[PATCH 02/20] libbsp/shared/bspinit.c: Document assumption of NULL returned
Tue Nov 25 23:02:30 UTC 2014
 c/src/lib/libbsp/shared/bspinit.c | 24 ++++++++++++------------
 1 file changed, 12 insertions(+), 12 deletions(-)
diff --git a/c/src/lib/libbsp/shared/bspinit.c b/c/src/lib/libbsp/shared/bspinit.c
index 86c950c..b524389 100644
--- a/c/src/lib/libbsp/shared/bspinit.c
+++ b/c/src/lib/libbsp/shared/bspinit.c
@@ -37,12 +37,10 @@ rtems_task Init (rtems_task_argument arg)
   char**      argv = NULL;
   int         result = -124;
-  if (boot_cmdline)
+  if (boot_cmdline) {
     cmdline = malloc (strlen (boot_cmdline) + 1);
-    if (cmdline)
+    if (cmdline) {
       strcpy (cmdline, boot_cmdline);
       command = cmdline;
@@ -50,8 +48,7 @@ rtems_task Init (rtems_task_argument arg)
        * Break the line up into arguments with "" being ignored.
-      while (true)
+      while (true) {
         command = strtok (command, " \t\r\n");
         if (command == NULL)
           break;
@@ -59,22 +56,25 @@ rtems_task Init (rtems_task_argument arg)
         command = '\0';
+       * If there are arguments, allocate enough memory for the argv
+       * array to be passed into main().
+       * NOTE: If argc is 0, then argv will be NULL.
       argv = calloc (argc, sizeof (char*));
-      if (argv)
+      if (argv) {
         int a;
         command = cmdline;
         argv[0] = command;
-        for (a = 1; a < argc; a++)
+        for (a = 1; a < argc; a++) {
           command += strlen (command) + 1;
           argv[a] = command;
-      else
+      } else
         argc = 0;
1.9.3
