gdb patches to RBS
Sat Nov 15 00:14:36 UTC 2014
On 15/11/2014 10:30 am, Jiri Gaisler wrote:
> On 11/14/2014 02:34 AM, Chris Johns wrote:
>> On 14/11/2014 9:12 am, Jiri Gaisler wrote:
>>> What is the procedure to add gdb patches to RBS?
>> Patches are first accepted by the RTEMS Project as the definition of the tools belongs to the project and tool packagers, ie the RSB, need to adopt that definition to get a project tick. Patches should be posted upstream where possible and then referenced from there. If the
>> upstream does not have a suitable method to reference patches we can add them to the rtems-tools.git repo under the tools directory. There are specific cases such as the openrisc tools where a specific github instance is referenced as we have a positive undertaking from that
>> community the tools are being merged upstream. Examples of upstream patch referencing is qemu and patchworks.
>> I do not see a patch management system for gdb. There was talk back in April of this year of gdb using patchworks and then something else however it seems to have died out.
>>> I have a few patches that fixes the erc32 simulator and also
>>> add support for leon2 and leon3. This would allow us to drop
>>> the sis bsp, and also to test the leon2 and leon3 bsp's with
>>> sis.
>> Excellent. I suggest you provide git patches for the rtems-tools.git repo to add the patches and then provide RSB patches for the sparc gdb build to use them. There are specific sparc patches already present which need updating as they are currently stopping us moving off gdb-7.7.
> I tried to move RBS to gdb-7.8.1, but there were several other
> dependency problems that I could not (easily) fix.
Are these gdb, RSB, or rtems-tools patch issues ?
> So I have back-ported
> my patches to gdb-7.7 which seems to work equally well. I will send the
> patches for rtems-tools and rtems-source-builder to Chris off-list as the
> patch is quite large (300K). I built the sparc toolchain with RBS
> and copied the sis patch to rtems/patches manually since I have not
> write access to rtems-tools.git.
Thanks for this. I have the patch and will push to rtems-tools once we
can commit to the repos again.
