[PATCH 5/6] i386/pc386/include: header files for VESA BIOS EXTENSIONS and VESA Extended Display Identification Data
Wed Nov 12 16:04:04 UTC 2014
Just a couple high-level comments:
Is this code entirely written by you?
If the code is i386-specific, I'd like to see it put into i386 namespace.
The use of bitfields worries me, especially if the code might be
ported to other architectures. I can see now why you put __packed__ on
all your structs, as it is necessary to get anywhere close to the
right behavior from the compiler when using bit fields.
-Gedare
On Wed, Nov 12, 2014 at 10:07 AM, Jan Dolezal <dolezj21 at fel.cvut.cz> wrote:
>  c/src/lib/libbsp/i386/pc386/Makefile.am    |   2 +
>  c/src/lib/libbsp/i386/pc386/include/edid.h | 759 +++++++++++++++++++++++++++++
>  c/src/lib/libbsp/i386/pc386/include/vbe3.h | 461 ++++++++++++++++++
>  c/src/lib/libbsp/i386/pc386/preinstall.am  |   8 +
>  4 files changed, 1230 insertions(+)
>  create mode 100644 c/src/lib/libbsp/i386/pc386/include/edid.h
>  create mode 100644 c/src/lib/libbsp/i386/pc386/include/vbe3.h
> diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am b/c/src/lib/libbsp/i386/pc386/Makefile.am
> index 6042b5b..2e60947 100644
> --- a/c/src/lib/libbsp/i386/pc386/Makefile.am
> +++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
> @@ -106,6 +106,8 @@ libbsp_a_SOURCES += console/printk_support.c
>  libbsp_a_SOURCES += console/vgacons.c
>  libbsp_a_SOURCES += console/exar17d15x.c
>  libbsp_a_SOURCES += console/rtd316.c
> +include_HEADERS += include/vbe3.h
> +include_HEADERS += include/edid.h
>  if USE_CIRRUS_GD5446
>  libbsp_a_SOURCES += console/fb_cirrus.c
>  else
> diff --git a/c/src/lib/libbsp/i386/pc386/include/edid.h b/c/src/lib/libbsp/i386/pc386/include/edid.h
> new file mode 100644
> index 0000000..937976e
> --- /dev/null
> +++ b/c/src/lib/libbsp/i386/pc386/include/edid.h
> @@ -0,0 +1,759 @@
> + * @file edid.h
> + * @ingroup i386_pc386
> + * @brief VESA EDID definitions.
> + * edid.h  - This file contains definitions for constants related to
> + *           VESA Extended Display Identification Data.
> + *          More information can be found at
> + *      <http://www.vesa.org/vesa-standards/free-standards/>
> + *          VESA public standards may be found at
> + *      <http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm>
> + * Copyright (C) 2014  Jan Doležal (dolezj21 at fel.cvut.cz)
> + *                     CTU in Prague.
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#ifndef _EDID_H
> +#define _EDID_H
> +#ifndef ASM /* ASM */
> +#include <stdint.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +/*  VESA Extended Display Identification Data (EDID) Standard
> +    Version 3, Revision Date: November 13, 1997 */
> +/*  VESA Enhanced Extended Display Identification Data (E-EDID) Standard
> +    Release A, Revision 2, September 25, 2006 */
> +/*  VESA Enhanced Extended Display Identification Data (E-EDID) Proposed
> +    Release A, March 27, 2007 */
> +/**** structs and defines shared by both EDIDv1 and EDIDv2 ****/
> +/* Video Input Definition */
> +/* Analog Interface Data Format - Signal Level Standard */
> +#define EDIDx_SLS_0700_0300_1000Vpp             0x0
> +#define EDIDx_SLS_0714_0286_1000Vpp             0x1
> +#define EDIDx_SLS_1000_0400_1400Vpp             0x2
> +#define EDIDx_SLS_0700_0000_0700Vpp             0x3
> +struct DetailedTimingDescriptor{
> +    uint16_t PixelClock_div10000;
> +    uint8_t HorizontalActiveLow;
> +    uint8_t HorizontalBlankingLow;
> +    uint8_t HorizontalBlankingHigh          : 4;
> +    uint8_t HorizontalActiveHigh            : 4;
> +    uint8_t VerticalActiveLow;
> +    uint8_t VerticalBlankingLow;
> +    uint8_t VerticalBlankingHigh            : 4;
> +    uint8_t VerticalActiveHigh              : 4;
> +    uint8_t HorizontalSyncOffsetLow;
> +    uint8_t HorizontalSyncPulseWidthLow;
> +    uint8_t VerticalSyncPulseWidthLow       : 4;
> +    uint8_t VerticalSyncOffsetLow           : 4;
> +    uint8_t VerticalSyncPulseWidthHigh      : 2;
> +    uint8_t VerticalSyncOffsetHigh          : 2;
> +    uint8_t HorizontalSyncPulseWidthHigh    : 2;
> +    uint8_t HorizontalSyncOffsetHigh        : 2;
> +    uint8_t HorizontalImageSizeLow;
> +    uint8_t VerticalImageSizeLow;
> +    uint8_t VerticalImageSizeHigh           : 4;
> +    uint8_t HorizontalImageSizeHigh         : 4;
> +    uint8_t HorizontalBorder;
> +    uint8_t VerticalBorder;
> +    uint8_t Flag_StereoMode0                : 1;
> +/* next four flags has different purpose with analog
> +   and digital interfaces for EDID version 2; first
> +   goes analog, after underscore there is digital name of bit */
> +    uint8_t Flag_SyncPolarity_LPPolarity    : 1;
> +    uint8_t Flag_Serration_FLMPolarity      : 1;
> +    uint8_t Flag_Composition_Serration      : 1;
> +    uint8_t Flag_Composition_ShiftClockUse  : 1;
> +    uint8_t Flag_StereoMode1                : 2;
> +    uint8_t Flag_Interlaced                 : 1;
> +}__attribute__((__packed__));
> +struct ColorPointData {
> +    uint8_t ColorPointWhitePointIndexNumber;
> +    uint8_t ColorPointWhiteLowBits;
> +    uint8_t ColorPointWhite_x;
> +    uint8_t ColorPointWhite_y;
> +    uint8_t ColorPointWhiteGamma;
> +/**** structs and defines for EDIDv1 ****/
> +/* Basic Display Parameters */
> +    /* Feature Support */
> +        /* analog - Display Color Type */
> +#define EDID_DisplayType_Monochrome         0
> +#define EDID_DisplayType_RGBcolor           1
> +#define EDID_DisplayType_nonRGBcolor        2
> +#define EDID_DisplayType_undef              3
> +        /* digital - Supported Color Encoding Formats */
> +#define EDID_DisplayType_RGB444                 0
> +#define EDID_DisplayType_RGB444YCrCb444         1
> +#define EDID_DisplayType_RGB444YCrCb422         2
> +#define EDID_DisplayType_RGB444YCrCb444YCrCb422 3
> +/* Monitor Descriptor - Data Type Tag */
> +#define EDID_DTT_MonitorSerialNumber        0xFF
> +#define EDID_DTT_ASCIIString                0xFE
> +#define EDID_DTT_MonitorRangeLimits         0xFD
> +struct MonitorRangeLimits {
> +    uint8_t MinVerticalRateInHz;
> +    uint8_t MaxVerticalRateInHz;
> +    uint8_t MinHorizontalInKHz;
> +    uint8_t MaxHorizontalInKHz;
> +    uint8_t MaxSupportedPixelClockIn10MHz;
> +/* see  VESA, Generalized Timing Formula Standard - GTF
> +        Version 1.0, December 18, 1996 */
> +    uint8_t GTFStandard[8];
> +#define EDID_DTT_MonitorName                0xFC
> +#define EDID_DTT_AdditionalColorPointData   0xFB
> +/* Standard Timing Identification */
> +#define EDID_DTT_AdditionalSTI              0xFA
> +#define EDID_DTT_DisplayColorManagement     0xF9
> +#define EDID_DTT_CVT3ByteTimingCodes        0xF8
> +#define EDID_CVT_AspectRatio_4_3            0
> +#define EDID_CVT_AspectRatio_16_9           1
> +#define EDID_CVT_AspectRatio_16_10          2
> +#define EDID_CVT_AspectRatio_15_9           3
> +#define EDID_CVT_PrefVertRate50Hz           0
> +#define EDID_CVT_PrefVertRate60Hz           1
> +#define EDID_CVT_PrefVertRate75Hz           2
> +#define EDID_CVT_PrefVertRate85Hz           3
> +struct CVT3ByteCodeDescriptor {
> +    uint8_t AddressableLinesLow;
> +    uint8_t Reserved0               : 2;
> +    uint8_t AspectRatio             : 2;
> +    uint8_t AddressableLinesHigh    : 4;
> +    /* next 5 bits indicate supported vertical rates */
> +    uint8_t VerticalRate60HzRB      : 1;
> +    uint8_t VerticalRate85Hz        : 1;
> +    uint8_t VerticalRate75Hz        : 1;
> +    uint8_t VerticalRate60Hz        : 1;
> +    uint8_t VerticalRate50Hz        : 1;
> +    uint8_t PreferredVerticalRate   : 2;
> +    uint8_t Reserved1               : 1;
> +struct CVTTimingCodes3B {
> +    uint8_t VersionNumber;
> +    struct CVT3ByteCodeDescriptor cvt[4];
> +#define EDID_DTT_EstablishedTimingsIII      0xF7
> +struct EstablishedTimingsIII {
> +    uint8_t RevisionNumber;
> +    uint8_t EST_1152x864_75Hz   : 1;
> +    uint8_t EST_1024x768_85Hz   : 1;
> +    uint8_t EST_800x600_85Hz    : 1;
> +    uint8_t EST_848x480_60Hz    : 1;
> +    uint8_t EST_640x480_85Hz    : 1;
> +    uint8_t EST_720x400_85Hz    : 1;
> +    uint8_t EST_640x400_85Hz    : 1;
> +    uint8_t EST_640x350_85Hz    : 1;
> +    uint8_t EST_1280x1024_85Hz  : 1;
> +    uint8_t EST_1280x1024_60Hz  : 1;
> +    uint8_t EST_1280x960_85Hz   : 1;
> +    uint8_t EST_1280x960_60Hz   : 1;
> +    uint8_t EST_1280x768_85Hz   : 1;
> +    uint8_t EST_1280x768_75Hz   : 1;
> +    uint8_t EST_1280x768_60Hz   : 1;
> +    uint8_t EST_1280x768_60HzRB : 1;
> +    uint8_t EST_1400x1050_75Hz  : 1;
> +    uint8_t EST_1400x1050_60Hz  : 1;
> +    uint8_t EST_1400x1050_60HzRB: 1;
> +    uint8_t EST_1400x900_85Hz   : 1;
> +    uint8_t EST_1400x900_75Hz   : 1;
> +    uint8_t EST_1400x900_60Hz   : 1;
> +    uint8_t EST_1400x900_60HzRB : 1;
> +    uint8_t EST_1360x768_60Hz   : 1;
> +    uint8_t EST_1600x1200_70Hz  : 1;
> +    uint8_t EST_1600x1200_65Hz  : 1;
> +    uint8_t EST_1600x1200_60Hz  : 1;
> +    uint8_t EST_1680x1050_85Hz  : 1;
> +    uint8_t EST_1680x1050_75Hz  : 1;
> +    uint8_t EST_1680x1050_60Hz  : 1;
> +    uint8_t EST_1680x1050_60HzRB: 1;
> +    uint8_t EST_1400x1050_85Hz  : 1;
> +    uint8_t EST_1920x1200_60Hz  : 1;
> +    uint8_t EST_1920x1200_60HzRB: 1;
> +    uint8_t EST_1856x1392_75Hz  : 1;
> +    uint8_t EST_1856x1392_60Hz  : 1;
> +    uint8_t EST_1792x1344_75Hz  : 1;
> +    uint8_t EST_1792x1344_60Hz  : 1;
> +    uint8_t EST_1600x1200_85Hz  : 1;
> +    uint8_t EST_1600x1200_75Hz  : 1;
> +    uint8_t EST_Reserved0       : 4;
> +    uint8_t EST_1920x1440_75Hz  : 1;
> +    uint8_t EST_1920x1440_60Hz  : 1;
> +    uint8_t EST_1920x1200_85Hz  : 1;
> +    uint8_t EST_1920x1200_75Hz  : 1;
> +    uint8_t EST_Reserved1[6];
> +#define EDID_DTT_DescriptorSpaceUnused      0x10
> +/* DTT 0x0 - 0xF are manufacturer specific */
> +struct MonitorDescriptor {
> +    uint16_t Flag0;
> +    uint8_t Flag1;
> +    uint8_t DataTypeTag;
> +    uint8_t Flag2;
> +    uint8_t DescriptorData[13];
> +union DTD_MD {
> +    struct DetailedTimingDescriptor dtd;
> +    struct MonitorDescriptor md;
> +#define EDID_STI_DescriptorUnused           0x0101
> +#define EDID_STI_AspectRatio_16_10          0
> +#define EDID_STI_AspectRatio_4_3            1
> +#define EDID_STI_AspectRatio_5_4            2
> +#define EDID_STI_AspectRatio_16_9           3
> +struct StandardTimingIdentification {
> +    uint8_t HorizontalActivePixels;
> +    uint8_t ImageAspectRatio    : 2;
> +    uint8_t RefreshRate         : 6;
> +struct VID_Analog {
> +    uint8_t SerationOnVerticalSync  : 1;
> +    uint8_t SyncSignalOnGreen       : 1;
> +    uint8_t SyncSignalOnHorizontal  : 1;
> +    uint8_t SeparateSyncHandVSignals: 1;
> +    uint8_t VideoSetupBlank         : 1;
> +    uint8_t SignalLevelStandard     : 2;
> +    uint8_t DigitalSignalLevel      : 1; /* Analog = 0, Digital = 1*/
> +struct VID_Digital {
> +    uint8_t DigitalVideoStandardSupp: 4;
> +    uint8_t ColorBitDepth           : 3;
> +/* Color Bit Depths */
> +#define CBD_undef               0x0
> +#define CBD_6bPerPrimaryColor   0x1
> +#define CBD_8bPerPrimaryColor   0x2
> +#define CBD_10bPerPrimaryColor  0x3
> +#define CBD_12bPerPrimaryColor  0x4
> +#define CBD_14bPerPrimaryColor  0x5
> +#define CBD_16bPerPrimaryColor  0x6
> +#define CBD_reserved            0x7
> +/* Digital Video Standard Supported */
> +#define DVS_undef               0x0
> +#define DVS_DVI                 0x1
> +#define DVS_HDMI-a              0x2
> +#define DVS_HDMI-b              0x3
> +#define DVS_MDDI                0x4
> +#define DVS_DiplayPort          0x5
> +union VideoInputDefinition {
> +    struct VID_Analog analog;
> +    struct VID_Digital digital;
> +struct edid1{
> +    uint8_t Header[8];
> +/*  Vendor Product Identification */
> +    uint16_t IDManufacturerName;
> +    uint16_t IDProductCode;
> +    uint32_t IDSerialNumber;
> +    uint8_t WeekofManufacture;
> +    uint8_t YearofManufacture;
> +/*  EDID Structure Version Revision Level */
> +    uint8_t Version;
> +    uint8_t Revision;
> +/*  Basic Display Parameters Features */
> +    /* Video Input Definition */
> +    union VideoInputDefinition vid;
> +    uint8_t MaxHorizontalImageSize;
> +    uint8_t MaxVerticalImageSize;
> +    uint8_t DisplayTransferCharacteristic;
> +    uint8_t Feature_GTFSupported                : 1;
> +    uint8_t Feature_PreferredTimingMode         : 1;
> +    uint8_t Feature_StandardDefaultColorSpace   : 1;
> +    uint8_t Feature_DisplayType                 : 2;
> +        /* Refer to VESA DPMS Specification */
> +    uint8_t Feature_ActiveOff                   : 1;
> +    uint8_t Feature_Suspend                     : 1;
> +    uint8_t Feature_StandBy                     : 1;
> +/*  Color Characteristics */
> +    uint8_t GreenYLow   : 2;
> +    uint8_t GreenXLow   : 2;
> +    uint8_t RedYLow     : 2;
> +    uint8_t RedXLow     : 2;
> +    uint8_t WhiteYLow   : 2;
> +    uint8_t WhiteXLow   : 2;
> +    uint8_t BlueYLow    : 2;
> +    uint8_t BlueXLow    : 2;
> +    uint8_t RedXHigh;
> +    uint8_t RedYHigh;
> +    uint8_t GreenXHigh;
> +    uint8_t GreenYHigh;
> +    uint8_t BlueXHigh;
> +    uint8_t BlueYHigh;
> +    uint8_t WhiteXHigh;
> +    uint8_t WhiteYHigh;
> +/*  Established Timings I */
> +    uint8_t EST_800x600_60Hz    : 1;
> +    uint8_t EST_800x600_56Hz    : 1;
> +    uint8_t EST_640x480_75Hz    : 1;
> +    uint8_t EST_640x480_72Hz    : 1;
> +    uint8_t EST_640x480_67Hz    : 1;
> +    uint8_t EST_640x480_60Hz    : 1;
> +    uint8_t EST_720x400_88Hz    : 1;
> +    uint8_t EST_720x400_70Hz    : 1;
> +/*  Established Timings II */
> +    uint8_t EST_1280x1024_75Hz  : 1;
> +    uint8_t EST_1024x768_75Hz   : 1;
> +    uint8_t EST_1024x768_70Hz   : 1;
> +    uint8_t EST_1024x768_60Hz   : 1;
> +    uint8_t EST_1024x768_87Hz   : 1;
> +    uint8_t EST_832x624_75Hz    : 1;
> +    uint8_t EST_800x600_75Hz    : 1;
> +    uint8_t EST_800x600_72Hz    : 1;
> +/*  Manufacturer's Timings */
> +    uint8_t EST_Reserved        : 7;
> +    uint8_t EST_1152x870_75Hz   : 1;
> +    struct StandardTimingIdentification STI[8];
> +/*  Detailed Timing Descriptions / Monitor Descriptions */
> +    union DTD_MD dtd_md[4];
> +    uint8_t ExtensionFlag;
> +    uint8_t Checksum;
> +/**** structs and defines for EDIDv2 ****/
> +struct EDID2_AnalogInterfaceDataFormatDescription{
> +    uint8_t SyncInputsSupported0            : 1;
> +    uint8_t SyncInputsSupported1            : 1;
> +    uint8_t SyncInputsSupported2            : 1;
> +    uint8_t SyncInputsSupported3            : 1;
> +    uint8_t Setup                           : 1;
> +    uint8_t Reserved0                       : 1;
> +    uint8_t Reserved1                       : 7;
> +    uint8_t PixelClockSupported             : 1;
> +    uint8_t Reserved2;
> +    uint8_t Reserved3;
> +struct EDID2_DigitalInterfaceDataFormatDescription{
> +    uint8_t ChannelSpeedExponent    : 4;
> +    uint8_t NumberOfReceiverUnits   : 2;
> +    uint8_t EdgeOfShiftClockUsed    : 1;
> +    uint8_t DisplayEnablePolarity   : 1;
> +    uint8_t MinimumChannelSpeed;
> +    uint8_t MaximumChannelSpeed;
> +    uint8_t DigitalInterfaceDataFormat;
> +union EDID2_InterfaceDataFormatDescription{
> +    struct EDID2_AnalogInterfaceDataFormatDescription analog;
> +    struct EDID2_DigitalInterfaceDataFormatDescription digital;
> +struct edid2{
> +/*  EDID Structure Version/Revision */
> +    uint8_t Revision : 4;
> +    uint8_t Version : 4;
> +/*  Vendor / Product Identification */
> +    uint8_t WeekOfManufacture;
> +    uint16_t YearOfManufacture;
> +/*  Manufacturer/Product Name String */
> +    char ManufacturerProductIDstring[32];
> +/*  Serial Number String */
> +    char SerialNumberString[16];
> +/*  Unused (Reserved) */
> +    uint8_t Unused0[8];
> +/*  Display Interface Parameters */
> +    /* Physical Connector Type */
> +    uint8_t PhysicalInterfaceSecondary  : 4; /* see Physical Connector Types */
> +    uint8_t PhysicalInterfaceDefault    : 4; /* see Physical Connector Types */
> +    uint8_t VideoInterfaceTypeSecondary     : 4;
> +    uint8_t VideoInterfaceTypeDefault       : 4;
> +    union EDID2_InterfaceDataFormatDescription IDFDefault;
> +    union EDID2_InterfaceDataFormatDescription IDFSecondary;
> +    /* Interface Color Luminance Encoding */
> +    uint8_t CLE_ColorencodingSecondary      : 4;
> +    uint8_t CLE_ColorencodingDefault        : 4;
> +        /* SC - sub-channel; 0 - red, 1 - green, 2 - blue */
> +    uint8_t CLE_supportedBitDepthSC1Default     : 4;
> +    uint8_t CLE_supportedBitDepthSC0Default     : 4;
> +    uint8_t CLE_supportedBitDepthSC3Default     : 4;
> +    uint8_t CLE_supportedBitDepthSC2Default     : 4;
> +    uint8_t CLE_supportedBitDepthSC1Secondary   : 4;
> +    uint8_t CLE_supportedBitDepthSC0Secondary   : 4;
> +    uint8_t CLE_supportedBitDepthSC3Secondary   : 4;
> +    uint8_t CLE_supportedBitDepthSC2Secondary   : 4;
> +/*  Display Device Description */
> +    uint8_t DisplayTechnologySubtype        : 4;
> +    uint8_t DisplayTechnologyType           : 4;
> +    /* Major Display Characteristics */
> +    uint8_t MDC_PhysicalImplementation      : 2;
> +    uint8_t MDC_DisplayBackground           : 1;
> +    uint8_t MDC_ScanOrientation             : 2;
> +    uint8_t MDC_Conditionalupdate           : 1;
> +    uint8_t MDC_SelectableDisplayChromacity : 1;
> +    uint8_t MDC_Color                       : 1;
> +    /* Features */
> +    uint8_t Features_Reserved0              : 1;
> +    uint8_t Features_StereoSupport          : 3;
> +    uint8_t Features_Off                    : 1;
> +    uint8_t Features_ActiveOff              : 1;
> +    uint8_t Features_Suspend                : 1;
> +    uint8_t Features_StandBy                : 1;
> +    uint8_t Features_VideoInput             : 2;
> +    uint8_t Features_AudioOutputInterface   : 2;
> +    uint8_t Features_AudioOutput            : 1;
> +    uint8_t Features_AudioInputInterface    : 2;
> +    uint8_t Features_AudioInput             : 1;
> +    uint8_t Features_Reserved1              : 3;
> +    uint8_t Features_AdjustableOrientation  : 1;
> +    uint8_t Features_Colorimeter            : 1;
> +    uint8_t Features_LuminanceProbe         : 1;
> +    uint8_t Features_LightPen               : 1;
> +    uint8_t Features_TouchScreen            : 1;
> +/*  Display Response Time; Seconds - Range 0-15 * 10^(-n), n=timeexp */
> +    uint8_t DRT_RiseTimeResponseInSeconds   : 4;
> +    uint8_t DRT_RiseTimeExponent            : 4;
> +    uint8_t DRT_FallTimeResponseInSeconds   : 4;
> +    uint8_t DRT_FallTimeExponent            : 4;
> +/*  Color Luminance Description */
> +    uint8_t DisplayTransferCharacteristic_WhiteGamma;
> +    uint8_t DisplayTransferCharacteristic_Color0Gamma;
> +    uint8_t DisplayTransferCharacteristic_Color1Gamma;
> +    uint8_t DisplayTransferCharacteristic_Color2Gamma;
> +    uint16_t MaximumLuminanceWhite;
> +    uint8_t LuminanceFlag_OffsetSignBit     : 1;
> +    uint8_t LuminanceFlags_Reserved         : 5;
> +    uint8_t LuminanceFlag_AdjustableGamma   : 1;
> +    uint8_t LuminanceFlag_StandardRGBmodel  : 1;
> +    uint8_t LuminanceOffset;
> +    /* Chromacity and Default White Point Coordinates */
> +    uint8_t ColorCharacteristicsGreenYLow   : 2;
> +    uint8_t ColorCharacteristicsGreenXLow   : 2;
> +    uint8_t ColorCharacteristicsRedYLow     : 2;
> +    uint8_t ColorCharacteristicsRedXLow     : 2;
> +    uint8_t ColorCharacteristicsWhiteYLow   : 2;
> +    uint8_t ColorCharacteristicsWhiteXLow   : 2;
> +    uint8_t ColorCharacteristicsBlueYLow    : 2;
> +    uint8_t ColorCharacteristicsBlueXLow    : 2;
> +    uint8_t ColorCharacteristicsRedXHigh;
> +    uint8_t ColorCharacteristicsRedYHigh;
> +    uint8_t ColorCharacteristicsGreenXHigh;
> +    uint8_t ColorCharacteristicsGreenYHigh;
> +    uint8_t ColorCharacteristicsBlueXHigh;
> +    uint8_t ColorCharacteristicsBlueYHigh;
> +    uint8_t ColorCharacteristicsWhiteXHigh;
> +    uint8_t ColorCharacteristicsWhiteYHigh;
> +    /* Additional White Points And Gamma */
> +    struct ColorPointData cpd[2];
> +/*  Display Spatial Description */
> +    uint16_t MaxHorizontalImageSize;
> +    uint16_t MaxVerticalImageSize;
> +    uint16_t MaxHorizontalAddressibility;
> +    uint16_t MaxVerticalAddressibility;
> +    uint8_t HorizontalPixelPitch;
> +    uint8_t VerticalPixelPitch;
> +    uint8_t Unused1;
> +/*  GTF Support Information */
> +    uint8_t GTFSupportInformationSecond : 4;
> +    uint8_t GTFSupportInformation       : 4;
> +/*  Map Of Timing Information */
> +    uint8_t MTI_NumberOfDetailedRangeLimitsListed   : 2;
> +    uint8_t MTI_NumberOfFrequencyRangesListed       : 3;
> +    uint8_t MTI_LuminanceTableProvided              : 1;
> +    uint8_t MTI_PreferredTimingMode                 : 1;
> +    uint8_t MTI_ExtensionFlag                       : 1;
> +    uint8_t MTI_NumberOfDetailedTimingDescriptions  : 3;
> +    uint8_t MTI_NumberOf4byteTimingCodesListed      : 5;
> +/* 80h  Luminance Table Timing Descriptions */
> +    uint8_t LuminanceTableTimingDescriptions[0x7F];
> +/*  x*A Luminance Table */
> +/*  8*B Range Limits */
> +/* 27*C 27-Byte Detailed Range Limits */
> +/*  4*D 4-Byte Timing Codes */
> +/* 18*E 18-Byte Detailed Timing Descriptions */
> +/* zeros up to FEh */
> +    uint8_t Checksum;
> +/* Luminance Table */
> +struct LuminanceTable {
> +    uint8_t NumberOfLuminanceEntries        : 5; /* n */
> +    uint8_t Reserved                        : 2;
> +    uint8_t SeparateSubChannels             : 1; /* s */
> +    uint8_t LuminanceValues; /* if s==0 there are n else 3*n bytes here */
> +/* Range Limits */
> +struct DisplayTimingRangeLimits {
> +    uint8_t MinFrameFieldRateInHzHigh;
> +    uint8_t MaxFrameFieldRateInHzHigh;
> +    uint8_t MinLineRateInkHzHigh;
> +    uint8_t MaxLineRateInkHzHigh;
> +    uint8_t MaxLineRateInkHzLow             : 2;
> +    uint8_t MinLineRateInkHzLow             : 2;
> +    uint8_t MaxFrameFieldRateInHzLow        : 2;
> +    uint8_t MinFrameFieldRateInHzLow        : 2;
> +    uint8_t MinPixelRateInMHzLow;
> +    uint8_t MaxPixelRateInMHzLow;
> +    uint8_t MaxPixelRateInMHzHigh           : 4;
> +    uint8_t MinPixelRateInMHzHigh           : 4;
> +/* 27-Byte Detailed Range Limits */
> +struct DetailedTimingRangeFormat27B {
> +    uint16_t MinPixelClock_div10000;
> +    uint8_t MinHorizontalBlankingLow;
> +    uint8_t MinVerticalBlankingLow;
> +    uint8_t MinVerticalBlankingHigh         : 4;
> +    uint8_t MinHorizontalBlankingHigh       : 4;
> +    uint8_t MinHorizontalSyncOffsetLow;
> +    uint8_t MinHorizontalSyncPulseWidthLow;
> +    uint8_t MinVerticalSyncPulseWidthLow    : 4;
> +    uint8_t MinVerticalSyncOffsetLow        : 4;
> +    uint8_t MinVerticalSyncPulseWidthHigh   : 2;
> +    uint8_t MinVerticalSyncOffsetHigh       : 2;
> +    uint8_t MinHorizontalSyncPulseWidthHigh : 2;
> +    uint8_t MinHorizontalSyncOffsetHigh     : 2;
> +    uint16_t MaxPixelClock_div10000;
> +    uint8_t MaxHorizontalBlankingLow;
> +    uint8_t MaxVerticalBlankingLow;
> +    uint8_t MaxVerticalBlankingHigh         : 4;
> +    uint8_t MaxHorizontalBlankingHigh       : 4;
> +    uint8_t MaxHorizontalSyncOffsetLow;
> +    uint8_t MaxHorizontalSyncPulseWidthLow;
> +    uint8_t MaxVerticalSyncPulseWidthLow    : 4;
> +    uint8_t MaxVerticalSyncOffsetLow        : 4;
> +    uint8_t MaxVerticalSyncPulseWidthHigh   : 2;
> +    uint8_t MaxVerticalSyncOffsetHigh       : 2;
> +    uint8_t MaxHorizontalSyncPulseWidthHigh : 2;
> +    uint8_t MaxHorizontalSyncOffsetHigh     : 2;
> +    uint8_t Flags_Set0                      : 1;
> +    /* Next four bits are specified for digital interfaces.
> +    Meaning for analog interfaces shall be found
> +    in the document mentioned above. */
> +    uint8_t Flags_LPPolarity                : 1;
> +    uint8_t Flags_FLMPolarity               : 1;
> +    uint8_t Flags_Reserved                  : 1;
> +    uint8_t Flags_ShiftClockUse             : 1;
> +    uint8_t Flags_Set1                      : 2;
> +    uint8_t Flags_Interlaced                : 1;
> +/* 4-Byte Timing Codes */
> +struct TimingCodeFormat4B {
> +    uint8_t ActivePixelsPerLine;
> +    uint8_t Reserved                        : 1;
> +    uint8_t SHFTCLKedgesUsed                : 1;
> +    uint8_t FLMPolarity                     : 1;
> +    uint8_t LPPolarity                      : 1;
> +    uint8_t Portrait                        : 1;
> +    uint8_t Stereo                          : 1;
> +    uint8_t InterlacedTiming                : 1;
> +    uint8_t ReducedBlanking                 : 1;
> +    uint8_t FormatAspectRatio;
> +    uint8_t RefreshRate;
> +/* 18-Byte Detailed Timing Descriptions */
> +    /* see struct DetailedTimingDescriptor */
> +/* Physical Connector Types (Default/SecondaryPhysicalInterface) */
> +#define EDID2_PCT_None                          0x0
> +#define EDID2_PCT_BNC                           0x1
> +#define EDID2_PCT_15pinVGA                      0x2
> +#define EDID2_PCT_13w3                          0x3
> +#define EDID2_PCT_VESAEVC                       0x4
> +#define EDID2_PCT_VESAPDD                       0x5
> +#define EDID2_PCT_Microribbon                   0x6
> +#define EDID2_PCT_IEEE1394                      0x7
> +#define EDID2_PCT_VESAFPDI2                     0x8
> +/* Reserved 0x9-0xE */
> +#define EDID2_PCT_Nonstandard                   0xF
> +/* Video Interface Type */
> +#define EDID2_VIT_None                          0x0
> +#define EDID2_VIT_Analog                        0x1
> +#define EDID2_VIT_Analogwsampledpixelclock      0x2
> +    /* Transition Minimized Differential Signaling */
> +#define EDID2_VIT_TMDS                          0x3
> +#define EDID2_VIT_IEEE1394_1995                 0x4
> +#define EDID2_VIT_LVDS                          0x5
> +#define EDID2_VIT_Parallel                      0x6
> +/* Reserved 0x7-0xF */
> +/* digital interface data format */
> +#define EDID2_didf_RGB_STN-DD_8BitOver8Bit      0x15
> +#define EDID2_didf_RGB_STN-DD_12BitOver12Bit    0x19
> +#define EDID2_didf_MSBAlignedRGBTFT24Bit        0x24
> +/* Color/Luminance Encoding Description */
> +        /* nibbles of byte 0 - color encodings */
> +#define EDID2_CLE_CE_Monochrome                 0x0
> +#define EDID2_CLE_CE_RGBadd                     0x1
> +#define EDID2_CLE_CE_CMYsub                     0x2
> +#define EDID2_CLE_CE_CMYKsub                    0x3
> +#define EDID2_CLE_CE_YC_NTSC                    0x4
> +#define EDID2_CLE_CE_YC_PAL                     0x5
> +#define EDID2_CLE_CE_YC_SECAM                   0x6
> +#define EDID2_CLE_CE_YIQ_NTSC                   0x7
> +#define EDID2_CLE_CE_YIQ_PAL                    0x8
> +#define EDID2_CLE_CE_YIQ_SECAM                  0x9
> +#define EDID2_CLE_CE_YCrCb                      0xA
> +#define EDID2_CLE_CE_YPrPb                      0xB
> +#define EDID2_CLE_CE_XYZ                        0xC
> +#define EDID2_CLE_CE_CIELuv                     0xD
> +#define EDID2_CLE_CE_CIELab                     0xE
> +#define EDID2_CLE_CE_Digital_ATSC               0xF
> +/* Display Device Description; T-type, ST-subtype */
> +#define EDID2_DDD_T_CRT         0x0 /* Cathode Ray Tube */
> +#define EDID2_DDD_ST_CRT_Monochrome             0x0
> +#define EDID2_DDD_ST_CRT_ShadowmaskColor        0x1
> +#define EDID2_DDD_ST_CRT_BeamIndexColor         0x2
> +#define EDID2_DDD_ST_CRT_BeamPenetrationColor   0x3
> +#define EDID2_DDD_T_LCD         0x1 /* Liquid Crystal Display */
> +#define EDID2_DDD_ST_LCD_STN                    0x0
> +#define EDID2_DDD_ST_LCD_DSTN                   0x1
> +#define EDID2_DDD_ST_LCD_FLCD                   0x2
> +#define EDID2_DDD_ST_LCD_TFTconv                0x3
> +#define EDID2_DDD_ST_LCD_TFTinplaneswtch        0x4
> +#define EDID2_DDD_ST_LCD_PDLCD                  0x5
> +#define EDID2_DDD_ST_LCD_PSCLCD                 0x6
> +#define EDID2_DDD_ST_LCD_PALCD                  0x7
> +#define EDID2_DDD_T_EL          0x2 /* Electroluminiscent Displ */
> +#define EDID2_DDD_ST_EL_ACThin                  0x0
> +#define EDID2_DDD_ST_EL_ACThick                 0x1
> +#define EDID2_DDD_ST_EL_DCThin                  0x2
> +#define EDID2_DDD_ST_EL_DCThick                 0x3
> +#define EDID2_DDD_T_PDP         0x3 /* Plasma Display Panel */
> +#define EDID2_DDD_ST_PDP_AC                     0x0
> +#define EDID2_DDD_ST_PDP_DC                     0x1
> +#define EDID2_DDD_T_FED         0x4 /* Field Emission Displays */
> +#define EDID2_DDD_ST_FED_TBD                    0x0
> +#define EDID2_DDD_T_LED         0x5 /* Light Emitting Diode */
> +#define EDID2_DDD_ST_LED_TBD                    0x0
> +#define EDID2_DDD_T_IRD         0x6 /* Integrated Reflective Display */
> +#define EDID2_DDD_ST_IRD_1Chip                  0x0
> +#define EDID2_DDD_ST_IRD_2Chip                  0x1
> +#define EDID2_DDD_ST_IRD_3Chip                  0x2
> +    /* Types 0x7-0xF Reserved */
> +/* MajorDisplayCharacteristics */
> +#define EDID2_MDC_C_Color               1
> +#define EDID2_MDC_C_Mono                0
> +#define EDID2_MDC_SO_notscanned         0x0
> +#define EDID2_MDC_SO_fastLRslowTB       0x1
> +#define EDID2_MDC_SO_fastTBslowLR       0x2
> +#define EDID2_MDC_SO_fastTBslowRL       0x3
> +#define EDID2_MDC_DB_NonTransp          0
> +#define EDID2_MDC_DB_Transparent        1
> +#define EDID2_MDC_PI_Large              0x0
> +#define EDID2_MDC_PI_Desktop            0x1
> +#define EDID2_MDC_PI_Eyepiece           0x2
> +/* FeaturesSupport */
> +        /* byte 0 - refer to VESA DPMS specification */
> +            /* Stereo Support */
> +#define EDID2_FS_SS_nodirectstereo      0x0
> +#define EDID2_FS_SS_fieldseqstereo      0x1
> +#define EDID2_FS_SS_directviewcolumnilv 0x2
> +#define EDID2_FS_SS_directviewlineilv   0x3
> +        /* byte 1 */
> +            /* VideoInputValues */
> +#define EDID2_FX_VI_None                0x0
> +#define EDID2_FX_VI_AnalogYCconnEVC     0x1
> +#define EDID2_FX_VI_USBCam              0x2
> +#define EDID2_FX_VI_IEEE1394Cam         0x3
> +            /* AudioOutputInterfaceValues */
> +#define EDID2_FS_AOI_None               0x0
> +#define EDID2_FS_AOI_Analog             0x1
> +#define EDID2_FS_AOI_USB                0x2
> +#define EDID2_FS_AOI_IEEE1394           0x3
> +            /* Audio Input Interface Values */
> +#define EDID2_FS_AII_None               0x0
> +#define EDID2_FS_AII_Analog             0x1
> +#define EDID2_FS_AII_USB                0x2
> +#define EDID2_FS_AII_IEEE1394           0x3
> +/* GTFSupportInformation values */
> +#define EDID2_GTFSI_nosupport       0x0
> +#define EDID2_GTFSI_stdCRTparams    0x1
> +#define EDID2_GTFSI_defaultTBD      0x2
> +#define EDID2_GTFSI_custom          0xF
> +union edid {
> +    struct edid1 edid1;
> +    struct edid2 edid2;
> +#ifdef __cplusplus
> +#endif /* ASM */
> +#endif /* _VBE_H */
> diff --git a/c/src/lib/libbsp/i386/pc386/include/vbe3.h b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
> index 0000000..152d552
> --- /dev/null
> +++ b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
> @@ -0,0 +1,461 @@
> + * @file vbe3.h
> + * @brief VESA Bios Extension definitions.
> + * vbe3.h  - This file contains definitions for constants related to VBE.
> + *                     CTU in Prague.
> +#ifndef _VBE_H
> +#define _VBE_H
> +#ifdef __cplusplus
> +extern "C" {
> +/*  VESA BIOS EXTENSION (VBE) Core functions Standard
> +    Version: 3.0 Date: September 16, 1998               */
> +/* VBE RETURN STATUS */
> +/* AL == 4Fh: Function is supported */
> +/* AL != 4Fh: Function is not supported */
> +#define VBE_functionSupported        0x4F
> +/* AH == 00h: Function call successful */
> +#define VBE_callSuccessful           0x00
> +/* AH == 01h: Function call failed */
> +#define VBE_callFailed               0x01
> +/* AH == 02h: Function is not supported in the current hardware configuration */
> +#define VBE_notSupportedInCurHWConf  0x02
> +/* AH == 03h: Function call invalid in current video mode */
> +#define VBE_callInvalid              0x03
> +/* VBE Mode Numbers */
> +/* D0-D8 =  Mode number */
> +#define VBE_modeNumberMask         0x01FF
> +#define VBE_modeNumberShift          0x00
> +/* If D8 == 0, this is not a VESA defined VBE mode */
> +#define VBE_VESAmodeMask           0x0100
> +/* If D8 == 1, this is a VESA defined VBE mode */
> +/* D9-D12 =  Reserved by VESA for future expansion (= 0) */
> +#define VBE_VESAmodeShift            0x08
> +/* If D11 == 0, Use current BIOS default refresh rate */
> +#define VBE_refreshRateCtrlMask    0x0800
> +/* If D11 == 1, Use user specified CRTC values for refresh rate */
> +/* D12-13 = Reserved for VBE/AF (must be 0) */
> +#define VBE_refreshRateCtrlShift     0x0B
> +/* If D14 == 0, Use Banked/Windowed Frame Buffer */
> +#define VBE_linearFlatFrameBufMask 0x4000
> +/* If D14 == 1, Use Linear/Flat Frame Buffer */
> +#define VBE_linearFlatFrameBufShift  0x0E
> +/* If D15 == 0, Clear display memory */
> +#define VBE_preserveDispMemMask    0x8000
> +/* If D15 == 1, Preserve display memory */
> +#define VBE_preserveDispMemShift     0x0F
> +/* Graphics modes */
> +/* 15-bit mode, Resolution: 640x400,   Colors: 256  */
> +#define VBE_R640x400C256      0x100
> +/* 15-bit mode, Resolution: 640x480,   Colors: 256  */
> +#define VBE_R640x480C256      0x101
> +/* 15-bit mode, Resolution: 800x600,   Colors: 16   */
> +#define VBE_R800x600C16       0x102
> +/* 7-bit mode,  Resolution: 800x600,   Colors: 16   */
> +#define VBE_b7R800x600C16     0x6A
> +/* 15-bit mode, Resolution: 800x600,   Colors: 256  */
> +#define VBE_R800x600C256      0x103
> +/* 15-bit mode, Resolution: 1024x768,  Colors: 16   */
> +#define VBE_R1024x768C16      0x104
> +/* 15-bit mode, Resolution: 1024x768,  Colors: 256  */
> +#define VBE_R1024x768C256     0x105
> +/* 15-bit mode, Resolution: 1280x1024, Colors: 16   */
> +#define VBE_R1280x1024C16     0x106
> +/* 15-bit mode, Resolution: 1280x1024, Colors: 256  */
> +#define VBE_R1280x1024C256    0x107
> +/* 15-bit mode, Resolution: 320x200,   Colors: 32K   (1:5:5:5) */
> +#define VBE_R320x200C32K      0x10D
> +/* 15-bit mode, Resolution: 320x200,   Colors: 64K   (5:6:5)   */
> +#define VBE_R320x200C64K      0x10E
> +/* 15-bit mode, Resolution: 320x200,   Colors: 16.8M (8:8:8)   */
> +#define VBE_R320x200C17M      0x10F
> +/* 15-bit mode, Resolution: 640x480,   Colors: 32K   (1:5:5:5) */
> +#define VBE_R640x480C32K      0x110
> +/* 15-bit mode, Resolution: 640x480,   Colors: 64K   (5:6:5)   */
> +#define VBE_R640x480C64K      0x111
> +/* 15-bit mode, Resolution: 640x480,   Colors: 16.8M (8:8:8)   */
> +#define VBE_R640x480C17M      0x112
> +/* 15-bit mode, Resolution: 800x600,   Colors: 32K   (1:5:5:5) */
> +#define VBE_R800x600C32K      0x113
> +/* 15-bit mode, Resolution: 800x600,   Colors: 64K   (5:6:5)   */
> +#define VBE_R800x600C64K      0x114
> +/* 15-bit mode, Resolution: 800x600,   Colors: 16.8M (8:8:8)   */
> +#define VBE_R800x600C17M      0x115
> +/* 15-bit mode, Resolution: 1024x768,  Colors: 32K   (1:5:5:5) */
> +#define VBE_R1024x768C32K     0x116
> +/* 15-bit mode, Resolution: 1024x768,  Colors: 64K   (5:6:5)   */
> +#define VBE_R1024x768C64K     0x117
> +/* 15-bit mode, Resolution: 1024x768,  Colors: 16.8M (8:8:8)   */
> +#define VBE_R1024x768C17M     0x118
> +/* 15-bit mode, Resolution: 1280x1024, Colors: 32K   (1:5:5:5) */
> +#define VBE_R1280x1024C32K    0x119
> +/* 15-bit mode, Resolution: 1280x1024, Colors: 64K   (5:6:5)   */
> +#define VBE_R1280x1024C64K    0x11A
> +/* 15-bit mode, Resolution: 1280x1024, Colors: 16.8M (8:8:8)   */
> +#define VBE_R1280x1024C17M    0x11B
> +#define VBE_SpecialMode       0x81FF
> +/* Text modes */
> +#define VBE_C80R60            0x108   /* 15-bit mode, Columns: 80,  Rows: 60 */
> +#define VBE_C132R25           0x109   /* 15-bit mode, Columns: 132, Rows: 25 */
> +#define VBE_C132R43           0x10A   /* 15-bit mode, Columns: 132, Rows: 43 */
> +#define VBE_C132R50           0x10B   /* 15-bit mode, Columns: 132, Rows: 50 */
> +#define VBE_C132R60           0x10C   /* 15-bit mode, Columns: 132, Rows: 60 */
> +/* VBE function numbers - passed in AX register */
> +#define VBE_RetVBEConInf       0x4F00 /* Return VBE Controller Information */
> +#define VBE_RetVBEModInf       0x4F01 /* Return VBE Mode Information */
> +#define VBE_SetVBEMod          0x4F02 /* Set VBE Mode */
> +#define VBE_RetCurVBEMod       0x4F03 /* Return Current VBE Mode */
> +#define VBE_SavResSta          0x4F04 /* Save/Restore State */
> +#define VBE_DisWinCon          0x4F05 /* Display Window Control */
> +#define VBE_SetGetLogScaLinLen 0x4F06 /* Set/Get Logical Scan Line Length */
> +#define VBE_SetGetDisSta       0x4F07 /* Set/Get Display Start */
> +#define VBE_SetGetDACPalFor    0x4F08 /* Set/Get DAC Palette Format */
> +#define VBE_SetGetPalDat       0x4F09 /* Set/Get Palette Data */
> +#define VBE_RetVBEProModInt    0x4F0A /* Return VBE Protected Mode Interface */
> +#define VBE_GetSetpixclo       0x4F0B /* Get/Set pixel clock */
> +#define VBE_PowManExt          0x4F10 /* Power Management Extensions (PM) */
> +#define VBE_FlaPanIntExt       0x4F11 /* Flat Panel Interface Extensions (FP) */
> +#define VBE_AudIntExt          0x4F13 /* Audio Interface Extensions (AI) */
> +#define VBE_OEMExt             0x4F14 /* OEM Extensions */
> +#define VBE_DisDatCha          0x4F15 /* Display Data Channel (DDC),
> +                                         Serial Control Interface (SCI) */
> +/* VBE subfunction numbers - passed in BL register */
> +#define VBE_RetVBESupSpeInf    0x00  /* Return VBE Supplemental
> +                                        Specification Information */
> +/* *** Structures *** */
> +struct VBE_FarPtr {
> +    uint16_t offset;
> +    uint16_t selector;
> +} __attribute__((__packed__)) ;
> +struct VBE_PMInfoBlock {
> +    uint8_t   Signature[4];    /*  PM Info Block Signature */
> +    uint16_t  EntryPoint;      /*  Offset of PM entry point within BIOS */
> +    uint16_t  PMInitialize;    /*  Offset of PM initialization entry point */
> +    uint16_t  BIOSDataSel;     /*  Selector to BIOS data area emulation block */
> +    uint16_t  A0000Sel;        /*  Selector to access A0000h physical mem */
> +    uint16_t  B0000Sel;        /*  Selector to access B0000h physical mem */
> +    uint16_t  B8000Sel;        /*  Selector to access B8000h physical mem */
> +    uint16_t  CodeSegSel;      /*  Selector to access code segment as data */
> +    uint8_t   InProtectMode;   /*  Set to 1 when in protected mode */
> +    uint8_t   Checksum;        /*  Checksum byte for structure */
> +/* General VBE signature */
> +#define VBE_SIGNATURE "VESA"
> +/* Signature for VBE 2.0 and higher */
> +#define VBE20plus_SIGNATURE "VBE2"
> +/* for STUB see VBE CORE FUNCTIONS VERSION 3.0 - Appendix 1 */
> +#define VBE_END_OF_VideoModeList 0xFFFF
> +#define VBE_STUB_VideoModeList 0xFFFF
> +struct VBE_VbeInfoBlock {
> +    uint8_t   VbeSignature[4];   /*  VBE Signature */
> +    uint16_t  VbeVersion;        /*  VBE Version */
> +    uint8_t  *OemStringPtr;      /*  VbeFarPtr to OEM String */
> +    uint8_t   Capabilities[4];   /*  Capabilities of graphics controller */
> +    uint32_t *VideoModePtr;      /*  VbeFarPtr to VideoModeList */
> +    uint16_t  TotalMemory;       /*  Number of 64kb memory blocks    */
> +    /*  Added for VBE 2.0+ */
> +    uint16_t  OemSoftwareRev;    /*  VBE implementation Software revision */
> +    uint8_t  *OemVendorNamePtr;  /*  VbeFarPtr to Vendor Name String */
> +    uint8_t  *OemProductNamePtr; /*  VbeFarPtr to Product Name String */
> +    uint8_t  *OemProductRevPtr;  /*  VbeFarPtr to Product Revision String */
> +    uint8_t   Reserved[222];     /*  Reserved for VBE implementation scratch */
> +    /*    area */
> +    uint8_t   OemData[256];      /*  Data Area for OEM Strings */
> +struct VBE_ModeInfoBlock {
> +    /*  Mandatory information for all VBE revisions */
> +    uint16_t  ModeAttributes;        /* mode attributes */
> +    uint8_t   WinAAttributes;        /* window A attributes */
> +    uint8_t   WinBAttributes;        /* window B attributes */
> +    uint16_t  WinGranularity;        /* window granularity */
> +    uint16_t  WinSize;               /* window size */
> +    uint16_t  WinASegment;           /* window A start segment */
> +    uint16_t  WinBSegment;           /* window B start segment */
> +    uint32_t *WinFuncPtr;            /* real mode pointer to window function */
> +    uint16_t  BytesPerScanLine;      /* bytes per scan line */
> +    /*  Mandatory information for VBE 1.2 and above */
> +    uint16_t  XResolution;           /* horizontal resolution in px or chars */
> +    uint16_t  YResolution;           /* vertical resolution in px or chars */
> +    uint8_t   XCharSize;             /* character cell width in pixels */
> +    uint8_t   YCharSize;             /* character cell height in pixels */
> +    uint8_t   NumberOfPlanes;        /* number of memory planes */
> +    uint8_t   BitsPerPixel;          /* bits per pixel */
> +    uint8_t   NumberOfBanks;         /* number of banks */
> +    uint8_t   MemoryModel;           /* memory model type */
> +    uint8_t   BankSize;              /* bank size in KB */
> +    uint8_t   NumberOfImagePages;    /* number of images */
> +    uint8_t   Reserved0;             /* reserved for page function */
> +    /*  Direct Color fields (required for direct/6 and YUV/7 memory models) */
> +    uint8_t   RedMaskSize;           /* size of direct color red mask in bits */
> +    uint8_t   RedFieldPosition;      /* bit position of lsb of red mask */
> +    uint8_t   GreenMaskSize;         /* size of direct color green mask in b */
> +    uint8_t   GreenFieldPosition;    /* bit position of lsb of green mask */
> +    uint8_t   BlueMaskSize;          /* size of direct color blue mask in b */
> +    uint8_t   BlueFieldPosition;     /* bit position of lsb of blue mask */
> +    uint8_t   RsvdMaskSize;          /* size of direct color reserved mask */
> +    uint8_t   RsvdFieldPosition;     /* bit position of lsb of reserved mask */
> +    uint8_t   DirectColorModeInfo;   /* direct color mode attributes */
> +    /*  Mandatory information for VBE 2.0 and above */
> +    uint32_t *PhysBasePtr;           /* physical address for
> +                                        flat memory frame buffer */
> +    uint32_t  Reserved1;             /* Reserved - always set to 0 */
> +    uint16_t  Reserved2;             /* Reserved - always set to 0 */
> +    /*  Mandatory information for VBE 3.0 and above */
> +    uint16_t  LinBytesPerScanLine;   /* bytes per scan line for linear modes */
> +    uint8_t   BnkNumberOfImagePages; /* number of images for banked modes */
> +    uint8_t   LinNumberOfImagePages; /* number of images for linear modes */
> +        /* linear modes */
> +    uint8_t   LinRedMaskSize;        /* size of direct color red mask */
> +    uint8_t   LinRedFieldPosition;   /* bit position of lsb of red mask */
> +    uint8_t   LinGreenMaskSize;      /* size of direct color green mask  */
> +    uint8_t   LinGreenFieldPosition; /* bit position of lsb of green mask */
> +    uint8_t   LinBlueMaskSize;       /* size of direct color blue mask  */
> +    uint8_t   LinBlueFieldPosition;  /* bit position of lsb of blue mask */
> +    uint8_t   LinRsvdMaskSize;       /* size of direct color reserved mask */
> +    uint8_t   LinRsvdFieldPosition;  /* bit position of lsb of reserved mask */
> +    uint32_t  MaxPixelClock;         /* maximum pixel clock
> +                                        (in Hz) for graphics mode */
> +    uint8_t   Reserved3[189];        /* remainder of ModeInfoBlock */
> +struct VBE_CRTCInfoBlock {
> +    uint16_t  HorizontalTotal;       /* Horizontal total in pixels */
> +    uint16_t  HorizontalSyncStart;   /* Horizontal sync start in pixels */
> +    uint16_t  HorizontalSyncEnd;     /* Horizontal sync end in pixels */
> +    uint16_t  VerticalTotal;         /* Vertical total in lines */
> +    uint16_t  VerticalSyncStart;     /* Vertical sync start in lines */
> +    uint16_t  VerticalSyncEnd;       /* Vertical sync end in lines */
> +    uint8_t   Flags;                 /* Flags (Interlaced, Double Scan etc) */
> +    uint32_t  PixelClock;            /* Pixel clock in units of Hz */
> +    uint16_t  RefreshRate;           /* Refresh rate in units of 0.01 Hz */
> +    uint8_t   Reserved[40];          /* remainder of ModeInfoBlock */
> +struct VBE_PaletteEntry {
> +    uint8_t   Blue;                  /* Blue channel value (6 or 8 bits) */
> +    uint8_t   Green;                 /* Green channel value (6 or 8 bits) */
> +    uint8_t   Red;                   /* Red channel value(6 or 8 bits) */
> +    uint8_t   Alignment;             /* DWORD alignment byte (unused) */
> +struct VBE_SupVbeInfoBlock {
> +    uint8_t   SupVbeSignature[7];    /* Supplemental VBE Signature */
> +    uint16_t  SupVbeVersion;         /* Supplemental VBE Version */
> +    uint8_t   SupVbeSubFunc[8];      /* Bitfield of supported subfunctions */
> +    uint16_t  OemSoftwareRev;        /* OEM Software revision */
> +    uint8_t   Reserved[221];         /* Reserved for description
> +                                        strings and future */
> +    /*  expansion */
> +/* VbeInfoBlock Capabilities */
> +/*  D0 = 0  DAC is fixed width, with 6 bits per primary color */
> +/*     = 1 DAC width is switchable to 8 bits per primary color */
> +#define VBE_DACswitchableMask     0x0001
> +/*  D1 = 0 Controller is VGA compatible */
> +/*     = 1 Controller is not VGA compatible */
> +#define VBE_notVGAcompatibleMask  0x0002
> +/*  D2 = 0 Normal RAMDAC operation */
> +/*     = 1 When programming large blocks of information to the RAMDAC,
> +            use the blank bit in Function 09h. */
> +#define VBE_specialRAMDACopMask   0x0004
> +/*  D3 = 0 No hardware stereoscopic signaling support */
> +/*     = 1 Hardware stereoscopic signaling supported by controller */
> +#define VBE_hwStereoscopicMask    0x0008
> +/*  D4 = 0 Stereo signaling supported via external VESA stereo connector */
> +/*     = 1 Stereo signaling supported via VESA EVC connector */
> +#define VBE_supportEVCconnMask    0x0010
> +/*  D5-31 = Reserved */
> +/* ModeInfoBlock ModeAttributes */
> +/*  D0 =  Mode supported by hardware configuration */
> +/*   0 =  Mode not supported in hardware */
> +/*   1 =  Mode supported in hardware */
> +#define VBE_modSupInHWMask        0x0001
> +/*  D1 =  1 (Reserved) */
> +/*  D2 =  TTY Output functions supported by BIOS */
> +/*   0 =  TTY Output functions not supported by BIOS */
> +/*   1 =  TTY Output functions supported by BIOS */
> +#define VBE_TTYOutSupByBIOSMask   0x0004
> +/*  D3 =  Monochrome/color mode (see note below) */
> +/*   0 =  Monochrome mode */
> +/*   1 =  Color mode */
> +#define VBE_ColorModeMask         0x0008
> +/*  D4 =  Mode type */
> +/*   0 =  Text mode */
> +/*   1 =  Graphics mode */
> +#define VBE_GraphicsModeMask      0x0010
> +/*  D5 =  VGA compatible mode */
> +/*   0 =  Yes */
> +/*   1 =  No */
> +#define VBE_VGACompModeMask       0x0020
> +/*  D6 =  VGA compatible windowed memory mode is available */
> +/*   0 =  Yes */
> +/*   1 =  No */
> +#define VBE_VGACompWinMemModeMask 0x0040
> +/*  D7 =  Linear frame buffer mode is available */
> +/*   0 =  No */
> +/*   1 =  Yes */
> +#define VBE_LinFraBufModeAvaiMask 0x0080
> +/*  D8 =  Double scan mode is available */
> +/*   0 =  No */
> +/*   1 =  Yes */
> +#define VBE_DblScnModeAvaiMask    0x0100
> +/*  D9 =  Interlaced mode is available */
> +/*   0 =  No */
> +/*   1 =  Yes */
> +#define VBE_InterlModeAvaiMask    0x0200
> +/*  D10 =  Hardware triple buffering support */
> +/*   0 =  No */
> +/*   1 =  Yes */
> +#define VBE_HWTripBufSupMask      0x0400
> +/*  D11 =  Hardware stereoscopic display support */
> +/*   0 =  No */
> +/*   1 =  Yes */
> +#define VBE_HWSterDispSupMask     0x0800
> +/*  D12 =  Dual display start address support */
> +/*   0 =  No */
> +/*   1 =  Yes */
> +#define VBE_DualDispStAdrSupMask  0x1000
> +/*  D13-D15 =  Reserved */
> +/* ModeInfoBlock WinXAttributes */
> +/*  D0 =  Relocatable window(s) supported */
> +/*   0 =  Single non-relocatable window only */
> +/*   1 =  Relocatable window(s) are supported */
> +#define VBE_RelocWinSupMask       0x01
> +/*  D1 =  Window readable */
> +/*   0 =  Window is not readable */
> +/*   1 =  Window is readable */
> +#define VBE_WinReadableMask       0x02
> +/*  D2 =  Window writeable */
> +/*   0 =  Window is not writeable */
> +/*   1 =  Window is writeable */
> +#define VBE_WinWritableMask       0x04
> +/*  D3-D7 =  Reserved */
> +/* ModeInfoBlock MemoryModel */
> +#define VBE_TextMode              0x00
> +#define VBE_CGAGraphics           0x01
> +#define VBE_HerculesGraphics      0x02
> +#define VBE_Planar                0x03
> +#define VBE_PackedPixel           0x04
> +#define VBE_NonChain4Color256     0x05
> +#define VBE_DirectColor           0x06
> +#define VBE_YUV                   0x07
> +    /* 0x08-0x0F Reserved, to be defined by VESA */
> +    /* 0x10-0xFF To be defined by OEM */
> +/* ModeInfoBlock DirectColorModeInfo */
> +/*  D0 =  Color ramp is fixed/programmable */
> +/*   0 =  Color ramp is fixed */
> +/*   1 =  Color ramp is programmable */
> +#define VBE_ColRampProgMask       0x01
> +/*  D1 =  Bits in Rsvd field are usable/reserved */
> +/*   0 =  Bits in Rsvd field are reserved */
> +/*   1 =  Bits in Rsvd field are usable by the application */
> +#define VBE_RsvdBitsUsableMask    0x02
> +/* CRTCInfoBlock Flags */
> +/*  D0 =  Double Scan Mode Enable */
> +/*   0 =  Graphics mode is not double scanned */
> +/*   1 =  Graphics mode is double scanned */
> +#define VBE_GrModeDblScanMask     0x01
> +/*  D1 =  Interlaced Mode Enable */
> +/*   0 =  Graphics mode is non-interlaced */
> +/*   1 =  Graphics mode is interlaced */
> +#define VBE_GrModeInterlMask      0x02
> +/*  D2 =  Horizontal sync polarity */
> +/*   0 =  Horizontal sync polarity is positive (+) */
> +/*   1 =  Horizontal sync polarity is negative (-) */
> +#define VBE_HorSncPolNegMask      0x04
> +/*  D3 =  Vertical sync polarity */
> +/*   0 =  Vertical sync polarity is positive (+) */
> +/*   1 =  Vertical sync polarity is negative (-) */
> +#define VBE_VerSncPolNegMask      0x08
> +/*  VESA BIOS Extensions/Display Data Channel Standard
> +    Version: 1.1 November 18, 1999                      */
> +/* VBE/DDC subfunction numbers - passed in BL register */
> +#define VBEDDC_Capabilities    0x0   /* Report VBE/DDC Capabilities */
> +#define VBEDDC_ReadEDID        0x1   /* Read EDID */
> +/* DDC Capabilities */
> +/* DDC level supported - returned in BL register */
> +/* 0 - DDC1 not supported; 1 - DDC1 supported */
> +#define VBEDDC_1SupportedMask  0x1
> +/* 0 - DDC2 not supported; 1 - DDC2 supported */
> +#define VBEDDC_2SupportedMask  0x2
> +/* 0 - Screen not blanked during data transfer;
> +   1 - Screen blanked during data transfer */
> +#define VBEDDC_scrBlnkDatTrMs  0x4
> +/*  VESA BIOS Extensions/Serial Control Interface Standard
> +    Version: 1.0 Revision: 2 Date: July 2, 1997         */
> +/* VBE/SCI subfunction numbers - passed in BL register */
> +#define VBESCI_ReportCapabil   0x10  /* Report VBE/SCI Capabilities */
> +#define VBESCI_BegSCLSDACtrl   0x11  /* Begin SCL/SDA control */
> +#define VBESCI_EndSCLSDACtrl   0x12  /* End SCL/SDA control */
> +#define VBESCI_WrtSCLClkLine   0x13  /* Write SCL clock line */
> +#define VBESCI_WrtSDADatLine   0x14  /* Write SDA data line */
> +#define VBESCI_RdySCLClkLine   0x15  /* Read SCL clock line */
> +#define VBESCI_RdySDADatLine   0x16  /* Read SDA data line */
> +/* SCI Capabilities */
> +/* I2C level supported - returned in BL register */
> +#define VBESCI_capSCLwrtMask   0x1   /* Can write to SCL clock line */
> +#define VBESCI_capSDAwrtMask   0x2   /* Can write to SDA data line */
> +#define VBESCI_capSCLrdyMask   0x4   /* Can read from SCL clock line */
> +#define VBESCI_capSDArdyMask   0x8   /* Can read from SDA data line */
> +#ifdef __cplusplus
> +#endif /* ASM */
> diff --git a/c/src/lib/libbsp/i386/pc386/preinstall.am b/c/src/lib/libbsp/i386/pc386/preinstall.am
> index 1ff9fb8..e02d9d5 100644
> --- a/c/src/lib/libbsp/i386/pc386/preinstall.am
> +++ b/c/src/lib/libbsp/i386/pc386/preinstall.am
> @@ -147,6 +147,14 @@ $(PROJECT_INCLUDE)/i386_io.h: ../../i386/shared/comm/i386_io.h $(PROJECT_INCLUDE
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/i386_io.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/i386_io.h
> +$(PROJECT_INCLUDE)/vbe3.h: include/vbe3.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/vbe3.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/vbe3.h
> +$(PROJECT_INCLUDE)/edid.h: include/edid.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/edid.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/edid.h
>  $(PROJECT_INCLUDE)/pcibios.h: ../../i386/shared/pci/pcibios.h $(PROJECT_INCLUDE)/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/pcibios.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/pcibios.h
> 1.9.1
> devel mailing list
> devel at rtems.org
