[PATCH 2/4] sys/mman.h: New file. Clean up and add supporting stubs
Wed Nov 19 22:04:21 UTC 2014
On 11/19/2014 2:55 PM, Gedare Bloom wrote:
> Is this the same one that Chris has had in use before? (I think that
> is who had one in use..)
Yes. You wanted it in rtems to avoid me having to add a prototype to a file
to avoid a warning.
I didn't integrate his implementation but only his .h file and stubs. His
implementation will need the addition of tests and code in confdefs.h.
--joel
> -Gedare
> On Wed, Nov 19, 2014 at 2:59 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>>         * Makefile.am updated and preinstall.am regenerated.
>>         * mprotect.c had a prototype removed now that we have mman.h
>>         * mmap.c, munmap.c: New stub files.
>>  cpukit/posix/Makefile.am        |   5 ++
>>  cpukit/posix/include/sys/mman.h | 189 ++++++++++++++++++++++++++++++++++++++++
>>  cpukit/posix/preinstall.am      |   9 ++
>>  cpukit/posix/src/mmap.c         |  26 ++++++
>>  cpukit/posix/src/mprotect.c     |  10 +--
>>  cpukit/posix/src/munmap.c       |  30 +++++++
>>  6 files changed, 261 insertions(+), 8 deletions(-)
>>  create mode 100644 cpukit/posix/include/sys/mman.h
>>  create mode 100644 cpukit/posix/src/mmap.c
>>  create mode 100644 cpukit/posix/src/munmap.c
>> diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
>> index 346b65a..b3be07c 100644
>> --- a/cpukit/posix/Makefile.am
>> +++ b/cpukit/posix/Makefile.am
>> @@ -21,6 +21,9 @@ include_rtems_posix_HEADERS += include/rtems/posix/keyimpl.h
>>  include_rtems_posix_HEADERS += include/rtems/posix/config.h
>>  include_rtems_posix_HEADERS += include/rtems/posix/posixapi.h
>> +include_sysdir = $(includedir)/sys
>> +include_sys_HEADERS = include/sys/mman.h
>>  if HAS_PTHREADS
>>  # include
>>  include_HEADERS = include/aio.h
>> @@ -91,7 +94,9 @@ libposix_a_SOURCES += src/cond.c src/condattrdestroy.c \
>>      src/condtimedwait.c src/condwait.c src/condwaitsupp.c src/condget.c
>>  ## MEMORY_C_FILES
>> +libposix_a_SOURCES += src/mmap.c
>>  libposix_a_SOURCES += src/mprotect.c
>> +libposix_a_SOURCES += src/munmap.c
>>  ## MESSAGE_QUEUE_C_FILES
>>  libposix_a_SOURCES += src/mqueue.c src/mqueueclose.c \
>> diff --git a/cpukit/posix/include/sys/mman.h b/cpukit/posix/include/sys/mman.h
>> new file mode 100644
>> index 0000000..ddf34cc
>> --- /dev/null
>> +++ b/cpukit/posix/include/sys/mman.h
>> @@ -0,0 +1,189 @@
>> +/*     $NetBSD: mman.h,v 1.36 2005/09/13 01:42:51 christos Exp $       */
>> + * Copyright (c) 1982, 1986, 1993
>> + *     The Regents of the University of California.  All rights reserved.
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + *    notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + *    notice, this list of conditions and the following disclaimer in the
>> + *    documentation and/or other materials provided with the distribution.
>> + * 3. Neither the name of the University nor the names of its contributors
>> + *    may be used to endorse or promote products derived from this software
>> + *    without specific prior written permission.
>> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
>> + * SUCH DAMAGE.
>> + *     @(#)mman.h      8.2 (Berkeley) 1/9/95
>> +#ifndef _SYS_MMAN_H_
>> +#define _SYS_MMAN_H_
>> +#ifdef __rtems__
>> +#include <inttypes.h>
>> +#include <stddef.h>
>> +#include <sys/types.h>
>> +#else /* __rtems__ */
>> +#include <sys/featuretest.h>
>> +#include <machine/ansi.h>
>> +#ifdef _BSD_SIZE_T_
>> +typedef        _BSD_SIZE_T_    size_t;
>> +#undef _BSD_SIZE_T_
>> +#endif
>> +#include <sys/ansi.h>
>> +#ifndef        mode_t
>> +typedef        __mode_t        mode_t;
>> +#define        mode_t          __mode_t
>> +#endif
>> +#ifndef        off_t
>> +typedef        __off_t         off_t;          /* file offset */
>> +#define        off_t           __off_t
>> +#endif
>> +#endif /* __rtems__ */
>> + * Protections are chosen from these bits, or-ed together
>> +#define        PROT_NONE       0x00    /* no permissions */
>> +#define        PROT_READ       0x01    /* pages can be read */
>> +#define        PROT_WRITE      0x02    /* pages can be written */
>> +#define        PROT_EXEC       0x04    /* pages can be executed */
>> + * Flags contain sharing type and options.
>> + * Sharing types; choose one.
>> +#define        MAP_SHARED      0x0001  /* share changes */
>> +#define        MAP_PRIVATE     0x0002  /* changes are private */
>> +#ifdef _KERNEL
>> + * Deprecated flag; these are treated as MAP_PRIVATE internally by
>> + * the kernel.
>> +#define        MAP_COPY        0x0004  /* "copy" region at mmap time */
>> +#endif
>> + * Other flags
>> +#define        MAP_FIXED        0x0010 /* map addr must be exactly as requested */
>> +#define        MAP_RENAME       0x0020 /* Sun: rename private pages to file */
>> +#define        MAP_NORESERVE    0x0040 /* Sun: don't reserve needed swap area */
>> +#define        MAP_INHERIT      0x0080 /* region is retained after exec */
>> +#define        MAP_HASSEMAPHORE 0x0200 /* region may contain semaphores */
>> +#define        MAP_TRYFIXED     0x0400 /* attempt hint address, even within break */
>> +#define        MAP_WIRED        0x0800 /* mlock() mapping when it is established */
>> + * Mapping type
>> +#define        MAP_FILE        0x0000  /* map from file (default) */
>> +#define        MAP_ANON        0x1000  /* allocated from memory, swap space */
>> + * Alignment (expressed in log2).  Must be >= log2(PAGE_SIZE) and
>> + * < # bits in a pointer (26 (acorn26), 32 or 64).
>> +#define        MAP_ALIGNED(n)          ((n) << MAP_ALIGNMENT_SHIFT)
>> +#define        MAP_ALIGNMENT_SHIFT     24
>> +#define        MAP_ALIGNMENT_MASK      MAP_ALIGNED(0xff)
>> +#define        MAP_ALIGNMENT_64KB      MAP_ALIGNED(16) /* 2^16 */
>> +#define        MAP_ALIGNMENT_16MB      MAP_ALIGNED(24) /* 2^24 */
>> +#define        MAP_ALIGNMENT_4GB       MAP_ALIGNED(32) /* 2^32 */
>> +#define        MAP_ALIGNMENT_1TB       MAP_ALIGNED(40) /* 2^40 */
>> +#define        MAP_ALIGNMENT_256TB     MAP_ALIGNED(48) /* 2^48 */
>> +#define        MAP_ALIGNMENT_64PB      MAP_ALIGNED(56) /* 2^56 */
>> + * Error indicator returned by mmap(2)
>> +#define        MAP_FAILED      ((void *) -1)   /* mmap() failed */
>> + * Flags to msync
>> +#define        MS_ASYNC        0x01    /* perform asynchronous writes */
>> +#define        MS_INVALIDATE   0x02    /* invalidate cached data */
>> +#define        MS_SYNC         0x04    /* perform synchronous writes */
>> + * Flags to mlockall
>> +#define        MCL_CURRENT     0x01    /* lock all pages currently mapped */
>> +#define        MCL_FUTURE      0x02    /* lock all pages mapped in the future */
>> +#if defined(_NETBSD_SOURCE)
>> + * Advice to madvise
>> +#define        MADV_NORMAL     0       /* no further special treatment */
>> +#define        MADV_RANDOM     1       /* expect random page references */
>> +#define        MADV_SEQUENTIAL 2       /* expect sequential page references */
>> +#define        MADV_WILLNEED   3       /* will need these pages */
>> +#define        MADV_DONTNEED   4       /* dont need these pages */
>> +#define        MADV_SPACEAVAIL 5       /* insure that resources are reserved */
>> +#define        MADV_FREE       6       /* pages are empty, free them */
>> + * Flags to minherit
>> +#define        MAP_INHERIT_SHARE       0       /* share with child */
>> +#define        MAP_INHERIT_COPY        1       /* copy into child */
>> +#define        MAP_INHERIT_NONE        2       /* absent from child */
>> +#define        MAP_INHERIT_DONATE_COPY 3       /* copy and delete -- not
>> +                                          implemented in UVM */
>> +#define        MAP_INHERIT_DEFAULT     MAP_INHERIT_COPY
>> +#endif
>> +#ifndef _KERNEL
>> +#include <sys/cdefs.h>
>> +__BEGIN_DECLS
>> +void   *mmap(void *, size_t, int, int, int, off_t);
>> +int    munmap(void *, size_t);
>> +int    mprotect(void *, size_t, int);
>> +#ifndef __LIBC12_SOURCE__
>> +#if defined(__rtems__)
>> +int    msync(void *, size_t, int);
>> +#else
>> +int    msync(void *, size_t, int) __RENAME(__msync13);
>> +#endif
>> +#endif
>> +int    mlock(const void *, size_t);
>> +int    munlock(const void *, size_t);
>> +int    mlockall(int);
>> +int    munlockall(void);
>> +int    madvise(void *, size_t, int);
>> +int    mincore(void *, size_t, char *);
>> +int    minherit(void *, size_t, int);
>> +#endif
>> +__END_DECLS
>> +#endif /* !_KERNEL */
>> +#endif /* !_SYS_MMAN_H_ */
>> diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
>> index 6e3f2a2..1b65213 100644
>> --- a/cpukit/posix/preinstall.am
>> +++ b/cpukit/posix/preinstall.am
>> @@ -43,6 +43,15 @@ $(PROJECT_INCLUDE)/rtems/posix/posixapi.h: include/rtems/posix/posixapi.h $(PROJ
>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/posixapi.h
>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/posixapi.h
>> +$(PROJECT_INCLUDE)/sys/$(dirstamp):
>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/sys
>> +       @: > $(PROJECT_INCLUDE)/sys/$(dirstamp)
>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/sys/$(dirstamp)
>> +$(PROJECT_INCLUDE)/sys/mman.h: include/sys/mman.h $(PROJECT_INCLUDE)/sys/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/mman.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/mman.h
>>  if HAS_PTHREADS
>>  $(PROJECT_INCLUDE)/aio.h: include/aio.h $(PROJECT_INCLUDE)/$(dirstamp)
>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/aio.h
>> diff --git a/cpukit/posix/src/mmap.c b/cpukit/posix/src/mmap.c
>> index 0000000..2798326
>> --- /dev/null
>> +++ b/cpukit/posix/src/mmap.c
>> @@ -0,0 +1,26 @@
>> + * @file
>> + *  COPYRIGHT (c) 2014.
>> + *  On-Line Applications Research Corporation (OAR).
>> + *  The license and distribution terms for this file may be
>> + *  found in the file LICENSE in this distribution or at
>> + *  http://www.rtems.org/license/LICENSE.
>> +#if HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +#include <sys/mman.h>
>> +int munmap(
>> +  void   *addr __attribute__((unused)),
>> +  size_t  length __attribute__((unused))
>> +  return -1;
>> diff --git a/cpukit/posix/src/mprotect.c b/cpukit/posix/src/mprotect.c
>> index 51b565e..94bd316 100644
>> --- a/cpukit/posix/src/mprotect.c
>> +++ b/cpukit/posix/src/mprotect.c
>> @@ -28,16 +28,10 @@
>>  #endif
>>  #include <unistd.h>
>> - * RTEMS does not have <sys/mman.h> so we need a prototype here to
>> - * avoid warnings.
>> -int mprotect( const void *, size_t, int );
>>  int mprotect(
>> -  const void *addr __attribute__((unused)),
>>    size_t len __attribute__((unused)),
>>    int prot __attribute__((unused)) )
>> diff --git a/cpukit/posix/src/munmap.c b/cpukit/posix/src/munmap.c
>> index 0000000..3ebb2f4
>> --- /dev/null
>> +++ b/cpukit/posix/src/munmap.c
>> @@ -0,0 +1,30 @@
>> + * @file
>> +#if HAVE_CONFIG_H
>> +#endif
>> +void *mmap(
>> +  size_t  lenhth __attribute__((unused)),
>> +  int     prot __attribute__((unused)),
>> +  int     flags __attribute__((unused)),
>> +  int     fildes __attribute__((unused)),
>> +  off_t   off
>> +  return NULL;
>> 1.9.3
>> devel mailing list
>> devel at rtems.org
