[PATCH] libbsp ARM: create abort.h to eliminate warnings Created libbsp/arm/shared/abort/abort.h Edited abort.c and simple_abort.c to include abort.h Changed Raspberry Pi BSP to use abort.c instead of simple_abort.c
Alan Cudmore
alan.cudmore at gmail.com
Mon Nov 3 11:22:51 UTC 2014
OK, that makes sense. I'll fix it and resubmit the patch. Any other ARM
BSPs?
Alan
On Nov 3, 2014 2:03 AM, "Sebastian Huber" <
> On 03/11/14 02:59, Alan Cudmore wrote:
>> -libbsp_a_SOURCES += ../shared/abort/simple_abort.c
>> +libbsp_a_SOURCES += ../shared/abort/abort.c
> Since this BSP uses the shared start.S file, I would prefer to remove
> simple_abort.c and abort.c from the Makefile.am. These files should go
> away in the long run.
> The default abort handler is now in:
> http://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/
> armv4-exception-default.S
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141103/077fb8c0/attachment-0002.html>
