rtems-tools: Fix libpath failed for rtems-ld
Peng Fan
van.freenix at gmail.com
Sat Nov 8 02:39:16 UTC 2014
Hi,
we should not clear input parameter 'se' in rld::split, otherwise paths
passed using '--lib-path' to rtems-ld will be cleared if standlibs are used.
Regards,
Peng.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141108/31533eae/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141108/31533eae/attachment.obj>
