[PATCH] libbsp ARM: create abort.h to eliminate warnings Created libbsp/arm/shared/abort/abort.h Edited abort.c and simple_abort.c to include abort.h Changed Raspberry Pi BSP to use abort.c instead of simple_abort.c
Alan Cudmore alan.cudmore at gmail.com
Wed Nov 5 14:35:11 UTC 2014
I'm not sure any of the ARM BSPs use the abort.c or simple_abort.c, even if
they have the code included.
I don't have access to the code right now, but I will take a look at the
ARM BSPs and remove it from the ones that use the shared start.S.
If the ARM BSPs that do not use the shared start.S include the code, but
never call it, I can remove it, if that is what is best. We could even
remove abort.c and simple_abort.c completely. Just let me know.
Alan
On Mon, Nov 3, 2014 at 3:08 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On 11/3/2014 5:22 AM, Alan Cudmore wrote:
> OK, that makes sense. I'll fix it and resubmit the patch. Any other ARM
> BSPs?
> The warning only shows up in these:
> $ grep abort.c warnings-20141030a.txt
>       2 c/src/lib/libbsp/arm/rtl22xx/../shared/abort/simple_abort.c:56:6:
> warning: no previous prototype for '_print_full_context'
> [-Wmissing-prototypes]
>       2 c/src/lib/libbsp/arm/rtl22xx/../shared/abort/simple_abort.c:108:6:
> warning: no previous prototype for 'do_data_abort' [-Wmissing-prototypes]
>       1
> c/src/lib/libbsp/arm/raspberrypi/../shared/abort/simple_abort.c:56:6:
>       1
> c/src/lib/libbsp/arm/raspberrypi/../shared/abort/simple_abort.c:108:6:
> which matches a grep:
> $ grep simple_abort.c */M*am
> raspberrypi/Makefile.am:libbsp_a_SOURCES += ../shared/abort/simple_abort.c
> rtl22xx/Makefile.am:libbsp_a_SOURCES += ../shared/abort/simple_abort.c
> When I "grep start.S */M*.am" from libbsp/arm, most BSPs use
> shared/start/start.S
> but a few have their own start.S. Not sure what the impact of that is.
> --joel
>  Alan
> On Nov 3, 2014 2:03 AM, "Sebastian Huber" <
> sebastian.huber at embedded-brains.de> wrote:
>> On 03/11/14 02:59, Alan Cudmore wrote:
>>> -libbsp_a_SOURCES += ../shared/abort/simple_abort.c
>>> +libbsp_a_SOURCES += ../shared/abort/abort.c
>> Since this BSP uses the shared start.S file, I would prefer to remove
>> simple_abort.c and abort.c from the Makefile.am.  These files should go
>> away in the long run.
>> The default abort handler is now in:
>> http://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/armv4-exception-default.S
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Joel Sherrill, Ph.D.             Director of Research & Developmentjoel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141105/5b05dc0c/attachment-0002.html>
