[PATCH] 4.11/rtems-nios2.bset: Drop patch adding RTEMS target
Fri Nov 21 18:49:32 UTC 2014
 rtems/config/4.11/rtems-nios2.bset | 8 --------
 1 file changed, 8 deletions(-)
diff --git a/rtems/config/4.11/rtems-nios2.bset b/rtems/config/4.11/rtems-nios2.bset
index 41e6a12..ed76eac 100644
--- a/rtems/config/4.11/rtems-nios2.bset
+++ b/rtems/config/4.11/rtems-nios2.bset
@@ -1,8 +1,6 @@
 # Tools Set for RTEMS NIOS 4.11 Stable
-# The NIOS source is a special version released by Altera.
 %define release 1
@@ -14,12 +12,6 @@
 %include rtems-4.11-base.bset
-# Add support for Cortex-M4 and Cortex-R based chips
-%patch add gcc pw://patchwork.ozlabs.org/patch/364504/raw/RTEMS-Add-Nios-2-support.patch
-%hash  md5 RTEMS-Add-Nios-2-support.patch fd9bbc8482e69623214e2a4289e38d8f
 # Tools configuration.
 4.11/rtems-autotools
1.9.3
