[PATCH] ARM removed shared/abort from several ARM BSPs
Alan Cudmore
alan.cudmore at gmail.com
Wed Nov 12 13:00:05 UTC 2014
c/src/lib/libbsp/arm/beagle/Makefile.am | 1 -
c/src/lib/libbsp/arm/gdbarmsim/Makefile.am | 2 -
c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 1 -
c/src/lib/libbsp/arm/shared/abort/abort.c | 29 +------------
c/src/lib/libbsp/arm/shared/abort/abort.h | 52 ++++++++++++++++++++++++
c/src/lib/libbsp/arm/shared/abort/simple_abort.c | 24 +----------
6 files changed, 55 insertions(+), 54 deletions(-)
create mode 100644 c/src/lib/libbsp/arm/shared/abort/abort.h
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index c6cf9e79..abef8ba 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -85,7 +85,6 @@ libbsp_a_SOURCES += ../../shared/src/stackalloc.c
libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
libbsp_a_SOURCES += ../../shared/timerstub.c
libbsp_a_SOURCES += ../../shared/cpucounterread.c
-libbsp_a_SOURCES += ../shared/abort/simple_abort.c
libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
libbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
index f13ad7d..3265494 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
+++ b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
@@ -45,8 +45,6 @@ libbsp_a_SOURCES += ../../shared/console-polled.c console/console-io.c
libbsp_a_SOURCES += ../../shared/clock_driver_simidle.c
# timer
-# above
-libbsp_a_SOURCES += ../shared/abort/abort.c
# start hooks
libbsp_a_SOURCES += startup/bspstarthooks.c
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index 839c8de..ed134fa 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -86,7 +86,6 @@ libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
libbsp_a_SOURCES += ../../shared/sbrk.c
libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
diff --git a/c/src/lib/libbsp/arm/shared/abort/abort.c b/c/src/lib/libbsp/arm/shared/abort/abort.c
index d509a2a..657b2f4 100644
--- a/c/src/lib/libbsp/arm/shared/abort/abort.c
+++ b/c/src/lib/libbsp/arm/shared/abort/abort.c
@@ -23,34 +23,7 @@
#include <rtems/bspIo.h>
-#define INSN_MASK 0xc5
-#define INSN_STM1 0x80
-#define INSN_STM2 0x84
-#define INSN_STR 0x40
-#define INSN_STRB 0x44
-#define INSN_LDM1 0x81
-#define INSN_LDM23 0x85
-#define INSN_LDR 0x41
-#define INSN_LDRB 0x45
-#define GET_RD(x) ((x & 0x0000f000) >> 12)
-#define GET_RN(x) ((x & 0x000f0000) >> 16)
-#define GET_U(x) ((x & 0x00800000) >> 23)
-#define GET_I(x) ((x & 0x02000000) >> 25)
-#define GET_REG(r, ctx) (((uint32_t *)ctx)[r])
-#define SET_REG(r, ctx, v) (((uint32_t *)ctx)[r] = v)
-#define GET_OFFSET(insn) (insn & 0xfff)
- * Prototypes
-void _print_full_context(uint32_t);
-void do_data_abort(uint32_t, uint32_t, Context_Control *);
+#include "abort.h"
uint32_t g_data_abort_cnt = 0;
/*this is a big overhead for MCU only got 16K RAM*/
diff --git a/c/src/lib/libbsp/arm/shared/abort/abort.h b/c/src/lib/libbsp/arm/shared/abort/abort.h
new file mode 100644
index 0000000..6d8704f
--- /dev/null
+++ b/c/src/lib/libbsp/arm/shared/abort/abort.h
@@ -0,0 +1,52 @@
+ * COPYRIGHT (c) 2007 Ray Xu.
+ * mailto: Rayx at gmail dot com
+ * COPYRIGHT (c) 2000 Canon Research Centre France SA.
+ * Emmanuel Raguet, mailto:raguet at crf.canon.fr
+ * Copyright (c) 2002 Advent Networks, Inc
+ * Jay Monkman <jmonkman at adventnetworks.com>
+#ifndef _BSPABORT_H
+#define _BSPABORT_H
+#include <rtems/system.h>
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#define INSN_MASK 0xc5
+#define INSN_STM1 0x80
+#define INSN_STM2 0x84
+#define INSN_STR 0x40
+#define INSN_STRB 0x44
+#define INSN_LDM1 0x81
+#define INSN_LDM23 0x85
+#define INSN_LDR 0x41
+#define INSN_LDRB 0x45
+#define GET_RD(x) ((x & 0x0000f000) >> 12)
+#define GET_RN(x) ((x & 0x000f0000) >> 16)
+#define GET_U(x) ((x & 0x00800000) >> 23)
+#define GET_I(x) ((x & 0x02000000) >> 25)
+#define GET_REG(r, ctx) (((uint32_t *)ctx)[r])
+#define SET_REG(r, ctx, v) (((uint32_t *)ctx)[r] = v)
+#define GET_OFFSET(insn) (insn & 0xfff)
+ * Prototypes
+void _print_full_context(uint32_t);
+void do_data_abort(uint32_t, uint32_t, Context_Control *);
+#endif /* _BSPABORT_H */
diff --git a/c/src/lib/libbsp/arm/shared/abort/simple_abort.c b/c/src/lib/libbsp/arm/shared/abort/simple_abort.c
index 51854bd..e721323 100644
--- a/c/src/lib/libbsp/arm/shared/abort/simple_abort.c
+++ b/c/src/lib/libbsp/arm/shared/abort/simple_abort.c
@@ -18,30 +18,10 @@
+#include "abort.h"
char *_print_full_context_mode2txt[0x10]={
[0x0]="user", /* User */
2.1.0
