BeagleBoneBlack how to enable UART1
Eduardo Sanchez
eduardo.sanchez at tallertechnologies.com
Wed Nov 12 12:52:15 UTC 2014
Hi,
The Beagle BSP from Ben Gras has only enabled the UART0 for console.
Since I need another available UART; I wrote the code and I successfully
enabled the UART1 (Rx pin: P9_26 and Tx pin: P9_24) for the Beaglebone
Black.
Attached you will find the patch code for this.
If you have any questions, please let me know.
Thanks and regards,
Eduardo.-
Eduardo Sanchez
Software Engineer
Taller Technologies Argentina
San Lorenzo 47, 3rd floor, Office 9
Cordoba, Argentina
Phone: +54 351 4217888 / +54 351 4218211
Skype: sanchez.taller
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141112/b8f43feb/attachment.html>
diff --git a/c/src/lib/libbsp/arm/beagle/console/console-config.c b/c/src/lib/libbsp/arm/beagle/console/console-config.c
index 63c7ba7..b773d76 100644
--- a/c/src/lib/libbsp/arm/beagle/console/console-config.c
+++ b/c/src/lib/libbsp/arm/beagle/console/console-config.c
@@ -32,37 +32,127 @@
#define CONSOLE_UART_THR (*(volatile unsigned int *)BSP_CONSOLE_UART_BASE)
#define CONSOLE_UART_RHR (*(volatile unsigned int *)BSP_CONSOLE_UART_BASE)
-#define CONSOLE_UART_LSR (*(volatile unsigned int *)(BSP_CONSOLE_UART_BASE+0x14))
-#define CONSOLE_SYSC (*(volatile uint32_t *) (BSP_CONSOLE_UART_BASE + 0x54))
-#define CONSOLE_SYSS (*(volatile uint32_t *) (BSP_CONSOLE_UART_BASE + 0x58))
+#define CONSOLE_SYSC (*(volatile uint32_t *) (BSP_CONSOLE_UART_BASE + BEAGLE_UART_SYSC))
+#define CONSOLE_SYSS (*(volatile uint32_t *) (BSP_CONSOLE_UART_BASE + BEAGLE_UART_SYSS))
#define TX_FIFO_E (1<<5)
#define RX_FIFO_E (1<<0)
-static uint8_t beagle_uart_get_register(uintptr_t addr, uint8_t i)
+static bool beagle_uart2_probe(int minor); /* Prototype for warning suppression */
+static uint8_t beagle_uart_get_register(uintptr_t addr, uint8_t offset)
- uint8_t v;
- volatile uint32_t *reg_r = (volatile uint32_t *) addr + i;
+ volatile uint32_t *reg = (volatile uint32_t *) addr;
- if(reg_r == (uint32_t*) BSP_CONSOLE_UART_BASE /* reading RHR */ ) {
- /* check there should be anything in the RHR before accessing it */
- if(!(CONSOLE_UART_LSR & 0x01)) {
- return 0;
+ return (uint8_t) reg [offset];
- v = (uint8_t) *reg_r;
+static void beagle_uart_set_register(uintptr_t addr, uint8_t offset, uint8_t val)
- return v;
+ reg [offset] = val;
-static void beagle_uart_set_register(uintptr_t addr, uint8_t i, uint8_t val)
+#if IS_AM335X
+ * @brief Enable clock for UART 2 module
+ * Use when enabling UART2 in BeagleBone Black.
+static void beagle_uart2_enable_module(void)
+ /* Enabling clock for UART2 Module */
+ /* Writing to MODULEMODE field of CM_PER_UART2_CLKCTRL register. */
+ REG(CM_PER_BASE + BEAGLE_CM_PER_UART2_CLKCTRL) |=
+ CM_MODULEMODE_ENABLE;
+ /* Waiting for MODULEMODE field to reflect the written value. */
+ while(CM_MODULEMODE_ENABLE !=
+ (REG(CM_PER_BASE + BEAGLE_CM_PER_UART2_CLKCTRL) &
+ CM_MODULEMODE_MASK));
+ * @brief Change GPIO pins to UART (Rx and Tx)
+static void beagle_uart2_pinmux(void)
+ /* Set pinmux for UART2 */
+ /* RXD Pin: select pull-up and set pin as rx active */
+ REG(BEAGLE_CONTROL_MODULE_BASE_REG + BEAGLE_CONF_UART2_RXD) =
+ (BEAGLE_CONF_UART2_RXD_PUTYPESEL |
+ BEAGLE_CONF_UART2_RXD_RXACTIVE);
+ /* TXD Pin: select pull-up */
+ REG(BEAGLE_CONTROL_MODULE_BASE_REG + BEAGLE_CONF_UART2_TXD) =
+ BEAGLE_CONF_UART2_TXD_PUTYPESEL;
+ * @brief Reset module
+static void beagle_uart2_reset_module(void)
+ /* Performing Software Reset of the module. */
+ REG(BEAGLE_BASE_UART_2 + BEAGLE_UART_SYSC) |= (BEAGLE_UART_SYSC_SOFTRESET);
+ /* Wait until the process of Module Reset is complete. */
+ while(!(REG(BEAGLE_BASE_UART_2 + BEAGLE_UART_SYSS) & BEAGLE_UART_SYSS_RESETDONE));
+ * @brief Switch operating mode to "UART16x"
+static void beagle_uart2_UART16x_operating_mode(void)
+ /* Clearing the MODESELECT field in MDR1. */
+ REG(BEAGLE_BASE_UART_2 + BEAGLE_UART_MDR1) &= ~(BEAGLE_UART_MDR1_MODE_SELECT);
+ /* Programming the MODESELECT field in MDR1. */
+ REG(BEAGLE_BASE_UART_2 + BEAGLE_UART_MDR1) |= (BEAGLE_UART16x_OPER_MODE & BEAGLE_UART_MDR1_MODE_SELECT);
+ * @brief Enable UART2 in BeagleBone Black.
+ * Enable clock, pin setup, reset module and set operating mode.
- volatile uint32_t *reg = (volatile uint32_t *) addr;
- reg [i] = val;
+ beagle_uart2_enable_module();
+ beagle_uart2_pinmux();
+ /* Reset UART Module */
+ beagle_uart2_reset_module();
+ /* Switch to UART16x operating mode. */
+ beagle_uart2_UART16x_operating_mode();
+ return true;
+#endif
console_tbl Console_Configuration_Ports [] = {
.sDeviceName = "/dev/ttyS0",
@@ -72,6 +162,7 @@ console_tbl Console_Configuration_Ports [] = {
#else
.pDeviceFns = &ns16550_fns,
#endif
+ .deviceProbe = NULL,
.ulMargin = 16,
.ulHysteresis = 8,
.pDeviceParams = (void *) CONSOLE_BAUD,
@@ -82,9 +173,35 @@ console_tbl Console_Configuration_Ports [] = {
.setRegister = beagle_uart_set_register,
.ulClock = UART_CLOCK, /* 48MHz base clock */
+#if IS_AM335X
+ .sDeviceName = "/dev/ttyS1",
+ .deviceType = SERIAL_NS16550,
+#if CONSOLE_POLLED /* option to facilitate running the tests */
+ .pDeviceFns = &ns16550_fns_polled,
+#else /* ELSE: UART will use Interrupts */
+ .pDeviceFns = &ns16550_fns,
+#endif
+ .deviceProbe = beagle_uart2_probe,
+ .ulMargin = 16,
+ .ulHysteresis = 8,
+ .pDeviceParams = (void *) CONSOLE_BAUD,
+ .ulCtrlPort1 = BEAGLE_BASE_UART_2,
+ .ulDataPort = BEAGLE_BASE_UART_2,
+ .ulIntVector = OMAP3_UART2_IRQ,
+ .getRegister = beagle_uart_get_register,
+ .setRegister = beagle_uart_set_register,
+ .ulClock = UART_CLOCK, /* 48MHz base clock */
+#endif
-unsigned long Console_Configuration_Count = 1;
+#define BEAGLE_UART_COUNT ( sizeof( Console_Configuration_Ports ) \
+ / sizeof( Console_Configuration_Ports[ 0 ] ) )
+unsigned long Console_Configuration_Count = BEAGLE_UART_COUNT;
static int init_needed = 1; // don't rely on bss being 0
diff --git a/c/src/lib/libbsp/arm/beagle/include/bsp.h b/c/src/lib/libbsp/arm/beagle/include/bsp.h
index e235efa..e839058 100644
--- a/c/src/lib/libbsp/arm/beagle/include/bsp.h
+++ b/c/src/lib/libbsp/arm/beagle/include/bsp.h
@@ -155,12 +155,26 @@ static inline void flush_data_cache(void)
/* per-target uart config */
#if IS_AM335X
-#define BSP_CONSOLE_UART 1
-#define BSP_CONSOLE_UART_BASE BEAGLE_BASE_UART_1
-#define BSP_CONSOLE_UART_IRQ OMAP3_UART1_IRQ
-#define BEAGLE_BASE_UART_1 0x44E09000
-#define BEAGLE_BASE_UART_2 0x48022000
-#define BEAGLE_BASE_UART_3 0x48024000
+#define BSP_CONSOLE_UART 1
+#define BSP_CONSOLE_UART_BASE BEAGLE_BASE_UART_1
+#define BSP_CONSOLE_UART_IRQ OMAP3_UART1_IRQ
+#define BEAGLE_BASE_UART_1 0x44E09000
+#define BEAGLE_BASE_UART_2 0x48022000
+#define BEAGLE_BASE_UART_3 0x48024000
+#define BEAGLE_UART_SYSS 0x58
+#define BEAGLE_UART_SYSC 0x54
+#define BEAGLE_UART_SYSC_SOFTRESET 0x00000002u
+#define BEAGLE_UART_SYSS_RESETDONE 0x00000001u
+#define BEAGLE_UART16x_OPER_MODE 0x0u
+#define BEAGLE_UART_MDR1 0x20
+#define BEAGLE_UART_MDR1_MODE_SELECT 0x00000007u
+#define BEAGLE_CM_PER_UART2_CLKCTRL 0x6c
+#define BEAGLE_CONTROL_MODULE_BASE_REG 0x44E10000
+#define BEAGLE_CONF_UART2_RXD 0x980
+#define BEAGLE_CONF_UART2_TXD 0x984
+#define BEAGLE_CONF_UART2_TXD_PUTYPESEL 0x00000010u
+#define BEAGLE_CONF_UART2_RXD_RXACTIVE 0x00000020u
+#define BEAGLE_CONF_UART2_RXD_PUTYPESEL 0x00000010u
#endif
