[PATCH 02/20] libbsp/shared/bspinit.c: Document assumption of NULL returned
Wed Nov 26 15:22:31 UTC 2014
On 11/26/2014 09:08 AM, Gedare Bloom wrote:
> On Tue, Nov 25, 2014 at 6:02 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com>  wrote:
>> From: Josh Oguin<josh.oguin at oarcorp.com>
>>   c/src/lib/libbsp/shared/bspinit.c | 24 ++++++++++++------------
>>   1 file changed, 12 insertions(+), 12 deletions(-)
>> diff --git a/c/src/lib/libbsp/shared/bspinit.c b/c/src/lib/libbsp/shared/bspinit.c
>> index 86c950c..b524389 100644
>> --- a/c/src/lib/libbsp/shared/bspinit.c
>> +++ b/c/src/lib/libbsp/shared/bspinit.c
>> @@ -37,12 +37,10 @@ rtems_task Init (rtems_task_argument arg)
>>     char**      argv = NULL;
>>     int         result = -124;
>> -  if (boot_cmdline)
>> +  if (boot_cmdline) {
>>       cmdline = malloc (strlen (boot_cmdline) + 1);
>> -    if (cmdline)
>> +    if (cmdline) {
>>         strcpy (cmdline, boot_cmdline);
>>         command = cmdline;
>> @@ -50,8 +48,7 @@ rtems_task Init (rtems_task_argument arg)
>>          * Break the line up into arguments with "" being ignored.
>> -      while (true)
>> +      while (true) {
>>           command = strtok (command, " \t\r\n");
>>           if (command == NULL)
>>             break;
>> @@ -59,22 +56,25 @@ rtems_task Init (rtems_task_argument arg)
>>           command = '\0';
>> +       * If there are arguments, allocate enough memory for the argv
>> +       * array to be passed into main().
>> +       * NOTE: If argc is 0, then argv will be NULL.
>>         argv = calloc (argc, sizeof (char*));
> Cleaner to change it to
>      argv = argc>  0 ? calloc(argc,sizeof(char*)) : NULL;
I don't care. Change it and commit it if you want. :)
No review needed. :)
>> -      if (argv)
>> +      if (argv) {
>>           int a;
>>           command = cmdline;
>>           argv[0] = command;
>> -        for (a = 1; a<  argc; a++)
>> +        for (a = 1; a<  argc; a++) {
>>             command += strlen (command) + 1;
>>             argv[a] = command;
>> -      else
>> +      } else
>>           argc = 0;
>> 1.9.3
>> devel mailing list
>> devel at rtems.org
