[PATCH 9/9] shell: Use crypt_r() in rtems_shell_login_check()
Fri Nov 14 13:46:35 UTC 2014
Use '*" to disable shell login instead of '!' according to the Linux man
page.  Use getpwnam_r() instead of getpwnam().  Do not access the user
environment directly.
 cpukit/libmisc/shell/login_check.c | 45 ++++++++++++++++++++++++--------------
 testsuites/samples/fileio/init.c   | 13 +++++++----
 2 files changed, 38 insertions(+), 20 deletions(-)
diff --git a/cpukit/libmisc/shell/login_check.c b/cpukit/libmisc/shell/login_check.c
index 8be5be2..4b21aaf 100644
--- a/cpukit/libmisc/shell/login_check.c
+++ b/cpukit/libmisc/shell/login_check.c
@@ -5,7 +5,7 @@
- * Copyright (c) 2009 embedded brains GmbH and others.
+ * Copyright (c) 2009-2014 embedded brains GmbH and others.
  * embedded brains GmbH
  * Obere Lagerstr. 30
@@ -30,34 +30,47 @@
 #include <unistd.h>
 #include <pwd.h>
+#include <crypt.h>
 #include <rtems/shell.h>
-#include <rtems/userenv.h>
 bool rtems_shell_login_check(
   const char *user,
   const char *passphrase
-  struct passwd *pw = getpwnam( user);
+  char buf[256];
+  struct passwd *pw_res;
+  struct passwd pw;
+  int eno;
+  eno = getpwnam_r(user, &pw, &buf[0], sizeof(buf), &pw_res);
   /* Valid user? */
-  if (pw != NULL && strcmp( pw->pw_passwd, "!") != 0) {
+  if (eno == 0 && strcmp(pw.pw_passwd, "*") != 0) {
     rtems_shell_env_t *env = rtems_shell_get_current_env();
-    setuid( pw->pw_uid);
-    setgid( pw->pw_gid);
-    rtems_current_user_env->euid = 0;
-    rtems_current_user_env->egid = 0;
-    if (env)
-      chown( env->devname, pw->pw_uid, 0);
-    rtems_current_user_env->euid = pw->pw_uid;
-    rtems_current_user_env->egid = pw->pw_gid;
-    if (strcmp( pw->pw_passwd, "*") == 0) {
-      /* TODO: /etc/shadow */
+    if (env != NULL) {
+      chown(env->devname, pw.pw_uid, 0);
+    setuid(pw.pw_uid);
+    setgid(pw.pw_gid);
+    seteuid(pw.pw_uid);
+    setegid(pw.pw_gid);
+    if (strcmp(pw.pw_passwd, "") == 0) {
       return true;
+    } else if (strcmp(pw.pw_passwd, "x") == 0) {
+      /* TODO: /etc/shadow */
+      return false;
     } else {
-      /* TODO: crypt() */
-      return true;
+      struct crypt_data data;
+      char *s;
+      s = crypt_r(passphrase, pw.pw_passwd, &data);
+      return strcmp(s, pw.pw_passwd) == 0;
diff --git a/testsuites/samples/fileio/init.c b/testsuites/samples/fileio/init.c
index 2b60922..735b588 100644
--- a/testsuites/samples/fileio/init.c
+++ b/testsuites/samples/fileio/init.c
@@ -13,6 +13,7 @@
 #define CONFIGURE_INIT
 #include "system.h"
+#include <crypt.h>
 #include <unistd.h>
@@ -641,10 +642,11 @@ static void fileio_start_shell(void)
   writeFile(
     "/etc/passwd",
     0644,
-    "root:7QR4o148UPtb.:0:0:root::/:/bin/sh\n"
-    "rtems:*:1:1:RTEMS Application::/:/bin/sh\n"
-    "test:8Yy.AaxynxbLI:2:2:test account::/:/bin/sh\n"
-    "tty:!:3:3:tty owner::/:/bin/false\n"
+    "root:$6$$FuPOhnllx6lhW2qqlnmWvZQLJ8Thr/09I7ESTdb9VbnTOn5.65"
+      "/Vh2Mqa6FoKXwT0nHS/O7F0KfrDc6Svb/sH.:0:0:root::/:/bin/sh\n"
+    "rtems::1:1:RTEMS Application::/:/bin/sh\n"
+    "test:$1$$oPu1Xt2Pw0ngIc7LyDHqu1:2:2:test account::/:/bin/sh\n"
+    "tty:*:3:3:tty owner::/:/bin/false\n"
   writeFile(
     "/etc/group",
@@ -1225,6 +1227,9 @@ Init (rtems_task_argument ignored)
   TEST_BEGIN();
+  crypt_add_format(&crypt_md5_format);
+  crypt_add_format(&crypt_sha512_format);
   status = rtems_shell_wait_for_input(
     STDIN_FILENO,
     20,
1.8.4.5
