[PATCH 4/6] i386/shared/int16: real mode interrupt interface
Tue Nov 18 16:17:26 UTC 2014
On Tue, Nov 18, 2014 at 10:47 AM, Jan Dolezal <dolezj21 at fel.cvut.cz> wrote:
> On 12.11.2014 16:54, Gedare Bloom wrote:
>> On Wed, Nov 12, 2014 at 10:07 AM, Jan Dolezal <dolezj21 at fel.cvut.cz>
>> wrote:
>>>   c/src/lib/libbsp/i386/pc386/Makefile.am    |   2 +
>>>   c/src/lib/libbsp/i386/pc386/preinstall.am  |   4 +
>>>   c/src/lib/libbsp/i386/shared/int16/int16.c | 397
>>>   c/src/lib/libbsp/i386/shared/int16/int16.h |  93 +++++++
>>>   4 files changed, 496 insertions(+)
>>>   create mode 100644 c/src/lib/libbsp/i386/shared/int16/int16.c
>>>   create mode 100644 c/src/lib/libbsp/i386/shared/int16/int16.h
>> These new files should probably go under i386/shared/irq  ?
> I am using i386/shared/realmode_int/realmode_int.* now as suggested
> in conversation with Mr. Pisa
>>> diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am
>>> b/c/src/lib/libbsp/i386/pc386/Makefile.am
>>> index 9c901df..6042b5b 100644
>>> --- a/c/src/lib/libbsp/i386/pc386/Makefile.am
>>> +++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
>>> @@ -29,6 +29,7 @@ SUBDIRS = . tools
>>>   include_bsp_HEADERS  = ../../i386/shared/irq/irq.h
>>>   include_bsp_HEADERS += ../../i386/shared/irq/irq_asm.h
>>>   include_bsp_HEADERS += ../../i386/shared/comm/tty_drv.h
>>> +include_bsp_HEADERS += ../../i386/shared/int16/int16.h
>>>   include_bsp_HEADERS += ../../shared/include/irq-generic.h
>>>   include_bsp_HEADERS += ../../shared/include/irq-info.h
>>>   include_bsp_HEADERS += console/rtd316.h
>>> @@ -94,6 +95,7 @@ libbsp_a_SOURCES += console/kbd_parser.c
>>>   libbsp_a_SOURCES += console/serial_mouse_config.c
>>>   libbsp_a_SOURCES += ../../i386/shared/comm/uart.c
>>>   libbsp_a_SOURCES += ../../i386/shared/comm/tty_drv.c
>>> +libbsp_a_SOURCES += ../../i386/shared/int16/int16.c
>>>   libbsp_a_SOURCES += ../../shared/console.c
>>>   libbsp_a_SOURCES += console/console_select.c
>>>   libbsp_a_SOURCES += ../../shared/console_read.c
>>> diff --git a/c/src/lib/libbsp/i386/pc386/preinstall.am
>>> b/c/src/lib/libbsp/i386/pc386/preinstall.am
>>> index aff01dc..1ff9fb8 100644
>>> --- a/c/src/lib/libbsp/i386/pc386/preinstall.am
>>> +++ b/c/src/lib/libbsp/i386/pc386/preinstall.am
>>> @@ -69,6 +69,10 @@ $(PROJECT_INCLUDE)/bsp/tty_drv.h:
>>> ../../i386/shared/comm/tty_drv.h $(PROJECT_INC
>>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tty_drv.h
>>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tty_drv.h
>>> +$(PROJECT_INCLUDE)/bsp/int16.h: ../../i386/shared/int16/int16.h
>>> $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/int16.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/int16.h
>>>   $(PROJECT_INCLUDE)/bsp/irq-generic.h:
>>> ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
>>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
>>> diff --git a/c/src/lib/libbsp/i386/shared/int16/int16.c
>>> b/c/src/lib/libbsp/i386/shared/int16/int16.c
>>> new file mode 100644
>>> index 0000000..380188f
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/i386/shared/int16/int16.c
>>> @@ -0,0 +1,397 @@
>>> + *  Realmode interrupt call implementation.
>>> + *  Copyright (c) 2014 - CTU in Prague
>>> + *                       Jan Doležal ( dolezj21 at fel.cvut.cz )
>>> + *  The license and distribution terms for this file may be
>>> + *  found in the file LICENSE in this distribution or at
>>> + *  http://www.rtems.org/license/LICENSE.
>>> +#include <bsp/int16.h>
>>> +#include <string.h>
>> Why include string.h?
> It is here because later there are used functions memset() and memcpy(),
> which have their prototypes in string.h
>> I have more comments below in the .h file. I am not reviewing this .c
>> file due to time constraints and my lack of confidence in x86
>> assembly, but I will say if the below macros and struct defines are
>> useful outside this file, then they should go into a header file
>> instead. Also, I think we use __volatile__ for declaring ASM blocks.
>> (We ought to have an RTEMS macro for this, e.g. RTEMS_INLINE_ASM(),
>> but I don't think we do.)
> I don't think these macros are useful outside, they are used in inline
> asm and defined only for better readability of the inline asm.
> Quick grep over whole rtems source directory shows that
> '__asm__ __volatile__' is used ~110 times and
> '__asm__ volatile' is used ~680 times, but if __volatile__ is a better
> choice I will gladly use that one.
I guess it may not matter then.
>>> +#include <rtems/score/cpu.h>
>>> +#define IR_EAX_OFF      "0x00"
>>> +#define IR_EBX_OFF      "0x04"
>>> +#define IR_ECX_OFF      "0x08"
>>> +#define IR_EDX_OFF      "0x0C"
>>> +#define IR_ESI_OFF      "0x10"
>>> +#define IR_EDI_OFF      "0x14"
>>> +#define IR_DS_OFF       "0x18"
>>> +#define IR_ES_OFF       "0x1A"
>>> +#define IR_FS_OFF       "0x1C"
>>> +#define IR_GS_OFF       "0x1E"
>>> +#define BKP_ESP_OFF     "0x20"
>>> +#define BKP_SS_OFF      "0x24"
>>> +#define BKP_DS_OFF      "0x26"
>>> +#define RM_ENTRY        "0x28"
>>> +#define PM_ENTRY        "0x2C"
>>> +/* parameters, results, backup values accessible in real mode */
>>> +struct rm_int_regs_bkp_param {
>>> +    struct interrupt_registers inoutregs;
>>> +    uint32_t pm_esp_bkp;
>>> +    uint16_t pm_ss_bkp;
>>> +    uint16_t ds_bkp;
>>> +    uint16_t rm_entry;
>>> +    uint16_t rm_code_segment;
>>> +    uint32_t pm_entry;
>>> +    uint16_t pm_code_selector;
>>> +    /* if modifying update offset definitions as well */
>>> +}__attribute__((__packed__));
>>> +#define BKP_IDTR_LIM    "0x00"
>>> +#define BKP_IDTR_BASE   "0x02"
>>> +#define BKP_ES_OFF      "0x06"
>>> +#define BKP_FS_OFF      "0x08"
>>> +#define BKP_GS_OFF      "0x0A"
>>> +#define RML_ENTRY       "0x0C"
>>> +#define RML_D_SEL       "0x12"
>>> +#define RM_SS           "0x14"
>>> +#define RM_SP           "0x16"
>>> +#define RM_DS           "0x18"
>>> +/* backup values, pointers/parameters accessible in protected mode */
>>> +struct pm_bkp_and_param {
>>> +    uint16_t idtr_lim_bkp;
>>> +    uint32_t idtr_base_bkp;
>>> +    uint16_t es_bkp;
>>> +    uint16_t fs_bkp;
>>> +    uint16_t gs_bkp;
>>> +    uint32_t rml_entry;
>>> +    uint16_t rml_code_selector;
>>> +    uint16_t rml_data_selector;
>>> +    uint16_t rm_stack_segment;
>>> +    uint16_t rm_stack_pointer;
>>> +    uint16_t rm_data_segment;
>>> +/* addresses where we are going to put Interrupt buffer,
>>> + * parameter/returned/preserved values, stack and copy code
>>> + * for calling BIOS interrupt real mode interface
>>> + * The value is chosen arbitrarily in the first 640kB
>>> + * to be accessible for real mode. It should be out of range
>>> + * used by RTEMS because its base address is above 1MB.
>>> + * It has to be above first 4kB (or better 64kB) which could
>>> + * be used by BIOS.
>>> +#define REAL_MODE_SPOT   0x12000
>>> +/* REAL_MODE_SPOT value is also top of real mode stack */
>>> +/* buffers positions and lengths */
>>> +#define DEFAULT_BUFFER_SIZE             512
>>> +static void *first_rm_buffer_spot = (void *)REAL_MODE_SPOT;
>>> +static uint16_t first_rm_buffer_size = DEFAULT_BUFFER_SIZE;
>>> +/* real mode stack */
>>> +#define STACK_SIZE                      8192
>>> +#define INT_STACK_TOP                   REAL_MODE_SPOT
>>> + * STACK            *         *
>>> + ****************************** REAL_MODE_SPOT
>>> + * INT_BUF          * 512 B   *
>>> + * INT_REGs         *  50 B   *
>>> + * INT_FNC          *~149 B   *
>>> +#define __DP_TYPE       uint8_t
>>> +#define __DP_YES        ((__DP_TYPE)1)
>>> +#define __DP_NO         ((__DP_TYPE)-1)
>>> +#define __DP_FAIL       ((__DP_TYPE)0)
>>> +static __DP_TYPE descsPrepared = __DP_NO;
>>> +/* rml - real mode alike */
>>> +#define rml_limit 0xFFFF
>>> +static uint16_t rml_code_dsc_index = 0;
>>> +static uint16_t rml_data_dsc_index = 0;
>>> + * Prepares real-mode like descriptors to be used for switching
>>> + * to real mode.
>>> + * @return __DP_YES descriptors are prepared
>>> + * @return __DP_FAIL descriptors allocation failed (GDT too small)
>>> +static __DP_TYPE prepareRMDescriptors (void *base32) {
>>> +    static void *prevBase = (void *)-1;
>>> +    /* check if descriptors were prepared already */
>>> +    if (descsPrepared == __DP_YES && prevBase == base32)
>>> +        return descsPrepared;
>>> +    if (descsPrepared == __DP_FAIL)
>>> +    /* create 'real mode like' segment descriptors, for switching to
>>> real mode */
>>> +    rml_code_dsc_index = i386_next_empty_gdt_entry();
>>> +    if (rml_code_dsc_index == 0)
>>> +        /* not enough space in GDT */
>>> +        descsPrepared = __DP_FAIL;
>>> +    segment_descriptors flags_desc;
>>> +    memset(&flags_desc, 0, sizeof(flags_desc));
>>> +    flags_desc.type                = 0xE;      /* bits 4  */
>>> +    flags_desc.descriptor_type     = 0x1;      /* bits 1  */
>>> +    flags_desc.privilege           = 0x0;      /* bits 2  */
>>> +    flags_desc.present             = 0x1;      /* bits 1  */
>>> +    flags_desc.available           = 0x0;      /* bits 1  */
>>> +    flags_desc.fixed_value_bits    = 0x0;      /* bits 1  */
>>> +    flags_desc.operation_size      = 0x0;      /* bits 1  */
>>> +    flags_desc.granularity         = 0x0;      /* bits 1  */
>>> +    i386_fill_segment_desc_base((unsigned)base32, &flags_desc);
>>> +    i386_fill_segment_desc_limit(rml_limit, &flags_desc);
>>> +    if (i386_raw_gdt_entry(rml_code_dsc_index, &flags_desc) == 0)
>>> +        /* selector to GDT out of range */
>>> +    rml_data_dsc_index = i386_next_empty_gdt_entry();
>>> +    if (rml_data_dsc_index == 0)
>>> +        /* not enough space in GDT for both descriptors */
>>> +    flags_desc.type                = 0x2;      /* bits 4  */
>>> +    if (i386_raw_gdt_entry(rml_data_dsc_index, &flags_desc) == 0)
>>> +    prevBase = base32;
>>> +    descsPrepared = __DP_YES;
>>> +inline void *i386_get_primary_rm_buffer() {
>>> +    return first_rm_buffer_spot;
>>> +inline uint16_t i386_get_primary_rm_buffer_size() {
>>> +    return first_rm_buffer_size;
>>> +int i386_real_interrupt_call(uint8_t interruptNumber, struct
>>> interrupt_registers *ir){
>>> +    uint32_t pagingon;
>>> +    struct rm_int_regs_bkp_param *int_passed_regs_spot;
>>> +    /* place where the code switching to realmode and executing
>>> +       interrupt is coppied */
>>> +    void *rm_swtch_code_dst;
>>> +    void *rm_stack_top;
>>> +    size_t cpLength;
>>> +    void *cpBeg;
>>> +    /* values that can be passed from protected mode are stored in this
>>> struct
>>> +       and they are passed later to the inline assembler executing
>>> interrupt */
>>> +    volatile struct pm_bkp_and_param pm_bkp, *pm_bkp_addr;
>>> +    unsigned short unused_offset;
>>> +    __asm__ volatile(   "\t"
>>> +        "movl    %%cr0, %%eax\n\t"
>>> +        "andl    %1, %%eax\n"
>>> +        : "=a"(pagingon)
>>> +        : "i"(CR0_PAGING)
>>> +    if (pagingon)
>>> +        return 0;
>>> +    /* located under 1MB for real mode to be able to get/set values */
>>> +    int_passed_regs_spot = (struct rm_int_regs_bkp_param *)
>>> (first_rm_buffer_spot+first_rm_buffer_size);
>>> +    /* position for real mode code reallocation to the first 1MB of RAM
>>> +    rm_swtch_code_dst = (void
>>> *)((uint32_t)int_passed_regs_spot+sizeof(*int_passed_regs_spot));
>>> +    rm_stack_top = (void *)INT_STACK_TOP;
>>> +    if (prepareRMDescriptors(int_passed_regs_spot) != __DP_YES)
>>> +        return 0;
>>> +    pm_bkp_addr = &pm_bkp;
>>> +    i386_Physical_to_real_mode_ptr(
>>> +        rm_stack_top - STACK_SIZE,
>>> +        (unsigned short *)&pm_bkp.rm_stack_segment,
>>> +        (unsigned short *)&pm_bkp.rm_stack_pointer
>>> +    pm_bkp.rm_stack_pointer += STACK_SIZE;
>>> +    pm_bkp.rml_code_selector = (rml_code_dsc_index<<3);
>>> +    pm_bkp.rml_entry =
>>> ((uint32_t)rm_swtch_code_dst-(uint32_t)int_passed_regs_spot);
>>> +    pm_bkp.rml_data_selector = (rml_data_dsc_index<<3);
>>> +        int_passed_regs_spot,
>>> +        (unsigned short *)&pm_bkp.rm_data_segment,
>>> +        &unused_offset
>>> +    int_passed_regs_spot->inoutregs = *ir;
>>> +    /* offset from the beginning of coppied code */
>>> +    uint16_t rm_entry_offset;
>>> +    __asm__ volatile(
>>> +        "movw   $(rment-cp_beg), %0\n\t"
>>> +        : "=r"(rm_entry_offset)
>>> +        rm_swtch_code_dst+rm_entry_offset,
>>> +        (unsigned short *)&int_passed_regs_spot->rm_code_segment,
>>> +        (unsigned short *)&int_passed_regs_spot->rm_entry
>>> +    __asm__ volatile(
>>> +        "movl   $(cp_end), %0\n\t"
>>> +        "movw   %%cs, %1\n\t"
>>> +        : "=mr"(int_passed_regs_spot->pm_entry),
>>> "=mr"(int_passed_regs_spot->pm_code_selector)
>>> +    /* copy code for switch to real mode and executing interrupt to
>>> first MB of RAM */
>>> +        "mov    $cp_end-cp_beg, %0\n\t"
>>> +        "mov    $cp_beg, %1\n\t"
>>> +        : "=rm"(cpLength), "=rm"(cpBeg)
>>> +    memcpy(rm_swtch_code_dst, cpBeg, cpLength);
>>> +    /* write interrupt number to be executed */
>>> +    uint16_t interrupt_number_off;
>>> +    uint8_t *interrupt_number_ptr;
>>> +        "movw   $intnum-cp_beg, %0\n\t"
>>> +        : "=rm"(interrupt_number_off)
>>> +    interrupt_number_ptr = (uint8_t *)
>>> (rm_swtch_code_dst+interrupt_number_off);
>>> +    *interrupt_number_ptr = interruptNumber;
>>> +    /* execute code that jumps to coppied function, which switches to
>>> real mode,
>>> +       loads registers with values passed to interrupt and executes
>>> interrupt */
>>> +        /* backup stack */
>>> +        "movl    %[regs_spot], %%ebx\n\t"
>>> +        "movl    %%esp, "BKP_ESP_OFF"(%%ebx)\n\t"
>>> +        "movw    %%ss,  "BKP_SS_OFF"(%%ebx)\n\t"
>>> +        /* backup data selector */
>>> +        "movw    %%ds,  "BKP_DS_OFF"(%%ebx)\n\t"
>>> +        /* backup other selectors */
>>> +        "movl    %[pm_bkp], %%esi\n\t"
>>> +        "movw    %%es, "BKP_ES_OFF"(%%esi)\n\t"
>>> +        "movw    %%fs, "BKP_FS_OFF"(%%esi)\n\t"
>>> +        "movw    %%gs, "BKP_GS_OFF"(%%esi)\n\t"
>>> +        /* hopefully loader does not damage interrupt table on the
>>> beginning of memory; that means length: 0x3FF, base: 0x0 */
>>> +        /* preserve idtr */
>>> +        "movl    %%esi, %%eax\n\t"
>>> +        "addl    $"BKP_IDTR_LIM", %%eax\n\t"
>>> +        "cli\n\t"
>>> +        "sidt    (%%eax)\n\t"
>>> +        "movl    $rmidt, %%eax\n\t"
>>> +        "lidt    (%%eax)\n\t"
>>> +        /* prepare 'real mode like' data selector */
>>> +        "movw    "RML_D_SEL"(%%esi), %%ax\n\t"
>>> +        /* prepare real mode data segment value */
>>> +        "xorl    %%edx,%%edx\n\t"
>>> +        "movw    "RM_DS"(%%esi), %%dx\n\t"
>>> +        /* prepare real mode stack values */
>>> +        "movw    "RM_SS"(%%esi), %%cx\n\t"
>>> +        "movzwl  "RM_SP"(%%esi), %%esp\n\t"
>>> +        /* jump to copied function and */
>>> +        /* load 'real mode like' code selector */
>>> +        "ljmp   *"RML_ENTRY"(%%esi)\n"
>>> +"rmidt:"/* limit and base for realmode interrupt descriptor table */
>>> +        ".word 0x3FF\n\t"
>>> +        ".long 0\n\t"
>>> +        /* load 'real mode like' data selectors */
>>> +"cp_beg: .code16\n\t"
>>> +        "movw    %%ax, %%ss\n\t"
>>> +        "movw    %%ax, %%ds\n\t"
>>> +        "movw    %%ax, %%es\n\t"
>>> +        "movw    %%ax, %%fs\n\t"
>>> +        "movw    %%ax, %%gs\n\t"
>>> +        /* disable protected mode */
>>> +        "and     %[cr0_prot_dis], %%ax\n\t"
>>> +        "movl    %%eax, %%cr0\n\t"
>>> +        /* base for data selector of 16-bit protected mode is at
>>> beginning of passed regs */
>>> +        /* flush prefetch queue by far jumping */
>>> +        "ljmp    *"RM_ENTRY"\n\t"
>>> +"rment: "
>>> +        /* establish rm stack - esp was already set in 32-bit protected
>>> mode*/
>>> +        "movw    %%cx, %%ss\n\t"
>>> +        /* set data segment (value prepared in 32-bit prot mode) */
>>> +        "movw    %%dx, %%ds\n\t"
>>> +        /* count real mode pointer so we don't need to overuse address
>>> prefix (by using 32bit address) */
>>> +        "shll    $4,%%edx\n\t"
>>> +        "subl    %%edx,%%ebx\n\t"
>>> +        /* prepare values to be used after interrupt call */
>>> +        "pushw   %%bx\n\t"
>>> +        "pushw   %%ds\n\t"
>>> +        /* fill registers with parameters */
>>> +        "movw    " IR_DS_OFF"(%%bx), %%ax\n\t"
>>> +        "pushw   %%ax\n\t"
>>> +        "movl    "IR_EAX_OFF"(%%bx), %%eax\n\t"
>>> +        "movl    "IR_ECX_OFF"(%%bx), %%ecx\n\t"
>>> +        "movl    "IR_EDX_OFF"(%%bx), %%edx\n\t"
>>> +        "movl    "IR_EDI_OFF"(%%bx), %%edi\n\t"
>>> +        "movl    "IR_ESI_OFF"(%%bx), %%esi\n\t"
>>> +        "movw    " IR_ES_OFF"(%%bx), %%es\n\t"
>>> +        "movw    " IR_FS_OFF"(%%bx), %%fs\n\t"
>>> +        "movw    " IR_GS_OFF"(%%bx), %%gs\n\t"
>>> +        /* prepare ebx register */
>>> +        "movl    "IR_EBX_OFF"(%%bx), %%ebx\n\t"
>>> +        /* prepare ds */
>>> +        "popw    %%ds\n\t"
>>> +        /* interrupt instruction */
>>> +        ".byte   0xCD\n\t"
>>> +"intnum: .byte   0x0\n\t"
>>> +        /* fill return structure */
>>> +        "pushw   %%ds\n\t"
>>> +        "pushl   %%ebx\n\t"
>>> +        "movw    0x6(%%esp), %%ds\n\t"
>>> +        "movw    0x8(%%esp),%%bx\n\t" /* regs_spot */
>>> +        "movl    %%eax,"IR_EAX_OFF"(%%bx)\n\t"
>>> +        "popl    %%eax\n\t"
>>> +        "movl    %%eax,"IR_EBX_OFF"(%%bx)\n\t"
>>> +        "movl    %%ecx,"IR_ECX_OFF"(%%bx)\n\t"
>>> +        "movl    %%edx,"IR_EDX_OFF"(%%bx)\n\t"
>>> +        "movl    %%esi,"IR_ESI_OFF"(%%bx)\n\t"
>>> +        "movl    %%edi,"IR_EDI_OFF"(%%bx)\n\t"
>>> +        "popw    %%ax\n\t"
>>> +        "movw    %%ax, " IR_DS_OFF"(%%bx)\n\t"
>>> +        "movw    %%es, " IR_ES_OFF"(%%bx)\n\t"
>>> +        "movw    %%fs, " IR_FS_OFF"(%%bx)\n\t"
>>> +        "movw    %%gs, " IR_GS_OFF"(%%bx)\n\t"
>>> +        /* prepare protected mode data segment */
>>> +        "movw    "BKP_DS_OFF"(%%bx), %%ax\n\t"
>>> +        /* restore protected mode stack values */
>>> +        "movl    "BKP_ESP_OFF"(%%bx),%%esp\n\t"
>>> +        "movw    "BKP_SS_OFF"(%%bx), %%dx\n\t"
>>> +        /* return to protected mode */
>>> +        "movl    %%cr0, %%ecx     \n\t"
>>> +        "or      %[cr0_prot_ena], %%cx\n\t"
>>> +        "movl    %%ecx, %%cr0     \n\t"
>>> +        "ljmpl   *"PM_ENTRY"(%%bx)\n\t"
>>> +        ".code32\n"
>>> +        /* reload segmentation registers */
>>> +"cp_end:"
>>> +        /* restore stack segment in protected mode context */
>>> +        "movw    %%dx, %%ss\n\t"
>>> +        "movw    "BKP_ES_OFF"(%%esi), %%es\n\t"
>>> +        "movw    "BKP_FS_OFF"(%%esi), %%fs\n\t"
>>> +        "movw    "BKP_GS_OFF"(%%esi), %%gs\n\t"
>>> +        /* restore IDTR */
>>> +        "addl    $"BKP_IDTR_LIM", %%esi\n\t"
>>> +        "lidt    (%%esi)\n\t"
>>> +        : [regs_spot]"m"(int_passed_regs_spot),
>>> [pm_bkp]"m"(pm_bkp_addr), [cr0_prot_ena]"i"(CR0_PROTECTION_ENABLE),
>>> [cr0_prot_dis]"i"(~CR0_PROTECTION_ENABLE)
>>> +        : "memory", "ebx", "ecx", "edx", "esi", "edi"
>>> +    *ir = int_passed_regs_spot->inoutregs;
>>> +    return 1;
>>> diff --git a/c/src/lib/libbsp/i386/shared/int16/int16.h
>>> b/c/src/lib/libbsp/i386/shared/int16/int16.h
>>> index 0000000..96025ef
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/i386/shared/int16/int16.h
>>> @@ -0,0 +1,93 @@
>>> + * @file int16.h
>>> + * @ingroup i386_shared
>>> + * @brief Definitioins supporting real mode interrupt calls.
>>> + *  Interface allows calling given interrupt number with content of the
>>> + *  registers defined. For passing or receiving higher amounts of the
>>> data
>>> + *  there is a buffer accessible from real mode available. Real mode
>>> pointer
>>> + *  to this buffer is passed to the interrupt in the registers.
>>> + * Copyright (C) 2014  Jan Doležal (dolezj21 at fel.cvut.cz)
>>> + *                     CTU in Prague.
>>> +#ifndef _INT16_H
>>> +#define _INT16_H
>>> +#include <libcpu/cpu.h>
>>> +#include <stdint.h>
>>> +#ifndef ASM /* ASM */
>>> +#ifdef __cplusplus
>>> +extern "C" {
>>> +#endif /* __cplusplus */
>>> +/* --- BIOS service interrupt number --- */
>>> +/* number of interrupt servicing video functions */
>>> +#define INTERRUPT_NO_VIDEO_SERVICES 0x10
>>> +struct interrupt_registers { /* used for passing parameters, fetching
>>> results and preserving values */
>>> +    uint32_t reg_eax;
>>> +    uint32_t reg_ebx;
>>> +    uint32_t reg_ecx;
>>> +    uint32_t reg_edx;
>>> +    uint32_t reg_esi;
>>> +    uint32_t reg_edi;
>>> +    uint16_t reg_ds;
>>> +    uint16_t reg_es;
>>> +    uint16_t reg_fs;
>>> +    uint16_t reg_gs;
>> RTEMS prefers to use typedef on struct names. Also, the name should be
>> "namespaced", for example, i386_interrupt_registers. Usually I would
>> expect to see this kind of structure in
>> score/cpu/i386/rtems/score/i386.h defined as an interrupt context
>> structure. I think ARM has an example.
> I've chosen i386_realmode_interrupt_registers
> I believe the reasons from conversation with Mr. Pisa also apply
> here - to keep this separately from x86 protected mode runtime support.
>> Is __packed__ necessary? We avoid compiler attributes where possible,
>> and where necessary we should use a macro e.g. RTEMS_PACKED_STRUCT (or
>> something, if it exists).
> for moxie and h8300 there is
> #define nogap __attribute__ ((packed))
> in score - cpu.h
> and for arm bsp
> #define PACKED __attribute__ ((packed))
> in jtypes.h
> but I have not found such thing for i386
I'd prefer to see you define a generic macro in
score/include/rtems/score/basedefs.h along the same lines as the other
RTEMS_COMPILER macros, e.g. RTEMS_COMPILER_PACKED_ATTRIBUTE, as a
separate patch to apply before yours.
Time permitting, you could also cleanup the other placed that packed
is used to the new macro.
>>> + * provides position to real mode buffer, which is buffer
>>> + * accessible from real mode context - it is located below
>>> + * address ~0x100000 in order for it to be accessible
>>> + * This buffer is meant to be pointed to by segReg:GenPurpReg
>>> + * and through this get bigger portion of information to/from
>>> + * interrupt service routine.
>>> + * @return pointer to buffer
>>> +extern void *i386_get_primary_rm_buffer(void);
>> avoid abbreviations, use realmode
>> What does "primary"  mean? Is there a "secondary"? If not, just use
>> i386_get_realmode_buffer().
> If there was ever need to add another buffer this could make things
> easier.
> Is it ok if I use i386_get_default_realmode_buffer()?
Seems fine by me.
-Gedare
>>> + * returns size of real mode buffer
>>> + * @return size of buffer
>>> +extern uint16_t i386_get_primary_rm_buffer_size(void);
>> The above two functions can be merged together, where the buffer is
>> returned and the size gets set as a side-effect, if that is useful.
> ok
>>> +/* if there is ever need to have more buffers or setting size of the
>>> buffer,
>>> + * feel free to modify the code */
>>> + * This function allows calling interrupts in real mode and to set
>>> processor
>>> + * registers as desired before interrupt call is made and to retrieve
>>> the
>>> + * registers content after call was made.
>>> + * @param interruptNumber interrupt number to be called
>>> + * @param ir pointer to structure containing registers to be passed to
>>> interrupt
>>> + *        and to retrieve register content after call was made.
>>> + * @return  0 call failed (GDT too small or pagin is on)
>>> + *          1 call successful
>>> +extern int i386_real_interrupt_call(uint8_t interruptNumber, struct
>>> interrupt_registers *ir);
>>> +#ifdef __cplusplus
>>> +#endif /* ASM */
>>> +#endif /* _INT16_H */
>>> 1.9.1
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> Thank you,
> Jan Dolezal
