[rtems commit] bsps/arm: Enable L2C for Cortex-A9 MPCore BSPs
Chris Johns
chrisj at rtems.org
Fri Nov 21 05:10:37 UTC 2014
On 21/11/2014 12:53 am, Sebastian Huber wrote:
> Module: rtems
> Branch: master
> Commit: 50440c065e247899ee739d56cb1392c259289031
> Changeset: http://git.rtems.org/rtems/commit/?id=50440c065e247899ee739d56cb1392c259289031
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Wed Nov 19 15:30:24 2014 +0100
> +RTEMS_BSPOPTS_SET([BSP_DATA_CACHE_ENABLED],[*],[1])
> +RTEMS_BSPOPTS_HELP([BSP_DATA_CACHE_ENABLED],[enable data cache])
> +RTEMS_BSPOPTS_SET([BSP_INSTRUCTION_CACHE_ENABLED],[*],[1])
> +RTEMS_BSPOPTS_HELP([BSP_INSTRUCTION_CACHE_ENABLED],[enable instruction cache])
To disable I provide configure with:
BSP_DATA_CACHE_ENABLED=0 BSP_INSTRUCTION_CACHE_ENABLED=0
however this:
> +#if defined(BSP_DATA_CACHE_ENABLED) || defined(BSP_INSTRUCTION_CACHE_ENABLED)
> + /* Enable unified L2 cache */
> + rtems_cache_enable_data();
> +#endif
and this:
> +#if !defined(RTEMS_SMP) \
> + && (defined(BSP_DATA_CACHE_ENABLED) \
> + || defined(BSP_INSTRUCTION_CACHE_ENABLED))
> +#endif
only check for defined and it is always defined. These should check for
the value only ie:
#if BSP_DATA_CACHE_ENABLED || BSP_INSTRUCTION_CACHE_ENABLED
This is not the only case of BSPOPTS'less'ness we have in RTEMS but this
one is an issue for me. Have I told you recently how much I dislike the
BSPOPTS support.
FYI the L2 cache seems to have upset OpenOCD and breakpoints. They are
now stopdeadpoints and once hit you never leave.
