On 8/11/2014 1:39 pm, Peng Fan wrote: > > we should not clear input parameter 'se' in rld::split, otherwise paths > passed using '--lib-path' to rtems-ld will be cleared if standlibs are used. > Thanks for this. I also have a patch for this in my repo. I will push it once git has been relocated and writes are enabled again. Chris
