[PATCH 5/6] i386/pc386/include: header files for VESA BIOS EXTENSIONS and VESA Extended Display Identification Data
Jan Dolezal dolezj21 at fel.cvut.cz
Wed Nov 12 15:07:55 UTC 2014
 c/src/lib/libbsp/i386/pc386/Makefile.am    |   2 +
 c/src/lib/libbsp/i386/pc386/include/edid.h | 759 +++++++++++++++++++++++++++++
 c/src/lib/libbsp/i386/pc386/include/vbe3.h | 461 ++++++++++++++++++
 c/src/lib/libbsp/i386/pc386/preinstall.am  |   8 +
 4 files changed, 1230 insertions(+)
 create mode 100644 c/src/lib/libbsp/i386/pc386/include/edid.h
 create mode 100644 c/src/lib/libbsp/i386/pc386/include/vbe3.h
diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am b/c/src/lib/libbsp/i386/pc386/Makefile.am
index 6042b5b..2e60947 100644
--- a/c/src/lib/libbsp/i386/pc386/Makefile.am
+++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
@@ -106,6 +106,8 @@ libbsp_a_SOURCES += console/printk_support.c
 libbsp_a_SOURCES += console/vgacons.c
 libbsp_a_SOURCES += console/exar17d15x.c
 libbsp_a_SOURCES += console/rtd316.c
+include_HEADERS += include/vbe3.h
+include_HEADERS += include/edid.h
 if USE_CIRRUS_GD5446
 libbsp_a_SOURCES += console/fb_cirrus.c
 else
diff --git a/c/src/lib/libbsp/i386/pc386/include/edid.h b/c/src/lib/libbsp/i386/pc386/include/edid.h
new file mode 100644
index 0000000..937976e
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/include/edid.h
@@ -0,0 +1,759 @@
+ * @file edid.h
+ * @ingroup i386_pc386
+ * @brief VESA EDID definitions.
+ * edid.h  - This file contains definitions for constants related to
+ *           VESA Extended Display Identification Data.
+ *          More information can be found at
+ *      <http://www.vesa.org/vesa-standards/free-standards/>
+ *          VESA public standards may be found at
+ *      <http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm>
+ * Copyright (C) 2014  Jan Doležal (dolezj21 at fel.cvut.cz)
+ *                     CTU in Prague.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifndef _EDID_H
+#define _EDID_H
+#ifndef ASM /* ASM */
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+/*  VESA Extended Display Identification Data (EDID) Standard
+    Version 3, Revision Date: November 13, 1997 */
+/*  VESA Enhanced Extended Display Identification Data (E-EDID) Standard
+    Release A, Revision 2, September 25, 2006 */
+/*  VESA Enhanced Extended Display Identification Data (E-EDID) Proposed
+    Release A, March 27, 2007 */
+/**** structs and defines shared by both EDIDv1 and EDIDv2 ****/
+/* Video Input Definition */
+/* Analog Interface Data Format - Signal Level Standard */
+#define EDIDx_SLS_0700_0300_1000Vpp             0x0
+#define EDIDx_SLS_0714_0286_1000Vpp             0x1
+#define EDIDx_SLS_1000_0400_1400Vpp             0x2
+#define EDIDx_SLS_0700_0000_0700Vpp             0x3
+struct DetailedTimingDescriptor{
+    uint16_t PixelClock_div10000;
+    uint8_t HorizontalActiveLow;
+    uint8_t HorizontalBlankingLow;
+    uint8_t HorizontalBlankingHigh          : 4;
+    uint8_t HorizontalActiveHigh            : 4;
+    uint8_t VerticalActiveLow;
+    uint8_t VerticalBlankingLow;
+    uint8_t VerticalBlankingHigh            : 4;
+    uint8_t VerticalActiveHigh              : 4;
+    uint8_t HorizontalSyncOffsetLow;
+    uint8_t HorizontalSyncPulseWidthLow;
+    uint8_t VerticalSyncPulseWidthLow       : 4;
+    uint8_t VerticalSyncOffsetLow           : 4;
+    uint8_t VerticalSyncPulseWidthHigh      : 2;
+    uint8_t VerticalSyncOffsetHigh          : 2;
+    uint8_t HorizontalSyncPulseWidthHigh    : 2;
+    uint8_t HorizontalSyncOffsetHigh        : 2;
+    uint8_t HorizontalImageSizeLow;
+    uint8_t VerticalImageSizeLow;
+    uint8_t VerticalImageSizeHigh           : 4;
+    uint8_t HorizontalImageSizeHigh         : 4;
+    uint8_t HorizontalBorder;
+    uint8_t VerticalBorder;
+    uint8_t Flag_StereoMode0                : 1;
+/* next four flags has different purpose with analog
+   and digital interfaces for EDID version 2; first
+   goes analog, after underscore there is digital name of bit */
+    uint8_t Flag_SyncPolarity_LPPolarity    : 1;
+    uint8_t Flag_Serration_FLMPolarity      : 1;
+    uint8_t Flag_Composition_Serration      : 1;
+    uint8_t Flag_Composition_ShiftClockUse  : 1;
+    uint8_t Flag_StereoMode1                : 2;
+    uint8_t Flag_Interlaced                 : 1;
+}__attribute__((__packed__));
+struct ColorPointData {
+    uint8_t ColorPointWhitePointIndexNumber;
+    uint8_t ColorPointWhiteLowBits;
+    uint8_t ColorPointWhite_x;
+    uint8_t ColorPointWhite_y;
+    uint8_t ColorPointWhiteGamma;
+/**** structs and defines for EDIDv1 ****/
+/* Basic Display Parameters */
+    /* Feature Support */
+        /* analog - Display Color Type */
+#define EDID_DisplayType_Monochrome         0
+#define EDID_DisplayType_RGBcolor           1
+#define EDID_DisplayType_nonRGBcolor        2
+#define EDID_DisplayType_undef              3
+        /* digital - Supported Color Encoding Formats */
+#define EDID_DisplayType_RGB444                 0
+#define EDID_DisplayType_RGB444YCrCb444         1
+#define EDID_DisplayType_RGB444YCrCb422         2
+#define EDID_DisplayType_RGB444YCrCb444YCrCb422 3
+/* Monitor Descriptor - Data Type Tag */
+#define EDID_DTT_MonitorSerialNumber        0xFF
+#define EDID_DTT_ASCIIString                0xFE
+#define EDID_DTT_MonitorRangeLimits         0xFD
+struct MonitorRangeLimits {
+    uint8_t MinVerticalRateInHz;
+    uint8_t MaxVerticalRateInHz;
+    uint8_t MinHorizontalInKHz;
+    uint8_t MaxHorizontalInKHz;
+    uint8_t MaxSupportedPixelClockIn10MHz;
+/* see  VESA, Generalized Timing Formula Standard - GTF
+        Version 1.0, December 18, 1996 */
+    uint8_t GTFStandard[8];
+#define EDID_DTT_MonitorName                0xFC
+#define EDID_DTT_AdditionalColorPointData   0xFB
+/* Standard Timing Identification */
+#define EDID_DTT_AdditionalSTI              0xFA
+#define EDID_DTT_DisplayColorManagement     0xF9
+#define EDID_DTT_CVT3ByteTimingCodes        0xF8
+#define EDID_CVT_AspectRatio_4_3            0
+#define EDID_CVT_AspectRatio_16_9           1
+#define EDID_CVT_AspectRatio_16_10          2
+#define EDID_CVT_AspectRatio_15_9           3
+#define EDID_CVT_PrefVertRate50Hz           0
+#define EDID_CVT_PrefVertRate60Hz           1
+#define EDID_CVT_PrefVertRate75Hz           2
+#define EDID_CVT_PrefVertRate85Hz           3
+struct CVT3ByteCodeDescriptor {
+    uint8_t AddressableLinesLow;
+    uint8_t Reserved0               : 2;
+    uint8_t AspectRatio             : 2;
+    uint8_t AddressableLinesHigh    : 4;
+    /* next 5 bits indicate supported vertical rates */
+    uint8_t VerticalRate60HzRB      : 1;
+    uint8_t VerticalRate85Hz        : 1;
+    uint8_t VerticalRate75Hz        : 1;
+    uint8_t VerticalRate60Hz        : 1;
+    uint8_t VerticalRate50Hz        : 1;
+    uint8_t PreferredVerticalRate   : 2;
+    uint8_t Reserved1               : 1;
+struct CVTTimingCodes3B {
+    uint8_t VersionNumber;
+    struct CVT3ByteCodeDescriptor cvt[4];
+#define EDID_DTT_EstablishedTimingsIII      0xF7
+struct EstablishedTimingsIII {
+    uint8_t RevisionNumber;
+    uint8_t EST_1152x864_75Hz   : 1;
+    uint8_t EST_1024x768_85Hz   : 1;
+    uint8_t EST_800x600_85Hz    : 1;
+    uint8_t EST_848x480_60Hz    : 1;
+    uint8_t EST_640x480_85Hz    : 1;
+    uint8_t EST_720x400_85Hz    : 1;
+    uint8_t EST_640x400_85Hz    : 1;
+    uint8_t EST_640x350_85Hz    : 1;
+    uint8_t EST_1280x1024_85Hz  : 1;
+    uint8_t EST_1280x1024_60Hz  : 1;
+    uint8_t EST_1280x960_85Hz   : 1;
+    uint8_t EST_1280x960_60Hz   : 1;
+    uint8_t EST_1280x768_85Hz   : 1;
+    uint8_t EST_1280x768_75Hz   : 1;
+    uint8_t EST_1280x768_60Hz   : 1;
+    uint8_t EST_1280x768_60HzRB : 1;
+    uint8_t EST_1400x1050_75Hz  : 1;
+    uint8_t EST_1400x1050_60Hz  : 1;
+    uint8_t EST_1400x1050_60HzRB: 1;
+    uint8_t EST_1400x900_85Hz   : 1;
+    uint8_t EST_1400x900_75Hz   : 1;
+    uint8_t EST_1400x900_60Hz   : 1;
+    uint8_t EST_1400x900_60HzRB : 1;
+    uint8_t EST_1360x768_60Hz   : 1;
+    uint8_t EST_1600x1200_70Hz  : 1;
+    uint8_t EST_1600x1200_65Hz  : 1;
+    uint8_t EST_1600x1200_60Hz  : 1;
+    uint8_t EST_1680x1050_85Hz  : 1;
+    uint8_t EST_1680x1050_75Hz  : 1;
+    uint8_t EST_1680x1050_60Hz  : 1;
+    uint8_t EST_1680x1050_60HzRB: 1;
+    uint8_t EST_1400x1050_85Hz  : 1;
+    uint8_t EST_1920x1200_60Hz  : 1;
+    uint8_t EST_1920x1200_60HzRB: 1;
+    uint8_t EST_1856x1392_75Hz  : 1;
+    uint8_t EST_1856x1392_60Hz  : 1;
+    uint8_t EST_1792x1344_75Hz  : 1;
+    uint8_t EST_1792x1344_60Hz  : 1;
+    uint8_t EST_1600x1200_85Hz  : 1;
+    uint8_t EST_1600x1200_75Hz  : 1;
+    uint8_t EST_Reserved0       : 4;
+    uint8_t EST_1920x1440_75Hz  : 1;
+    uint8_t EST_1920x1440_60Hz  : 1;
+    uint8_t EST_1920x1200_85Hz  : 1;
+    uint8_t EST_1920x1200_75Hz  : 1;
+    uint8_t EST_Reserved1[6];
+#define EDID_DTT_DescriptorSpaceUnused      0x10
+/* DTT 0x0 - 0xF are manufacturer specific */
+struct MonitorDescriptor {
+    uint16_t Flag0;
+    uint8_t Flag1;
+    uint8_t DataTypeTag;
+    uint8_t Flag2;
+    uint8_t DescriptorData[13];
+union DTD_MD {
+    struct DetailedTimingDescriptor dtd;
+    struct MonitorDescriptor md;
+#define EDID_STI_DescriptorUnused           0x0101
+#define EDID_STI_AspectRatio_16_10          0
+#define EDID_STI_AspectRatio_4_3            1
+#define EDID_STI_AspectRatio_5_4            2
+#define EDID_STI_AspectRatio_16_9           3
+struct StandardTimingIdentification {
+    uint8_t HorizontalActivePixels;
+    uint8_t ImageAspectRatio    : 2;
+    uint8_t RefreshRate         : 6;
+struct VID_Analog {
+    uint8_t SerationOnVerticalSync  : 1;
+    uint8_t SyncSignalOnGreen       : 1;
+    uint8_t SyncSignalOnHorizontal  : 1;
+    uint8_t SeparateSyncHandVSignals: 1;
+    uint8_t VideoSetupBlank         : 1;
+    uint8_t SignalLevelStandard     : 2;
+    uint8_t DigitalSignalLevel      : 1; /* Analog = 0, Digital = 1*/
+struct VID_Digital {
+    uint8_t DigitalVideoStandardSupp: 4;
+    uint8_t ColorBitDepth           : 3;
+/* Color Bit Depths */
+#define CBD_undef               0x0
+#define CBD_6bPerPrimaryColor   0x1
+#define CBD_8bPerPrimaryColor   0x2
+#define CBD_10bPerPrimaryColor  0x3
+#define CBD_12bPerPrimaryColor  0x4
+#define CBD_14bPerPrimaryColor  0x5
+#define CBD_16bPerPrimaryColor  0x6
+#define CBD_reserved            0x7
+/* Digital Video Standard Supported */
+#define DVS_undef               0x0
+#define DVS_DVI                 0x1
+#define DVS_HDMI-a              0x2
+#define DVS_HDMI-b              0x3
+#define DVS_MDDI                0x4
+#define DVS_DiplayPort          0x5
+union VideoInputDefinition {
+    struct VID_Analog analog;
+    struct VID_Digital digital;
+struct edid1{
+    uint8_t Header[8];
+/*  Vendor Product Identification */
+    uint16_t IDManufacturerName;
+    uint16_t IDProductCode;
+    uint32_t IDSerialNumber;
+    uint8_t WeekofManufacture;
+    uint8_t YearofManufacture;
+/*  EDID Structure Version Revision Level */
+    uint8_t Version;
+    uint8_t Revision;
+/*  Basic Display Parameters Features */
+    /* Video Input Definition */
+    union VideoInputDefinition vid;
+    uint8_t MaxHorizontalImageSize;
+    uint8_t MaxVerticalImageSize;
+    uint8_t DisplayTransferCharacteristic;
+    uint8_t Feature_GTFSupported                : 1;
+    uint8_t Feature_PreferredTimingMode         : 1;
+    uint8_t Feature_StandardDefaultColorSpace   : 1;
+    uint8_t Feature_DisplayType                 : 2;
+        /* Refer to VESA DPMS Specification */
+    uint8_t Feature_ActiveOff                   : 1;
+    uint8_t Feature_Suspend                     : 1;
+    uint8_t Feature_StandBy                     : 1;
+/*  Color Characteristics */
+    uint8_t GreenYLow   : 2;
+    uint8_t GreenXLow   : 2;
+    uint8_t RedYLow     : 2;
+    uint8_t RedXLow     : 2;
+    uint8_t WhiteYLow   : 2;
+    uint8_t WhiteXLow   : 2;
+    uint8_t BlueYLow    : 2;
+    uint8_t BlueXLow    : 2;
+    uint8_t RedXHigh;
+    uint8_t RedYHigh;
+    uint8_t GreenXHigh;
+    uint8_t GreenYHigh;
+    uint8_t BlueXHigh;
+    uint8_t BlueYHigh;
+    uint8_t WhiteXHigh;
+    uint8_t WhiteYHigh;
+/*  Established Timings I */
+    uint8_t EST_800x600_60Hz    : 1;
+    uint8_t EST_800x600_56Hz    : 1;
+    uint8_t EST_640x480_75Hz    : 1;
+    uint8_t EST_640x480_72Hz    : 1;
+    uint8_t EST_640x480_67Hz    : 1;
+    uint8_t EST_640x480_60Hz    : 1;
+    uint8_t EST_720x400_88Hz    : 1;
+    uint8_t EST_720x400_70Hz    : 1;
+/*  Established Timings II */
+    uint8_t EST_1280x1024_75Hz  : 1;
+    uint8_t EST_1024x768_75Hz   : 1;
+    uint8_t EST_1024x768_70Hz   : 1;
+    uint8_t EST_1024x768_60Hz   : 1;
+    uint8_t EST_1024x768_87Hz   : 1;
+    uint8_t EST_832x624_75Hz    : 1;
+    uint8_t EST_800x600_75Hz    : 1;
+    uint8_t EST_800x600_72Hz    : 1;
+/*  Manufacturer's Timings */
+    uint8_t EST_Reserved        : 7;
+    uint8_t EST_1152x870_75Hz   : 1;
+    struct StandardTimingIdentification STI[8];
+/*  Detailed Timing Descriptions / Monitor Descriptions */
+    union DTD_MD dtd_md[4];
+    uint8_t ExtensionFlag;
+    uint8_t Checksum;
+/**** structs and defines for EDIDv2 ****/
+struct EDID2_AnalogInterfaceDataFormatDescription{
+    uint8_t SyncInputsSupported0            : 1;
+    uint8_t SyncInputsSupported1            : 1;
+    uint8_t SyncInputsSupported2            : 1;
+    uint8_t SyncInputsSupported3            : 1;
+    uint8_t Setup                           : 1;
+    uint8_t Reserved0                       : 1;
+    uint8_t Reserved1                       : 7;
+    uint8_t PixelClockSupported             : 1;
+    uint8_t Reserved2;
+    uint8_t Reserved3;
+struct EDID2_DigitalInterfaceDataFormatDescription{
+    uint8_t ChannelSpeedExponent    : 4;
+    uint8_t NumberOfReceiverUnits   : 2;
+    uint8_t EdgeOfShiftClockUsed    : 1;
+    uint8_t DisplayEnablePolarity   : 1;
+    uint8_t MinimumChannelSpeed;
+    uint8_t MaximumChannelSpeed;
+    uint8_t DigitalInterfaceDataFormat;
+union EDID2_InterfaceDataFormatDescription{
+    struct EDID2_AnalogInterfaceDataFormatDescription analog;
+    struct EDID2_DigitalInterfaceDataFormatDescription digital;
+struct edid2{
+/*  EDID Structure Version/Revision */
+    uint8_t Revision : 4;
+    uint8_t Version : 4;
+/*  Vendor / Product Identification */
+    uint8_t WeekOfManufacture;
+    uint16_t YearOfManufacture;
+/*  Manufacturer/Product Name String */
+    char ManufacturerProductIDstring[32];
+/*  Serial Number String */
+    char SerialNumberString[16];
+/*  Unused (Reserved) */
+    uint8_t Unused0[8];
+/*  Display Interface Parameters */
+    /* Physical Connector Type */
+    uint8_t PhysicalInterfaceSecondary  : 4; /* see Physical Connector Types */
+    uint8_t PhysicalInterfaceDefault    : 4; /* see Physical Connector Types */
+    uint8_t VideoInterfaceTypeSecondary     : 4;
+    uint8_t VideoInterfaceTypeDefault       : 4;
+    union EDID2_InterfaceDataFormatDescription IDFDefault;
+    union EDID2_InterfaceDataFormatDescription IDFSecondary;
+    /* Interface Color Luminance Encoding */
+    uint8_t CLE_ColorencodingSecondary      : 4;
+    uint8_t CLE_ColorencodingDefault        : 4;
+        /* SC - sub-channel; 0 - red, 1 - green, 2 - blue */
+    uint8_t CLE_supportedBitDepthSC1Default     : 4;
+    uint8_t CLE_supportedBitDepthSC0Default     : 4;
+    uint8_t CLE_supportedBitDepthSC3Default     : 4;
+    uint8_t CLE_supportedBitDepthSC2Default     : 4;
+    uint8_t CLE_supportedBitDepthSC1Secondary   : 4;
+    uint8_t CLE_supportedBitDepthSC0Secondary   : 4;
+    uint8_t CLE_supportedBitDepthSC3Secondary   : 4;
+    uint8_t CLE_supportedBitDepthSC2Secondary   : 4;
+/*  Display Device Description */
+    uint8_t DisplayTechnologySubtype        : 4;
+    uint8_t DisplayTechnologyType           : 4;
+    /* Major Display Characteristics */
+    uint8_t MDC_PhysicalImplementation      : 2;
+    uint8_t MDC_DisplayBackground           : 1;
+    uint8_t MDC_ScanOrientation             : 2;
+    uint8_t MDC_Conditionalupdate           : 1;
+    uint8_t MDC_SelectableDisplayChromacity : 1;
+    uint8_t MDC_Color                       : 1;
+    /* Features */
+    uint8_t Features_Reserved0              : 1;
+    uint8_t Features_StereoSupport          : 3;
+    uint8_t Features_Off                    : 1;
+    uint8_t Features_ActiveOff              : 1;
+    uint8_t Features_Suspend                : 1;
+    uint8_t Features_StandBy                : 1;
+    uint8_t Features_VideoInput             : 2;
+    uint8_t Features_AudioOutputInterface   : 2;
+    uint8_t Features_AudioOutput            : 1;
+    uint8_t Features_AudioInputInterface    : 2;
+    uint8_t Features_AudioInput             : 1;
+    uint8_t Features_Reserved1              : 3;
+    uint8_t Features_AdjustableOrientation  : 1;
+    uint8_t Features_Colorimeter            : 1;
+    uint8_t Features_LuminanceProbe         : 1;
+    uint8_t Features_LightPen               : 1;
+    uint8_t Features_TouchScreen            : 1;
+/*  Display Response Time; Seconds - Range 0-15 * 10^(-n), n=timeexp */
+    uint8_t DRT_RiseTimeResponseInSeconds   : 4;
+    uint8_t DRT_RiseTimeExponent            : 4;
+    uint8_t DRT_FallTimeResponseInSeconds   : 4;
+    uint8_t DRT_FallTimeExponent            : 4;
+/*  Color Luminance Description */
+    uint8_t DisplayTransferCharacteristic_WhiteGamma;
+    uint8_t DisplayTransferCharacteristic_Color0Gamma;
+    uint8_t DisplayTransferCharacteristic_Color1Gamma;
+    uint8_t DisplayTransferCharacteristic_Color2Gamma;
+    uint16_t MaximumLuminanceWhite;
+    uint8_t LuminanceFlag_OffsetSignBit     : 1;
+    uint8_t LuminanceFlags_Reserved         : 5;
+    uint8_t LuminanceFlag_AdjustableGamma   : 1;
+    uint8_t LuminanceFlag_StandardRGBmodel  : 1;
+    uint8_t LuminanceOffset;
+    /* Chromacity and Default White Point Coordinates */
+    uint8_t ColorCharacteristicsGreenYLow   : 2;
+    uint8_t ColorCharacteristicsGreenXLow   : 2;
+    uint8_t ColorCharacteristicsRedYLow     : 2;
+    uint8_t ColorCharacteristicsRedXLow     : 2;
+    uint8_t ColorCharacteristicsWhiteYLow   : 2;
+    uint8_t ColorCharacteristicsWhiteXLow   : 2;
+    uint8_t ColorCharacteristicsBlueYLow    : 2;
+    uint8_t ColorCharacteristicsBlueXLow    : 2;
+    uint8_t ColorCharacteristicsRedXHigh;
+    uint8_t ColorCharacteristicsRedYHigh;
+    uint8_t ColorCharacteristicsGreenXHigh;
+    uint8_t ColorCharacteristicsGreenYHigh;
+    uint8_t ColorCharacteristicsBlueXHigh;
+    uint8_t ColorCharacteristicsBlueYHigh;
+    uint8_t ColorCharacteristicsWhiteXHigh;
+    uint8_t ColorCharacteristicsWhiteYHigh;
+    /* Additional White Points And Gamma */
+    struct ColorPointData cpd[2];
+/*  Display Spatial Description */
+    uint16_t MaxHorizontalImageSize;
+    uint16_t MaxVerticalImageSize;
+    uint16_t MaxHorizontalAddressibility;
+    uint16_t MaxVerticalAddressibility;
+    uint8_t HorizontalPixelPitch;
+    uint8_t VerticalPixelPitch;
+    uint8_t Unused1;
+/*  GTF Support Information */
+    uint8_t GTFSupportInformationSecond : 4;
+    uint8_t GTFSupportInformation       : 4;
+/*  Map Of Timing Information */
+    uint8_t MTI_NumberOfDetailedRangeLimitsListed   : 2;
+    uint8_t MTI_NumberOfFrequencyRangesListed       : 3;
+    uint8_t MTI_LuminanceTableProvided              : 1;
+    uint8_t MTI_PreferredTimingMode                 : 1;
+    uint8_t MTI_ExtensionFlag                       : 1;
+    uint8_t MTI_NumberOfDetailedTimingDescriptions  : 3;
+    uint8_t MTI_NumberOf4byteTimingCodesListed      : 5;
+/* 80h  Luminance Table Timing Descriptions */
+    uint8_t LuminanceTableTimingDescriptions[0x7F];
+/*  x*A Luminance Table */
+/*  8*B Range Limits */
+/* 27*C 27-Byte Detailed Range Limits */
+/*  4*D 4-Byte Timing Codes */
+/* 18*E 18-Byte Detailed Timing Descriptions */
+/* zeros up to FEh */
+    uint8_t Checksum;
+/* Luminance Table */
+struct LuminanceTable {
+    uint8_t NumberOfLuminanceEntries        : 5; /* n */
+    uint8_t Reserved                        : 2;
+    uint8_t SeparateSubChannels             : 1; /* s */
+    uint8_t LuminanceValues; /* if s==0 there are n else 3*n bytes here */
+/* Range Limits */
+struct DisplayTimingRangeLimits {
+    uint8_t MinFrameFieldRateInHzHigh;
+    uint8_t MaxFrameFieldRateInHzHigh;
+    uint8_t MinLineRateInkHzHigh;
+    uint8_t MaxLineRateInkHzHigh;
+    uint8_t MaxLineRateInkHzLow             : 2;
+    uint8_t MinLineRateInkHzLow             : 2;
+    uint8_t MaxFrameFieldRateInHzLow        : 2;
+    uint8_t MinFrameFieldRateInHzLow        : 2;
+    uint8_t MinPixelRateInMHzLow;
+    uint8_t MaxPixelRateInMHzLow;
+    uint8_t MaxPixelRateInMHzHigh           : 4;
+    uint8_t MinPixelRateInMHzHigh           : 4;
+/* 27-Byte Detailed Range Limits */
+struct DetailedTimingRangeFormat27B {
+    uint16_t MinPixelClock_div10000;
+    uint8_t MinHorizontalBlankingLow;
+    uint8_t MinVerticalBlankingLow;
+    uint8_t MinVerticalBlankingHigh         : 4;
+    uint8_t MinHorizontalBlankingHigh       : 4;
+    uint8_t MinHorizontalSyncOffsetLow;
+    uint8_t MinHorizontalSyncPulseWidthLow;
+    uint8_t MinVerticalSyncPulseWidthLow    : 4;
+    uint8_t MinVerticalSyncOffsetLow        : 4;
+    uint8_t MinVerticalSyncPulseWidthHigh   : 2;
+    uint8_t MinVerticalSyncOffsetHigh       : 2;
+    uint8_t MinHorizontalSyncPulseWidthHigh : 2;
+    uint8_t MinHorizontalSyncOffsetHigh     : 2;
+    uint16_t MaxPixelClock_div10000;
+    uint8_t MaxHorizontalBlankingLow;
+    uint8_t MaxVerticalBlankingLow;
+    uint8_t MaxVerticalBlankingHigh         : 4;
+    uint8_t MaxHorizontalBlankingHigh       : 4;
+    uint8_t MaxHorizontalSyncOffsetLow;
+    uint8_t MaxHorizontalSyncPulseWidthLow;
+    uint8_t MaxVerticalSyncPulseWidthLow    : 4;
+    uint8_t MaxVerticalSyncOffsetLow        : 4;
+    uint8_t MaxVerticalSyncPulseWidthHigh   : 2;
+    uint8_t MaxVerticalSyncOffsetHigh       : 2;
+    uint8_t MaxHorizontalSyncPulseWidthHigh : 2;
+    uint8_t MaxHorizontalSyncOffsetHigh     : 2;
+    uint8_t Flags_Set0                      : 1;
+    /* Next four bits are specified for digital interfaces.
+    Meaning for analog interfaces shall be found
+    in the document mentioned above. */
+    uint8_t Flags_LPPolarity                : 1;
+    uint8_t Flags_FLMPolarity               : 1;
+    uint8_t Flags_Reserved                  : 1;
+    uint8_t Flags_ShiftClockUse             : 1;
+    uint8_t Flags_Set1                      : 2;
+    uint8_t Flags_Interlaced                : 1;
+/* 4-Byte Timing Codes */
+struct TimingCodeFormat4B {
+    uint8_t ActivePixelsPerLine;
+    uint8_t Reserved                        : 1;
+    uint8_t SHFTCLKedgesUsed                : 1;
+    uint8_t FLMPolarity                     : 1;
+    uint8_t LPPolarity                      : 1;
+    uint8_t Portrait                        : 1;
+    uint8_t Stereo                          : 1;
+    uint8_t InterlacedTiming                : 1;
+    uint8_t ReducedBlanking                 : 1;
+    uint8_t FormatAspectRatio;
+    uint8_t RefreshRate;
+/* 18-Byte Detailed Timing Descriptions */
+    /* see struct DetailedTimingDescriptor */
+/* Physical Connector Types (Default/SecondaryPhysicalInterface) */
+#define EDID2_PCT_None                          0x0
+#define EDID2_PCT_BNC                           0x1
+#define EDID2_PCT_15pinVGA                      0x2
+#define EDID2_PCT_13w3                          0x3
+#define EDID2_PCT_VESAEVC                       0x4
+#define EDID2_PCT_VESAPDD                       0x5
+#define EDID2_PCT_Microribbon                   0x6
+#define EDID2_PCT_IEEE1394                      0x7
+#define EDID2_PCT_VESAFPDI2                     0x8
+/* Reserved 0x9-0xE */
+#define EDID2_PCT_Nonstandard                   0xF
+/* Video Interface Type */
+#define EDID2_VIT_None                          0x0
+#define EDID2_VIT_Analog                        0x1
+#define EDID2_VIT_Analogwsampledpixelclock      0x2
+    /* Transition Minimized Differential Signaling */
+#define EDID2_VIT_TMDS                          0x3
+#define EDID2_VIT_IEEE1394_1995                 0x4
+#define EDID2_VIT_LVDS                          0x5
+#define EDID2_VIT_Parallel                      0x6
+/* Reserved 0x7-0xF */
+/* digital interface data format */
+#define EDID2_didf_RGB_STN-DD_8BitOver8Bit      0x15
+#define EDID2_didf_RGB_STN-DD_12BitOver12Bit    0x19
+#define EDID2_didf_MSBAlignedRGBTFT24Bit        0x24
+/* Color/Luminance Encoding Description */
+        /* nibbles of byte 0 - color encodings */
+#define EDID2_CLE_CE_Monochrome                 0x0
+#define EDID2_CLE_CE_RGBadd                     0x1
+#define EDID2_CLE_CE_CMYsub                     0x2
+#define EDID2_CLE_CE_CMYKsub                    0x3
+#define EDID2_CLE_CE_YC_NTSC                    0x4
+#define EDID2_CLE_CE_YC_PAL                     0x5
+#define EDID2_CLE_CE_YC_SECAM                   0x6
+#define EDID2_CLE_CE_YIQ_NTSC                   0x7
+#define EDID2_CLE_CE_YIQ_PAL                    0x8
+#define EDID2_CLE_CE_YIQ_SECAM                  0x9
+#define EDID2_CLE_CE_YCrCb                      0xA
+#define EDID2_CLE_CE_YPrPb                      0xB
+#define EDID2_CLE_CE_XYZ                        0xC
+#define EDID2_CLE_CE_CIELuv                     0xD
+#define EDID2_CLE_CE_CIELab                     0xE
+#define EDID2_CLE_CE_Digital_ATSC               0xF
+/* Display Device Description; T-type, ST-subtype */
+#define EDID2_DDD_T_CRT         0x0 /* Cathode Ray Tube */
+#define EDID2_DDD_ST_CRT_Monochrome             0x0
+#define EDID2_DDD_ST_CRT_ShadowmaskColor        0x1
+#define EDID2_DDD_ST_CRT_BeamIndexColor         0x2
+#define EDID2_DDD_ST_CRT_BeamPenetrationColor   0x3
+#define EDID2_DDD_T_LCD         0x1 /* Liquid Crystal Display */
+#define EDID2_DDD_ST_LCD_STN                    0x0
+#define EDID2_DDD_ST_LCD_DSTN                   0x1
+#define EDID2_DDD_ST_LCD_FLCD                   0x2
+#define EDID2_DDD_ST_LCD_TFTconv                0x3
+#define EDID2_DDD_ST_LCD_TFTinplaneswtch        0x4
+#define EDID2_DDD_ST_LCD_PDLCD                  0x5
+#define EDID2_DDD_ST_LCD_PSCLCD                 0x6
+#define EDID2_DDD_ST_LCD_PALCD                  0x7
+#define EDID2_DDD_T_EL          0x2 /* Electroluminiscent Displ */
+#define EDID2_DDD_ST_EL_ACThin                  0x0
+#define EDID2_DDD_ST_EL_ACThick                 0x1
+#define EDID2_DDD_ST_EL_DCThin                  0x2
+#define EDID2_DDD_ST_EL_DCThick                 0x3
+#define EDID2_DDD_T_PDP         0x3 /* Plasma Display Panel */
+#define EDID2_DDD_ST_PDP_AC                     0x0
+#define EDID2_DDD_ST_PDP_DC                     0x1
+#define EDID2_DDD_T_FED         0x4 /* Field Emission Displays */
+#define EDID2_DDD_ST_FED_TBD                    0x0
+#define EDID2_DDD_T_LED         0x5 /* Light Emitting Diode */
+#define EDID2_DDD_ST_LED_TBD                    0x0
+#define EDID2_DDD_T_IRD         0x6 /* Integrated Reflective Display */
+#define EDID2_DDD_ST_IRD_1Chip                  0x0
+#define EDID2_DDD_ST_IRD_2Chip                  0x1
+#define EDID2_DDD_ST_IRD_3Chip                  0x2
+    /* Types 0x7-0xF Reserved */
+/* MajorDisplayCharacteristics */
+#define EDID2_MDC_C_Color               1
+#define EDID2_MDC_C_Mono                0
+#define EDID2_MDC_SO_notscanned         0x0
+#define EDID2_MDC_SO_fastLRslowTB       0x1
+#define EDID2_MDC_SO_fastTBslowLR       0x2
+#define EDID2_MDC_SO_fastTBslowRL       0x3
+#define EDID2_MDC_DB_NonTransp          0
+#define EDID2_MDC_DB_Transparent        1
+#define EDID2_MDC_PI_Large              0x0
+#define EDID2_MDC_PI_Desktop            0x1
+#define EDID2_MDC_PI_Eyepiece           0x2
+/* FeaturesSupport */
+        /* byte 0 - refer to VESA DPMS specification */
+            /* Stereo Support */
+#define EDID2_FS_SS_nodirectstereo      0x0
+#define EDID2_FS_SS_fieldseqstereo      0x1
+#define EDID2_FS_SS_directviewcolumnilv 0x2
+#define EDID2_FS_SS_directviewlineilv   0x3
+        /* byte 1 */
+            /* VideoInputValues */
+#define EDID2_FX_VI_None                0x0
+#define EDID2_FX_VI_AnalogYCconnEVC     0x1
+#define EDID2_FX_VI_USBCam              0x2
+#define EDID2_FX_VI_IEEE1394Cam         0x3
+            /* AudioOutputInterfaceValues */
+#define EDID2_FS_AOI_None               0x0
+#define EDID2_FS_AOI_Analog             0x1
+#define EDID2_FS_AOI_USB                0x2
+#define EDID2_FS_AOI_IEEE1394           0x3
+            /* Audio Input Interface Values */
+#define EDID2_FS_AII_None               0x0
+#define EDID2_FS_AII_Analog             0x1
+#define EDID2_FS_AII_USB                0x2
+#define EDID2_FS_AII_IEEE1394           0x3
+/* GTFSupportInformation values */
+#define EDID2_GTFSI_nosupport       0x0
+#define EDID2_GTFSI_stdCRTparams    0x1
+#define EDID2_GTFSI_defaultTBD      0x2
+#define EDID2_GTFSI_custom          0xF
+union edid {
+    struct edid1 edid1;
+    struct edid2 edid2;
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* _VBE_H */
diff --git a/c/src/lib/libbsp/i386/pc386/include/vbe3.h b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
index 0000000..152d552
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
@@ -0,0 +1,461 @@
+ * @file vbe3.h
+ * @brief VESA Bios Extension definitions.
+ * vbe3.h  - This file contains definitions for constants related to VBE.
+ *                     CTU in Prague.
+#ifndef _VBE_H
+#define _VBE_H
+#ifdef __cplusplus
+extern "C" {
+/*  VESA BIOS EXTENSION (VBE) Core functions Standard
+    Version: 3.0 Date: September 16, 1998               */
+/* VBE RETURN STATUS */
+/* AL == 4Fh: Function is supported */
+/* AL != 4Fh: Function is not supported */
+#define VBE_functionSupported        0x4F
+/* AH == 00h: Function call successful */
+#define VBE_callSuccessful           0x00
+/* AH == 01h: Function call failed */
+#define VBE_callFailed               0x01
+/* AH == 02h: Function is not supported in the current hardware configuration */
+#define VBE_notSupportedInCurHWConf  0x02
+/* AH == 03h: Function call invalid in current video mode */
+#define VBE_callInvalid              0x03
+/* VBE Mode Numbers */
+/* D0-D8 =  Mode number */
+#define VBE_modeNumberMask         0x01FF
+#define VBE_modeNumberShift          0x00
+/* If D8 == 0, this is not a VESA defined VBE mode */
+#define VBE_VESAmodeMask           0x0100
+/* If D8 == 1, this is a VESA defined VBE mode */
+/* D9-D12 =  Reserved by VESA for future expansion (= 0) */
+#define VBE_VESAmodeShift            0x08
+/* If D11 == 0, Use current BIOS default refresh rate */
+#define VBE_refreshRateCtrlMask    0x0800
+/* If D11 == 1, Use user specified CRTC values for refresh rate */
+/* D12-13 = Reserved for VBE/AF (must be 0) */
+#define VBE_refreshRateCtrlShift     0x0B
+/* If D14 == 0, Use Banked/Windowed Frame Buffer */
+#define VBE_linearFlatFrameBufMask 0x4000
+/* If D14 == 1, Use Linear/Flat Frame Buffer */
+#define VBE_linearFlatFrameBufShift  0x0E
+/* If D15 == 0, Clear display memory */
+#define VBE_preserveDispMemMask    0x8000
+/* If D15 == 1, Preserve display memory */
+#define VBE_preserveDispMemShift     0x0F
+/* Graphics modes */
+/* 15-bit mode, Resolution: 640x400,   Colors: 256  */
+#define VBE_R640x400C256      0x100
+/* 15-bit mode, Resolution: 640x480,   Colors: 256  */
+#define VBE_R640x480C256      0x101
+/* 15-bit mode, Resolution: 800x600,   Colors: 16   */
+#define VBE_R800x600C16       0x102
+/* 7-bit mode,  Resolution: 800x600,   Colors: 16   */
+#define VBE_b7R800x600C16     0x6A
+/* 15-bit mode, Resolution: 800x600,   Colors: 256  */
+#define VBE_R800x600C256      0x103
+/* 15-bit mode, Resolution: 1024x768,  Colors: 16   */
+#define VBE_R1024x768C16      0x104
+/* 15-bit mode, Resolution: 1024x768,  Colors: 256  */
+#define VBE_R1024x768C256     0x105
+/* 15-bit mode, Resolution: 1280x1024, Colors: 16   */
+#define VBE_R1280x1024C16     0x106
+/* 15-bit mode, Resolution: 1280x1024, Colors: 256  */
+#define VBE_R1280x1024C256    0x107
+/* 15-bit mode, Resolution: 320x200,   Colors: 32K   (1:5:5:5) */
+#define VBE_R320x200C32K      0x10D
+/* 15-bit mode, Resolution: 320x200,   Colors: 64K   (5:6:5)   */
+#define VBE_R320x200C64K      0x10E
+/* 15-bit mode, Resolution: 320x200,   Colors: 16.8M (8:8:8)   */
+#define VBE_R320x200C17M      0x10F
+/* 15-bit mode, Resolution: 640x480,   Colors: 32K   (1:5:5:5) */
+#define VBE_R640x480C32K      0x110
+/* 15-bit mode, Resolution: 640x480,   Colors: 64K   (5:6:5)   */
+#define VBE_R640x480C64K      0x111
+/* 15-bit mode, Resolution: 640x480,   Colors: 16.8M (8:8:8)   */
+#define VBE_R640x480C17M      0x112
+/* 15-bit mode, Resolution: 800x600,   Colors: 32K   (1:5:5:5) */
+#define VBE_R800x600C32K      0x113
+/* 15-bit mode, Resolution: 800x600,   Colors: 64K   (5:6:5)   */
+#define VBE_R800x600C64K      0x114
+/* 15-bit mode, Resolution: 800x600,   Colors: 16.8M (8:8:8)   */
+#define VBE_R800x600C17M      0x115
+/* 15-bit mode, Resolution: 1024x768,  Colors: 32K   (1:5:5:5) */
+#define VBE_R1024x768C32K     0x116
+/* 15-bit mode, Resolution: 1024x768,  Colors: 64K   (5:6:5)   */
+#define VBE_R1024x768C64K     0x117
+/* 15-bit mode, Resolution: 1024x768,  Colors: 16.8M (8:8:8)   */
+#define VBE_R1024x768C17M     0x118
+/* 15-bit mode, Resolution: 1280x1024, Colors: 32K   (1:5:5:5) */
+#define VBE_R1280x1024C32K    0x119
+/* 15-bit mode, Resolution: 1280x1024, Colors: 64K   (5:6:5)   */
+#define VBE_R1280x1024C64K    0x11A
+/* 15-bit mode, Resolution: 1280x1024, Colors: 16.8M (8:8:8)   */
+#define VBE_R1280x1024C17M    0x11B
+#define VBE_SpecialMode       0x81FF
+/* Text modes */
+#define VBE_C80R60            0x108   /* 15-bit mode, Columns: 80,  Rows: 60 */
+#define VBE_C132R25           0x109   /* 15-bit mode, Columns: 132, Rows: 25 */
+#define VBE_C132R43           0x10A   /* 15-bit mode, Columns: 132, Rows: 43 */
+#define VBE_C132R50           0x10B   /* 15-bit mode, Columns: 132, Rows: 50 */
+#define VBE_C132R60           0x10C   /* 15-bit mode, Columns: 132, Rows: 60 */
+/* VBE function numbers - passed in AX register */
+#define VBE_RetVBEConInf       0x4F00 /* Return VBE Controller Information */
+#define VBE_RetVBEModInf       0x4F01 /* Return VBE Mode Information */
+#define VBE_SetVBEMod          0x4F02 /* Set VBE Mode */
+#define VBE_RetCurVBEMod       0x4F03 /* Return Current VBE Mode */
+#define VBE_SavResSta          0x4F04 /* Save/Restore State */
+#define VBE_DisWinCon          0x4F05 /* Display Window Control */
+#define VBE_SetGetLogScaLinLen 0x4F06 /* Set/Get Logical Scan Line Length */
+#define VBE_SetGetDisSta       0x4F07 /* Set/Get Display Start */
+#define VBE_SetGetDACPalFor    0x4F08 /* Set/Get DAC Palette Format */
+#define VBE_SetGetPalDat       0x4F09 /* Set/Get Palette Data */
+#define VBE_RetVBEProModInt    0x4F0A /* Return VBE Protected Mode Interface */
+#define VBE_GetSetpixclo       0x4F0B /* Get/Set pixel clock */
+#define VBE_PowManExt          0x4F10 /* Power Management Extensions (PM) */
+#define VBE_FlaPanIntExt       0x4F11 /* Flat Panel Interface Extensions (FP) */
+#define VBE_AudIntExt          0x4F13 /* Audio Interface Extensions (AI) */
+#define VBE_OEMExt             0x4F14 /* OEM Extensions */
+#define VBE_DisDatCha          0x4F15 /* Display Data Channel (DDC),
+                                         Serial Control Interface (SCI) */
+/* VBE subfunction numbers - passed in BL register */
+#define VBE_RetVBESupSpeInf    0x00  /* Return VBE Supplemental
+                                        Specification Information */
+/* *** Structures *** */
+struct VBE_FarPtr {
+    uint16_t offset;
+    uint16_t selector;
+} __attribute__((__packed__)) ;
+struct VBE_PMInfoBlock {
+    uint8_t   Signature[4];    /*  PM Info Block Signature */
+    uint16_t  EntryPoint;      /*  Offset of PM entry point within BIOS */
+    uint16_t  PMInitialize;    /*  Offset of PM initialization entry point */
+    uint16_t  BIOSDataSel;     /*  Selector to BIOS data area emulation block */
+    uint16_t  A0000Sel;        /*  Selector to access A0000h physical mem */
+    uint16_t  B0000Sel;        /*  Selector to access B0000h physical mem */
+    uint16_t  B8000Sel;        /*  Selector to access B8000h physical mem */
+    uint16_t  CodeSegSel;      /*  Selector to access code segment as data */
+    uint8_t   InProtectMode;   /*  Set to 1 when in protected mode */
+    uint8_t   Checksum;        /*  Checksum byte for structure */
+/* General VBE signature */
+#define VBE_SIGNATURE "VESA"
+/* Signature for VBE 2.0 and higher */
+#define VBE20plus_SIGNATURE "VBE2"
+/* for STUB see VBE CORE FUNCTIONS VERSION 3.0 - Appendix 1 */
+#define VBE_END_OF_VideoModeList 0xFFFF
+#define VBE_STUB_VideoModeList 0xFFFF
+struct VBE_VbeInfoBlock {
+    uint8_t   VbeSignature[4];   /*  VBE Signature */
+    uint16_t  VbeVersion;        /*  VBE Version */
+    uint8_t  *OemStringPtr;      /*  VbeFarPtr to OEM String */
+    uint8_t   Capabilities[4];   /*  Capabilities of graphics controller */
+    uint32_t *VideoModePtr;      /*  VbeFarPtr to VideoModeList */
+    uint16_t  TotalMemory;       /*  Number of 64kb memory blocks    */
+    /*  Added for VBE 2.0+ */
+    uint16_t  OemSoftwareRev;    /*  VBE implementation Software revision */
+    uint8_t  *OemVendorNamePtr;  /*  VbeFarPtr to Vendor Name String */
+    uint8_t  *OemProductNamePtr; /*  VbeFarPtr to Product Name String */
+    uint8_t  *OemProductRevPtr;  /*  VbeFarPtr to Product Revision String */
+    uint8_t   Reserved[222];     /*  Reserved for VBE implementation scratch */
+    /*    area */
+    uint8_t   OemData[256];      /*  Data Area for OEM Strings */
+struct VBE_ModeInfoBlock {
+    /*  Mandatory information for all VBE revisions */
+    uint16_t  ModeAttributes;        /* mode attributes */
+    uint8_t   WinAAttributes;        /* window A attributes */
+    uint8_t   WinBAttributes;        /* window B attributes */
+    uint16_t  WinGranularity;        /* window granularity */
+    uint16_t  WinSize;               /* window size */
+    uint16_t  WinASegment;           /* window A start segment */
+    uint16_t  WinBSegment;           /* window B start segment */
+    uint32_t *WinFuncPtr;            /* real mode pointer to window function */
+    uint16_t  BytesPerScanLine;      /* bytes per scan line */
+    /*  Mandatory information for VBE 1.2 and above */
+    uint16_t  XResolution;           /* horizontal resolution in px or chars */
+    uint16_t  YResolution;           /* vertical resolution in px or chars */
+    uint8_t   XCharSize;             /* character cell width in pixels */
+    uint8_t   YCharSize;             /* character cell height in pixels */
+    uint8_t   NumberOfPlanes;        /* number of memory planes */
+    uint8_t   BitsPerPixel;          /* bits per pixel */
+    uint8_t   NumberOfBanks;         /* number of banks */
+    uint8_t   MemoryModel;           /* memory model type */
+    uint8_t   BankSize;              /* bank size in KB */
+    uint8_t   NumberOfImagePages;    /* number of images */
+    uint8_t   Reserved0;             /* reserved for page function */
+    /*  Direct Color fields (required for direct/6 and YUV/7 memory models) */
+    uint8_t   RedMaskSize;           /* size of direct color red mask in bits */
+    uint8_t   RedFieldPosition;      /* bit position of lsb of red mask */
+    uint8_t   GreenMaskSize;         /* size of direct color green mask in b */
+    uint8_t   GreenFieldPosition;    /* bit position of lsb of green mask */
+    uint8_t   BlueMaskSize;          /* size of direct color blue mask in b */
+    uint8_t   BlueFieldPosition;     /* bit position of lsb of blue mask */
+    uint8_t   RsvdMaskSize;          /* size of direct color reserved mask */
+    uint8_t   RsvdFieldPosition;     /* bit position of lsb of reserved mask */
+    uint8_t   DirectColorModeInfo;   /* direct color mode attributes */
+    /*  Mandatory information for VBE 2.0 and above */
+    uint32_t *PhysBasePtr;           /* physical address for
+                                        flat memory frame buffer */
+    uint32_t  Reserved1;             /* Reserved - always set to 0 */
+    uint16_t  Reserved2;             /* Reserved - always set to 0 */
+    /*  Mandatory information for VBE 3.0 and above */
+    uint16_t  LinBytesPerScanLine;   /* bytes per scan line for linear modes */
+    uint8_t   BnkNumberOfImagePages; /* number of images for banked modes */
+    uint8_t   LinNumberOfImagePages; /* number of images for linear modes */
+        /* linear modes */
+    uint8_t   LinRedMaskSize;        /* size of direct color red mask */
+    uint8_t   LinRedFieldPosition;   /* bit position of lsb of red mask */
+    uint8_t   LinGreenMaskSize;      /* size of direct color green mask  */
+    uint8_t   LinGreenFieldPosition; /* bit position of lsb of green mask */
+    uint8_t   LinBlueMaskSize;       /* size of direct color blue mask  */
+    uint8_t   LinBlueFieldPosition;  /* bit position of lsb of blue mask */
+    uint8_t   LinRsvdMaskSize;       /* size of direct color reserved mask */
+    uint8_t   LinRsvdFieldPosition;  /* bit position of lsb of reserved mask */
+    uint32_t  MaxPixelClock;         /* maximum pixel clock
+                                        (in Hz) for graphics mode */
+    uint8_t   Reserved3[189];        /* remainder of ModeInfoBlock */
+struct VBE_CRTCInfoBlock {
+    uint16_t  HorizontalTotal;       /* Horizontal total in pixels */
+    uint16_t  HorizontalSyncStart;   /* Horizontal sync start in pixels */
+    uint16_t  HorizontalSyncEnd;     /* Horizontal sync end in pixels */
+    uint16_t  VerticalTotal;         /* Vertical total in lines */
+    uint16_t  VerticalSyncStart;     /* Vertical sync start in lines */
+    uint16_t  VerticalSyncEnd;       /* Vertical sync end in lines */
+    uint8_t   Flags;                 /* Flags (Interlaced, Double Scan etc) */
+    uint32_t  PixelClock;            /* Pixel clock in units of Hz */
+    uint16_t  RefreshRate;           /* Refresh rate in units of 0.01 Hz */
+    uint8_t   Reserved[40];          /* remainder of ModeInfoBlock */
+struct VBE_PaletteEntry {
+    uint8_t   Blue;                  /* Blue channel value (6 or 8 bits) */
+    uint8_t   Green;                 /* Green channel value (6 or 8 bits) */
+    uint8_t   Red;                   /* Red channel value(6 or 8 bits) */
+    uint8_t   Alignment;             /* DWORD alignment byte (unused) */
+struct VBE_SupVbeInfoBlock {
+    uint8_t   SupVbeSignature[7];    /* Supplemental VBE Signature */
+    uint16_t  SupVbeVersion;         /* Supplemental VBE Version */
+    uint8_t   SupVbeSubFunc[8];      /* Bitfield of supported subfunctions */
+    uint16_t  OemSoftwareRev;        /* OEM Software revision */
+    uint8_t   Reserved[221];         /* Reserved for description
+                                        strings and future */
+    /*  expansion */
+/* VbeInfoBlock Capabilities */
+/*  D0 = 0  DAC is fixed width, with 6 bits per primary color */
+/*     = 1 DAC width is switchable to 8 bits per primary color */
+#define VBE_DACswitchableMask     0x0001
+/*  D1 = 0 Controller is VGA compatible */
+/*     = 1 Controller is not VGA compatible */
+#define VBE_notVGAcompatibleMask  0x0002
+/*  D2 = 0 Normal RAMDAC operation */
+/*     = 1 When programming large blocks of information to the RAMDAC,
+            use the blank bit in Function 09h. */
+#define VBE_specialRAMDACopMask   0x0004
+/*  D3 = 0 No hardware stereoscopic signaling support */
+/*     = 1 Hardware stereoscopic signaling supported by controller */
+#define VBE_hwStereoscopicMask    0x0008
+/*  D4 = 0 Stereo signaling supported via external VESA stereo connector */
+/*     = 1 Stereo signaling supported via VESA EVC connector */
+#define VBE_supportEVCconnMask    0x0010
+/*  D5-31 = Reserved */
+/* ModeInfoBlock ModeAttributes */
+/*  D0 =  Mode supported by hardware configuration */
+/*   0 =  Mode not supported in hardware */
+/*   1 =  Mode supported in hardware */
+#define VBE_modSupInHWMask        0x0001
+/*  D1 =  1 (Reserved) */
+/*  D2 =  TTY Output functions supported by BIOS */
+/*   0 =  TTY Output functions not supported by BIOS */
+/*   1 =  TTY Output functions supported by BIOS */
+#define VBE_TTYOutSupByBIOSMask   0x0004
+/*  D3 =  Monochrome/color mode (see note below) */
+/*   0 =  Monochrome mode */
+/*   1 =  Color mode */
+#define VBE_ColorModeMask         0x0008
+/*  D4 =  Mode type */
+/*   0 =  Text mode */
+/*   1 =  Graphics mode */
+#define VBE_GraphicsModeMask      0x0010
+/*  D5 =  VGA compatible mode */
+/*   0 =  Yes */
+/*   1 =  No */
+#define VBE_VGACompModeMask       0x0020
+/*  D6 =  VGA compatible windowed memory mode is available */
+/*   0 =  Yes */
+/*   1 =  No */
+#define VBE_VGACompWinMemModeMask 0x0040
+/*  D7 =  Linear frame buffer mode is available */
+/*   0 =  No */
+/*   1 =  Yes */
+#define VBE_LinFraBufModeAvaiMask 0x0080
+/*  D8 =  Double scan mode is available */
+/*   0 =  No */
+/*   1 =  Yes */
+#define VBE_DblScnModeAvaiMask    0x0100
+/*  D9 =  Interlaced mode is available */
+/*   0 =  No */
+/*   1 =  Yes */
+#define VBE_InterlModeAvaiMask    0x0200
+/*  D10 =  Hardware triple buffering support */
+/*   0 =  No */
+/*   1 =  Yes */
+#define VBE_HWTripBufSupMask      0x0400
+/*  D11 =  Hardware stereoscopic display support */
+/*   0 =  No */
+/*   1 =  Yes */
+#define VBE_HWSterDispSupMask     0x0800
+/*  D12 =  Dual display start address support */
+/*   0 =  No */
+/*   1 =  Yes */
+#define VBE_DualDispStAdrSupMask  0x1000
+/*  D13-D15 =  Reserved */
+/* ModeInfoBlock WinXAttributes */
+/*  D0 =  Relocatable window(s) supported */
+/*   0 =  Single non-relocatable window only */
+/*   1 =  Relocatable window(s) are supported */
+#define VBE_RelocWinSupMask       0x01
+/*  D1 =  Window readable */
+/*   0 =  Window is not readable */
+/*   1 =  Window is readable */
+#define VBE_WinReadableMask       0x02
+/*  D2 =  Window writeable */
+/*   0 =  Window is not writeable */
+/*   1 =  Window is writeable */
+#define VBE_WinWritableMask       0x04
+/*  D3-D7 =  Reserved */
+/* ModeInfoBlock MemoryModel */
+#define VBE_TextMode              0x00
+#define VBE_CGAGraphics           0x01
+#define VBE_HerculesGraphics      0x02
+#define VBE_Planar                0x03
+#define VBE_PackedPixel           0x04
+#define VBE_NonChain4Color256     0x05
+#define VBE_DirectColor           0x06
+#define VBE_YUV                   0x07
+    /* 0x08-0x0F Reserved, to be defined by VESA */
+    /* 0x10-0xFF To be defined by OEM */
+/* ModeInfoBlock DirectColorModeInfo */
+/*  D0 =  Color ramp is fixed/programmable */
+/*   0 =  Color ramp is fixed */
+/*   1 =  Color ramp is programmable */
+#define VBE_ColRampProgMask       0x01
+/*  D1 =  Bits in Rsvd field are usable/reserved */
+/*   0 =  Bits in Rsvd field are reserved */
+/*   1 =  Bits in Rsvd field are usable by the application */
+#define VBE_RsvdBitsUsableMask    0x02
+/* CRTCInfoBlock Flags */
+/*  D0 =  Double Scan Mode Enable */
+/*   0 =  Graphics mode is not double scanned */
+/*   1 =  Graphics mode is double scanned */
+#define VBE_GrModeDblScanMask     0x01
+/*  D1 =  Interlaced Mode Enable */
+/*   0 =  Graphics mode is non-interlaced */
+/*   1 =  Graphics mode is interlaced */
+#define VBE_GrModeInterlMask      0x02
+/*  D2 =  Horizontal sync polarity */
+/*   0 =  Horizontal sync polarity is positive (+) */
+/*   1 =  Horizontal sync polarity is negative (-) */
+#define VBE_HorSncPolNegMask      0x04
+/*  D3 =  Vertical sync polarity */
+/*   0 =  Vertical sync polarity is positive (+) */
+/*   1 =  Vertical sync polarity is negative (-) */
+#define VBE_VerSncPolNegMask      0x08
+/*  VESA BIOS Extensions/Display Data Channel Standard
+    Version: 1.1 November 18, 1999                      */
+/* VBE/DDC subfunction numbers - passed in BL register */
+#define VBEDDC_Capabilities    0x0   /* Report VBE/DDC Capabilities */
+#define VBEDDC_ReadEDID        0x1   /* Read EDID */
+/* DDC Capabilities */
+/* DDC level supported - returned in BL register */
+/* 0 - DDC1 not supported; 1 - DDC1 supported */
+#define VBEDDC_1SupportedMask  0x1
+/* 0 - DDC2 not supported; 1 - DDC2 supported */
+#define VBEDDC_2SupportedMask  0x2
+/* 0 - Screen not blanked during data transfer;
+   1 - Screen blanked during data transfer */
+#define VBEDDC_scrBlnkDatTrMs  0x4
+/*  VESA BIOS Extensions/Serial Control Interface Standard
+    Version: 1.0 Revision: 2 Date: July 2, 1997         */
+/* VBE/SCI subfunction numbers - passed in BL register */
+#define VBESCI_ReportCapabil   0x10  /* Report VBE/SCI Capabilities */
+#define VBESCI_BegSCLSDACtrl   0x11  /* Begin SCL/SDA control */
+#define VBESCI_EndSCLSDACtrl   0x12  /* End SCL/SDA control */
+#define VBESCI_WrtSCLClkLine   0x13  /* Write SCL clock line */
+#define VBESCI_WrtSDADatLine   0x14  /* Write SDA data line */
+#define VBESCI_RdySCLClkLine   0x15  /* Read SCL clock line */
+#define VBESCI_RdySDADatLine   0x16  /* Read SDA data line */
+/* SCI Capabilities */
+/* I2C level supported - returned in BL register */
+#define VBESCI_capSCLwrtMask   0x1   /* Can write to SCL clock line */
+#define VBESCI_capSDAwrtMask   0x2   /* Can write to SDA data line */
+#define VBESCI_capSCLrdyMask   0x4   /* Can read from SCL clock line */
+#define VBESCI_capSDArdyMask   0x8   /* Can read from SDA data line */
+#ifdef __cplusplus
+#endif /* ASM */
diff --git a/c/src/lib/libbsp/i386/pc386/preinstall.am b/c/src/lib/libbsp/i386/pc386/preinstall.am
index 1ff9fb8..e02d9d5 100644
--- a/c/src/lib/libbsp/i386/pc386/preinstall.am
+++ b/c/src/lib/libbsp/i386/pc386/preinstall.am
@@ -147,6 +147,14 @@ $(PROJECT_INCLUDE)/i386_io.h: ../../i386/shared/comm/i386_io.h $(PROJECT_INCLUDE
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/i386_io.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/i386_io.h
+$(PROJECT_INCLUDE)/vbe3.h: include/vbe3.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/vbe3.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/vbe3.h
+$(PROJECT_INCLUDE)/edid.h: include/edid.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/edid.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/edid.h
 $(PROJECT_INCLUDE)/pcibios.h: ../../i386/shared/pci/pcibios.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/pcibios.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/pcibios.h
1.9.1
