu Nov 6 17:05:40 UTC 2014
On November 6, 2014 10:09:52 AM CST, Pavel Pisa <ppisa4lists at pikron.com> wrote:
>Hello Joel and others,
>the discussion to branch for 4.11 release
>has bring to my mind the 4.10 stable branch.
>The 4.10.2 release is dated to December 2011.
>There is significant amount of corrections
>and updates on in the GIT and last two commits
>are almost one year old so I would expect that
>the code base is quite stable. I have tested
>it more times on CSB336 and we have used it for
>RTEMS CAN benchmarks on MPC5200 as well.
>There are significant pile of fixes - i.e. shell commands
>for memory editing fixed, SD card support correction
>and other stuff after 4.10.2 release.
>So I think it would be usesfull to declare actual
>state as 4.10.3 release. It would help people
>interrested in RTEMS to have stable base for existing
>projects.
There haven't been any discussions about it but it makes sense to do one. We need to work through the release procedure with git and this will be good practice.
Also Chris has RSB support for 4.10 tools so he should also comment to make sure he thinks it is ready.
This will also be a good exercise for the new hosting.
>Best wishes,
>               Pavel
