[PATCH 02/20] libbsp/shared/bspinit.c: Document assumption of NULL returned
Wed Nov 26 15:08:44 UTC 2014
On Tue, Nov 25, 2014 at 6:02 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> From: Josh Oguin <josh.oguin at oarcorp.com>
>  c/src/lib/libbsp/shared/bspinit.c | 24 ++++++++++++------------
>  1 file changed, 12 insertions(+), 12 deletions(-)
> diff --git a/c/src/lib/libbsp/shared/bspinit.c b/c/src/lib/libbsp/shared/bspinit.c
> index 86c950c..b524389 100644
> --- a/c/src/lib/libbsp/shared/bspinit.c
> +++ b/c/src/lib/libbsp/shared/bspinit.c
> @@ -37,12 +37,10 @@ rtems_task Init (rtems_task_argument arg)
>    char**      argv = NULL;
>    int         result = -124;
> -  if (boot_cmdline)
> +  if (boot_cmdline) {
>      cmdline = malloc (strlen (boot_cmdline) + 1);
> -    if (cmdline)
> +    if (cmdline) {
>        strcpy (cmdline, boot_cmdline);
>        command = cmdline;
> @@ -50,8 +48,7 @@ rtems_task Init (rtems_task_argument arg)
>         * Break the line up into arguments with "" being ignored.
> -      while (true)
> +      while (true) {
>          command = strtok (command, " \t\r\n");
>          if (command == NULL)
>            break;
> @@ -59,22 +56,25 @@ rtems_task Init (rtems_task_argument arg)
>          command = '\0';
> +       * If there are arguments, allocate enough memory for the argv
> +       * array to be passed into main().
> +       * NOTE: If argc is 0, then argv will be NULL.
>        argv = calloc (argc, sizeof (char*));
Cleaner to change it to
    argv = argc > 0 ? calloc(argc,sizeof(char*)) : NULL;
> -      if (argv)
> +      if (argv) {
>          int a;
>          command = cmdline;
>          argv[0] = command;
> -        for (a = 1; a < argc; a++)
> +        for (a = 1; a < argc; a++) {
>            command += strlen (command) + 1;
>            argv[a] = command;
> -      else
> +      } else
>          argc = 0;
> 1.9.3
> devel mailing list
> devel at rtems.org
