[PATCH 2/9] Add I2C driver framework
Sebastian Huber
Thu Nov 13 09:30:20 UTC 2014
This I2C driver framework has some major differences compared to libi2c.
* It is compatible to the Linux I2C user-space API.
* It uses generic IMFS nodes and thus reduces the levels of indirection.
* The drivers don't have to mess around with minor numbers to get their
state information.
* No arbitrary bus controller model is assumed. The main task of a I2C
bus controller driver is to process I2C messages. How this is done is
private to the driver.
* Scatter/gather operations are supported.
cpukit/dev/Makefile.am | 11 +
cpukit/dev/i2c/i2c-bus.c | 337 ++++++++++++++++++++++++++
cpukit/dev/i2c/i2c-dev.c | 291 +++++++++++++++++++++++
cpukit/dev/include/dev/i2c/i2c.h | 430 ++++++++++++++++++++++++++++++++++
cpukit/dev/preinstall.am | 9 +
cpukit/wrapup/Makefile.am | 1 +
testsuites/libtests/Makefile.am | 1 +
testsuites/libtests/configure.ac | 1 +
testsuites/libtests/i2c01/Makefile.am | 19 ++
testsuites/libtests/i2c01/i2c01.doc | 11 +
testsuites/libtests/i2c01/i2c01.scn | 2 +
testsuites/libtests/i2c01/init.c | 286 ++++++++++++++++++++++
12 files changed, 1399 insertions(+)
create mode 100644 cpukit/dev/i2c/i2c-bus.c
create mode 100644 cpukit/dev/i2c/i2c-dev.c
create mode 100644 cpukit/dev/include/dev/i2c/i2c.h
create mode 100644 testsuites/libtests/i2c01/Makefile.am
create mode 100644 testsuites/libtests/i2c01/i2c01.doc
create mode 100644 testsuites/libtests/i2c01/i2c01.scn
create mode 100644 testsuites/libtests/i2c01/init.c
diff --git a/cpukit/dev/Makefile.am b/cpukit/dev/Makefile.am
index 5f8fee6..c2913a6 100644
--- a/cpukit/dev/Makefile.am
+++ b/cpukit/dev/Makefile.am
@@ -1,12 +1,23 @@
include $(top_srcdir)/automake/compile.am
+include $(top_srcdir)/automake/multilib.am
include_devdir = $(includedir)/dev
include_dev_HEADERS =
+include_dev_i2cdir = $(includedir)/dev/i2c
+include_dev_i2c_HEADERS =
+include_dev_i2c_HEADERS += include/dev/i2c/i2c.h
include_linuxdir = $(includedir)/linux
include_linux_HEADERS =
include_linux_HEADERS += include/linux/i2c.h
include_linux_HEADERS += include/linux/i2c-dev.h
+noinst_LIBRARIES = libdev.a
+libdev_a_SOURCES =
+libdev_a_SOURCES += i2c/i2c-bus.c
+libdev_a_SOURCES += i2c/i2c-dev.c
include $(srcdir)/preinstall.am
include $(top_srcdir)/automake/local.am
diff --git a/cpukit/dev/i2c/i2c-bus.c b/cpukit/dev/i2c/i2c-bus.c
new file mode 100644
index 0000000..5ab185d
--- /dev/null
+++ b/cpukit/dev/i2c/i2c-bus.c
@@ -0,0 +1,337 @@
+ * @file
+ * @brief Inter-Integrated Circuit (I2C) Bus Implementation
+ * @ingroup I2CBus
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <dev/i2c/i2c.h>
+#include <rtems/imfs.h>
+#include <stdlib.h>
+#include <string.h>
+void i2c_bus_obtain(i2c_bus *bus)
+ rtems_status_code sc;
+ sc = rtems_semaphore_obtain(bus->mutex, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ _Assert(sc == RTEMS_SUCCESSFUL);
+ (void) sc;
+void i2c_bus_release(i2c_bus *bus)
+ sc = rtems_semaphore_release(bus->mutex);
+ (void) sc;
+int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
+ int err;
+ _Assert(msg_count > 0);
+ i2c_bus_obtain(bus);
+ err = (*bus->transfer)(bus, msgs, msg_count);
+ i2c_bus_release(bus);
+ return err;
+static ssize_t i2c_bus_read(
+ rtems_libio_t *iop,
+ void *buffer,
+ size_t count
+ i2c_bus *bus = IMFS_generic_get_context_by_iop(iop);
+ i2c_msg msg = {
+ .addr = bus->default_address,
+ .flags = I2C_M_RD,
+ .len = (uint16_t) count,
+ .buf = buffer
+ int err;
+ if (bus->ten_bit_address) {
+ msg.flags |= I2C_M_TEN;
+ err = i2c_bus_transfer(bus, &msg, 1);
+ if (err == 0) {
+ return msg.len;
+ } else {
+ rtems_set_errno_and_return_minus_one(-err);
+static ssize_t i2c_bus_write(
+ const void *buffer,
+ size_t count
+ i2c_msg msg = {
+ .flags = 0,
+ .buf = RTEMS_DECONST(void *, buffer)
+ int err;
+ if (err == 0) {
+ return msg.len;
+ } else {
+static int i2c_bus_ioctl(
+ ioctl_command_t command,
+ void *arg
+ i2c_rdwr_ioctl_data *rdwr;
+ int err;
+ switch (command) {
+ case I2C_RDWR:
+ rdwr = arg;
+ if (rdwr->nmsgs > 0) {
+ err = i2c_bus_transfer(bus, rdwr->msgs, rdwr->nmsgs);
+ } else {
+ err = 0;
+ break;
+ case I2C_BUS_OBTAIN:
+ err = 0;
+ break;
+ case I2C_BUS_RELEASE:
+ err = 0;
+ break;
+ case I2C_BUS_GET_CONTROL:
+ *(i2c_bus **) arg = bus;
+ err = 0;
+ break;
+ case I2C_FUNCS:
+ *(unsigned long *) arg = bus->functionality;
+ err = 0;
+ break;
+ case I2C_RETRIES:
+ bus->retries = (unsigned long) arg;
+ err = 0;
+ break;
+ case I2C_TIMEOUT:
+ bus->timeout = RTEMS_MILLISECONDS_TO_TICKS(10 * (unsigned long) arg);
+ err = 0;
+ break;
+ case I2C_SLAVE:
+ case I2C_SLAVE_FORCE:
+ bus->default_address = (unsigned long) arg;
+ err = 0;
+ break;
+ case I2C_TENBIT:
+ bus->ten_bit_address = (unsigned long) arg != 0;
+ err = 0;
+ break;
+ case I2C_PEC:
+ bus->use_pec = (unsigned long) arg != 0;
+ err = 0;
+ break;
+ case I2C_BUS_SET_CLOCK:
+ err = (*bus->set_clock)(bus, (unsigned long) arg);
+ break;
+ default:
+ err = -ENOTTY;
+ break;
+ if (err == 0) {
+ return 0;
+ } else {
+static const rtems_filesystem_file_handlers_r i2c_bus_handler = {
+ .open_h = rtems_filesystem_default_open,
+ .close_h = rtems_filesystem_default_close,
+ .read_h = i2c_bus_read,
+ .write_h = i2c_bus_write,
+ .ioctl_h = i2c_bus_ioctl,
+ .lseek_h = rtems_filesystem_default_lseek,
+ .fstat_h = IMFS_stat,
+ .ftruncate_h = rtems_filesystem_default_ftruncate,
+ .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fcntl_h = rtems_filesystem_default_fcntl,
+ .kqfilter_h = rtems_filesystem_default_kqfilter,
+ .poll_h = rtems_filesystem_default_poll,
+ .readv_h = rtems_filesystem_default_readv,
+ .writev_h = rtems_filesystem_default_writev
+static IMFS_jnode_t *i2c_bus_node_destroy(IMFS_jnode_t *node)
+ i2c_bus *bus;
+ bus = IMFS_generic_get_context_by_node(node);
+ (*bus->destroy)(bus);
+ return node;
+static const IMFS_node_control i2c_bus_node_control = {
+ .imfs_type = IMFS_GENERIC,
+ .handlers = &i2c_bus_handler,
+ .node_initialize = IMFS_node_initialize_generic,
+ .node_remove = IMFS_node_remove_default,
+ .node_destroy = i2c_bus_node_destroy
+int i2c_bus_register(
+ i2c_bus *bus,
+ const char *bus_path
+ int rv;
+ rv = IMFS_make_generic_node(
+ bus_path,
+ S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
+ &i2c_bus_node_control,
+ bus
+ if (rv != 0) {
+ return rv;
+static int i2c_bus_transfer_default(
+ i2c_bus *bus,
+ i2c_msg *msgs,
+ uint32_t msg_count
+ (void) bus;
+ (void) msgs;
+ (void) msg_count;
+ return -EIO;
+static int i2c_bus_set_clock_default(i2c_bus *bus, unsigned long clock)
+ (void) bus;
+ (void) clock;
+ return -EIO;
+static int i2c_bus_do_init(
+ i2c_bus *bus,
+ void (*destroy)(i2c_bus *bus)
+ sc = rtems_semaphore_create(
+ rtems_build_name('I', '2', 'C', ' '),
+ 1,
+ RTEMS_BINARY_SEMAPHORE | RTEMS_INHERIT_PRIORITY | RTEMS_PRIORITY,
+ 0,
+ &bus->mutex
+ if (sc != RTEMS_SUCCESSFUL) {
+ (*destroy)(bus);
+ rtems_set_errno_and_return_minus_one(ENOMEM);
+ bus->transfer = i2c_bus_transfer_default;
+ bus->set_clock = i2c_bus_set_clock_default;
+ bus->destroy = destroy;
+ return 0;
+void i2c_bus_destroy(i2c_bus *bus)
+ sc = rtems_semaphore_delete(bus->mutex);
+ (void) sc;
+void i2c_bus_destroy_and_free(i2c_bus *bus)
+ i2c_bus_destroy(bus);
+ free(bus);
+int i2c_bus_init(i2c_bus *bus)
+ memset(bus, 0, sizeof(*bus));
+ return i2c_bus_do_init(bus, i2c_bus_destroy);
+i2c_bus *i2c_bus_alloc_and_init(size_t size)
+ i2c_bus *bus = NULL;
+ if (size >= sizeof(*bus)) {
+ bus = calloc(1, size);
+ if (bus != NULL) {
+ int rv;
+ rv = i2c_bus_do_init(bus, i2c_bus_destroy_and_free);
+ if (rv != 0) {
+ return NULL;
+ return bus;
diff --git a/cpukit/dev/i2c/i2c-dev.c b/cpukit/dev/i2c/i2c-dev.c
index 0000000..b03effd
--- /dev/null
+++ b/cpukit/dev/i2c/i2c-dev.c
@@ -0,0 +1,291 @@
+ * @file
+ * @ingroup I2CDevice
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/score/assert.h>
+#include <fcntl.h>
+#include <unistd.h>
+static ssize_t i2c_dev_read(
+ void *buffer,
+ size_t count
+ i2c_dev *dev = IMFS_generic_get_context_by_iop(iop);
+ ssize_t n;
+ n = (*dev->read)(dev, buffer, count, iop->offset);
+ if (n > 0) {
+ iop->offset += n;
+ return n;
+static ssize_t i2c_dev_write(
+ size_t count
+ ssize_t n;
+ n = (*dev->write)(dev, buffer, count, iop->offset);
+ if (n > 0) {
+ iop->offset += n;
+ return n;
+static int i2c_dev_ioctl(
+ void *arg
+ int err;
+ err = (*dev->ioctl)(dev, command, arg);
+ if (err == 0) {
+ return 0;
+ } else {
+static int i2c_dev_fstat(
+ const rtems_filesystem_location_info_t *loc,
+ struct stat *buf
+ i2c_dev *dev = IMFS_generic_get_context_by_location(loc);
+ buf->st_size = (*dev->get_size)(dev);
+ buf->st_blksize = (*dev->get_block_size)(dev);
+ return IMFS_stat(loc, buf);
+static const rtems_filesystem_file_handlers_r i2c_dev_handler = {
+ .read_h = i2c_dev_read,
+ .write_h = i2c_dev_write,
+ .ioctl_h = i2c_dev_ioctl,
+ .lseek_h = rtems_filesystem_default_lseek_file,
+ .fstat_h = i2c_dev_fstat,
+static IMFS_jnode_t *i2c_dev_node_destroy(IMFS_jnode_t *node)
+ i2c_dev *dev;
+ dev = IMFS_generic_get_context_by_node(node);
+ (*dev->destroy)(dev);
+ return node;
+static const IMFS_node_control i2c_dev_node_control = {
+ .handlers = &i2c_dev_handler,
+ .node_destroy = i2c_dev_node_destroy
+int i2c_dev_register(
+ i2c_dev *dev,
+ const char *dev_path
+ int rv;
+ dev_path,
+ &i2c_dev_node_control,
+ dev
+ if (rv != 0) {
+ return rv;
+static ssize_t i2c_dev_read_default(
+ i2c_dev *dev,
+ void *buf,
+ size_t n,
+ off_t offset
+ (void) dev;
+ (void) buf;
+ (void) n;
+ (void) offset;
+ return -EIO;
+static ssize_t i2c_dev_write_default(
+ i2c_dev *dev,
+ const void *buf,
+ size_t n,
+ off_t offset
+ (void) dev;
+ (void) buf;
+ (void) n;
+ (void) offset;
+ return -EIO;
+static int i2c_dev_ioctl_default(
+ i2c_dev *dev,
+ void *arg
+ (void) dev;
+ (void) command;
+ (void) arg;
+ return -ENOTTY;
+static off_t i2c_dev_get_size_default(i2c_dev *dev)
+ (void) dev;
+ return 0;
+static blksize_t i2c_dev_get_block_size_default(i2c_dev *dev)
+ (void) dev;
+ return 1;
+static int i2c_dev_do_init(
+ i2c_dev *dev,
+ const char *bus_path,
+ uint16_t address,
+ void (*destroy)(i2c_dev *dev)
+ int fd;
+ int rv;
+ fd = open(bus_path, O_RDWR);
+ if (fd < 0) {
+ (*destroy)(dev);
+ return -1;
+ rv = ioctl(fd, I2C_BUS_GET_CONTROL, &dev->bus);
+ if (rv != 0) {
+ (*destroy)(dev);
+ return -1;
+ dev->read = i2c_dev_read_default;
+ dev->write = i2c_dev_write_default;
+ dev->ioctl = i2c_dev_ioctl_default;
+ dev->get_size = i2c_dev_get_size_default;
+ dev->get_block_size = i2c_dev_get_block_size_default;
+ dev->destroy = destroy;
+ dev->bus_fd = fd;
+ dev->address = address;
+ return 0;
+void i2c_dev_destroy(i2c_dev *dev)
+ int rv;
+ rv = close(dev->bus_fd);
+ _Assert(rv == 0);
+ (void) rv;
+void i2c_dev_destroy_and_free(i2c_dev *dev)
+ i2c_dev_destroy(dev);
+ free(dev);
+int i2c_dev_init(i2c_dev *dev, const char *bus_path, uint16_t address)
+ return i2c_dev_do_init(dev, bus_path, address, i2c_dev_destroy);
+i2c_dev *i2c_dev_alloc_and_init(
+ size_t size,
+ uint16_t address
+ i2c_dev *dev = NULL;
+ if (size >= sizeof(*dev)) {
+ dev = calloc(1, size);
+ if (dev != NULL) {
+ int rv;
+ rv = i2c_dev_do_init(dev, bus_path, address, i2c_dev_destroy_and_free);
+ if (rv != 0) {
+ return NULL;
+ return dev;
diff --git a/cpukit/dev/include/dev/i2c/i2c.h b/cpukit/dev/include/dev/i2c/i2c.h
index 0000000..f73cc9a
--- /dev/null
+++ b/cpukit/dev/include/dev/i2c/i2c.h
@@ -0,0 +1,430 @@
+ * @file
+ * @brief Inter-Integrated Circuit (I2C) Driver API
+ * @ingroup I2C
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#ifndef _DEV_I2C_I2C_H
+#define _DEV_I2C_I2C_H
+#include <linux/i2c.h>
+#include <linux/i2c-dev.h>
+#include <rtems.h>
+#include <rtems/seterr.h>
+#include <sys/ioctl.h>
+#include <sys/stat.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+typedef struct i2c_msg i2c_msg;
+typedef struct i2c_bus i2c_bus;
+typedef struct i2c_dev i2c_dev;
+typedef struct i2c_rdwr_ioctl_data i2c_rdwr_ioctl_data;
+ * @defgroup I2C Inter-Integrated Circuit (I2C) Driver
+ * @brief Inter-Integrated Circuit (I2C) bus and device driver support.
+ * @defgroup I2CBus I2C Bus Driver
+ * @ingroup I2C
+ * @name I2C IO Control Commands
+ * @brief Obtains the bus.
+ * This command has no argument.
+#define I2C_BUS_OBTAIN 0x800
+ * @brief Releases the bus.
+#define I2C_BUS_RELEASE 0x801
+ * @brief Gets the bus control.
+ * The argument type is a pointer to i2c_bus pointer.
+#define I2C_BUS_GET_CONTROL 0x802
+ * @brief Sets the bus clock in Hz.
+ * The argument type is unsigned long.
+#define I2C_BUS_SET_CLOCK 0x803
+ * @brief Default I2C bus clock in Hz.
+#define I2C_BUS_CLOCK_DEFAULT 100000
+ * @brief I2C bus control.
+struct i2c_bus {
+ * @brief Transfers I2C messages.
+ * @param[in] bus The bus control.
+ * @param[in] msgs The messages to transfer.
+ * @param[in] msg_count The count of messages to transfer. It must be
+ * positive.
+ * @retval 0 Successful operation.
+ * @retval negative Negative error number in case of an error.
+ int (*transfer)(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count);
+ * @brief Sets the bus clock.
+ * @param[in] clock The desired bus clock in Hz.
+ int (*set_clock)(i2c_bus *bus, unsigned long clock);
+ * @brief Destroys the bus.
+ void (*destroy)(i2c_bus *bus);
+ * @brief Mutex to protect the bus access.
+ rtems_id mutex;
+ * @brief Default slave device address.
+ uint16_t default_address;
+ * @brief Use 10-bit addresses.
+ bool ten_bit_address;
+ * @brief Use SMBus PEC.
+ bool use_pec;
+ * @brief Transfer retry count.
+ unsigned long retries;
+ * @brief Transaction timeout in ticks.
+ rtems_interval timeout;
+ * @brief Controller functionality.
+ unsigned long functionality;
+ * @brief Initializes a bus control.
+ * After a sucessful initialization the bus control must be destroyed via
+ * i2c_bus_destroy(). A registered bus control will be automatically destroyed
+ * in case the device file is unlinked. Make sure to call i2c_bus_destroy() in
+ * a custom destruction handler.
+ * @retval -1 An error occurred. The errno is set to indicate the error.
+ * @see i2c_bus_register()
+int i2c_bus_init(i2c_bus *bus);
+ * @brief Allocates a bus control from the heap and initializes it.
+ * After a sucessful allocation and initialization the bus control must be
+ * destroyed via i2c_bus_destroy_and_free(). A registered bus control will be
+ * automatically destroyed in case the device file is unlinked. Make sure to
+ * call i2c_bus_destroy_and_free() in a custom destruction handler.
+ * @param[in] size The size of the bus control. This enables the addition of
+ * bus controller specific data to the base bus control. The bus control is
+ * zero initialized.
+ * @retval non-NULL The new bus control.
+ * @retval NULL An error occurred. The errno is set to indicate the error.
+i2c_bus *i2c_bus_alloc_and_init(size_t size);
+ * @brief Destroys a bus control.
+void i2c_bus_destroy(i2c_bus *bus);
+ * @brief Destroys a bus control and frees its memory.
+void i2c_bus_destroy_and_free(i2c_bus *bus);
+ * @brief Registers a bus control.
+ * This function claims ownership of the bus control regardless if the
+ * registration is successful or not.
+ * @param[in] bus_path The path to the bus device file.
+ i2c_bus *bus,
+void i2c_bus_obtain(i2c_bus *bus);
+void i2c_bus_release(i2c_bus *bus);
+ * The bus is obtained before the transfer and released afterwards.
+ * positive.
+int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count);
+ * @defgroup I2CDevice I2C Device Driver
+ * @ingroup I2C
+ * @brief Base number for device IO control commands.
+#define I2C_DEVICE_IO_CONTROL 0x900
+ * @brief I2C slave device control.
+struct i2c_dev {
+ * @brief Reads from the device.
+ * @retval non-negative Bytes transferred from device.
+ ssize_t (*read)(i2c_dev *dev, void *buf, size_t n, off_t offset);
+ * @brief Writes to the device.
+ * @retval non-negative Bytes transferred to device.
+ ssize_t (*write)(i2c_dev *dev, const void *buf, size_t n, off_t offset);
+ * @brief Device IO control.
+ int (*ioctl)(i2c_dev *dev, ioctl_command_t command, void *arg);
+ * @brief Gets the file size.
+ off_t (*get_size)(i2c_dev *dev);
+ * @brief Gets the file block size.
+ blksize_t (*get_block_size)(i2c_dev *dev);
+ * @brief Destroys the device.
+ void (*destroy)(i2c_dev *dev);
+ * @brief The bus control.
+ i2c_bus *bus;
+ * @brief The device address.
+ uint16_t address;
+ * @brief File descriptor of the bus.
+ * This prevents destruction of the bus since we hold a reference to it with
+ * this.
+ int bus_fd;
+ * @brief Initializes a device control.
+ * After a sucessful initialization the device control must be destroyed via
+ * i2c_dev_destroy(). A registered device control will be automatically
+ * destroyed in case the device file is unlinked. Make sure to call
+ * i2c_dev_destroy_and_free() in a custom destruction handler.
+ * @param[in] device The device control.
+ * @param[in] address The address of the device.
+ * @see i2c_dev_register()
+int i2c_dev_init(i2c_dev *dev, const char *bus_path, uint16_t address);
+ * @brief Allocates a device control from the heap and initializes it.
+ * After a sucessful allocation and initialization the device control must be
+ * destroyed via i2c_dev_destroy_and_free(). A registered device control will
+ * be automatically destroyed in case the device file is unlinked. Make sure
+ * to call i2c_dev_destroy_and_free() in a custom destruction handler.
+ * @param[in] size The size of the device control. This enables the addition
+ * of device specific data to the base device control. The device control is
+ * @retval non-NULL The new device control.
+ size_t size,
+ uint16_t address
+ * @brief Destroys a device control.
+ * @param[in] dev The device control.
+void i2c_dev_destroy(i2c_dev *dev);
+ * @brief Destroys a device control and frees its memory.
+void i2c_dev_destroy_and_free(i2c_dev *dev);
+ * @brief Registers a device control.
+ * This function claims ownership of the device control regardless if the
+ * @param[in] dev The dev control.
+ * @param[in] dev_path The path to the device file of the device.
+ i2c_dev *dev,
+#ifdef __cplusplus
+#endif /* _DEV_I2C_I2C_H */
diff --git a/cpukit/dev/preinstall.am b/cpukit/dev/preinstall.am
index a17d606..8239327 100644
--- a/cpukit/dev/preinstall.am
+++ b/cpukit/dev/preinstall.am
@@ -18,6 +18,15 @@ $(PROJECT_INCLUDE)/dev/$(dirstamp):
@: > $(PROJECT_INCLUDE)/dev/$(dirstamp)
PREINSTALL_DIRS += $(PROJECT_INCLUDE)/dev/$(dirstamp)
+$(PROJECT_INCLUDE)/dev/i2c/$(dirstamp):
+ @$(MKDIR_P) $(PROJECT_INCLUDE)/dev/i2c
+ @: > $(PROJECT_INCLUDE)/dev/i2c/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/dev/i2c/$(dirstamp)
+$(PROJECT_INCLUDE)/dev/i2c/i2c.h: include/dev/i2c/i2c.h $(PROJECT_INCLUDE)/dev/i2c/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/dev/i2c/i2c.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/dev/i2c/i2c.h
$(PROJECT_INCLUDE)/linux/$(dirstamp):
@$(MKDIR_P) $(PROJECT_INCLUDE)/linux
@: > $(PROJECT_INCLUDE)/linux/$(dirstamp)
diff --git a/cpukit/wrapup/Makefile.am b/cpukit/wrapup/Makefile.am
index bf38cca..5dfe34b 100644
--- a/cpukit/wrapup/Makefile.am
+++ b/cpukit/wrapup/Makefile.am
@@ -8,6 +8,7 @@ project_lib_LIBRARIES = librtemscpu.a
librtemscpu_a_SOURCES =
TMP_LIBS =
+TMP_LIBS += ../dev/libdev.a
TMP_LIBS += ../score/cpu/@RTEMS_CPU@/libscorecpu.a
TMP_LIBS += ../score/libscore.a
TMP_LIBS += ../sapi/libsapi.a
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index 26e11c6..bee6e75 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -1,6 +1,7 @@
ACLOCAL_AMFLAGS = -I ../aclocal
_SUBDIRS = POSIX
+_SUBDIRS += i2c01
_SUBDIRS += newlib01
_SUBDIRS += block17
_SUBDIRS += exit02
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 392e2a9..77a108b 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -66,6 +66,7 @@ AS_IF([test x"$HAVE_LIBDL" = x"yes"],[
# Explicitly list all Makefiles here
AC_CONFIG_FILES([Makefile
+i2c01/Makefile
newlib01/Makefile
block17/Makefile
exit02/Makefile
diff --git a/testsuites/libtests/i2c01/Makefile.am b/testsuites/libtests/i2c01/Makefile.am
index 0000000..f329337
--- /dev/null
+++ b/testsuites/libtests/i2c01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = i2c01
+i2c01_SOURCES = init.c
+dist_rtems_tests_DATA = i2c01.scn i2c01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(i2c01_OBJECTS)
+LINK_LIBS = $(i2c01_LDLIBS)
+i2c01$(EXEEXT): $(i2c01_OBJECTS) $(i2c01_DEPENDENCIES)
+ @rm -f i2c01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/libtests/i2c01/i2c01.doc b/testsuites/libtests/i2c01/i2c01.doc
index 0000000..79185ee
--- /dev/null
+++ b/testsuites/libtests/i2c01/i2c01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: i2c01
+directives:
+ TBD
+concepts:
+ - Ensure that the I2C driver framework works.
diff --git a/testsuites/libtests/i2c01/i2c01.scn b/testsuites/libtests/i2c01/i2c01.scn
index 0000000..1b54497
--- /dev/null
+++ b/testsuites/libtests/i2c01/i2c01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST I2C 1 ***
+*** END OF TEST I2C 1 ***
diff --git a/testsuites/libtests/i2c01/init.c b/testsuites/libtests/i2c01/init.c
index 0000000..7f38d34
--- /dev/null
+++ b/testsuites/libtests/i2c01/init.c
@@ -0,0 +1,286 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#ifdef HAVE_CONFIG_H
+#endif
+#include <errno.h>
+#include <fcntl.h>
+#include <rtems/libcsupport.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "I2C 1";
+#define SPARE_ADDRESS_BITS 3
+#define DEVICE_SIMPLE_READ_WRITE (0UL << SPARE_ADDRESS_BITS)
+typedef struct test_device test_device;
+struct test_device {
+ int (*transfer)(
+ i2c_bus *bus,
+ i2c_msg *msgs,
+ uint32_t msg_count,
+ test_device *dev
+typedef struct {
+ test_device base;
+ char buf[3];
+} test_device_simple_read_write;
+typedef struct {
+ i2c_bus base;
+ unsigned long clock;
+ test_device *devices[1];
+ test_device_simple_read_write simple_read_write;
+} test_bus;
+static const char bus_path[] = "/dev/i2c-0";
+static int test_simple_read_write_transfer(
+ i2c_bus *bus,
+ i2c_msg *msgs,
+ test_device *base
+ test_device_simple_read_write *dev = (test_device_simple_read_write *) base;
+ if (msg_count == 1 && msgs[0].len == sizeof(dev->buf)) {
+ if ((msgs[0].flags & I2C_M_RD) != 0) {
+ memcpy(msgs[0].buf, &dev->buf[0], sizeof(dev->buf));
+ } else {
+ memcpy(&dev->buf[0], msgs[0].buf, sizeof(dev->buf));
+ return 0;
+ } else {
+ return -EIO;
+static int test_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
+ test_bus *bus = (test_bus *) base;
+ uint16_t addr;
+ test_device *dev;
+ addr = msgs[0].addr >> SPARE_ADDRESS_BITS;
+ if (addr >= RTEMS_ARRAY_SIZE(bus->devices)) {
+ return -EIO;
+ dev = bus->devices[addr];
+ return (*dev->transfer)(&bus->base, msgs, msg_count, dev);
+static int test_set_clock(i2c_bus *base, unsigned long clock)
+ bus->clock = clock;
+ return 0;
+static void test_destroy(i2c_bus *base)
+ i2c_bus_destroy_and_free(base);
+static void test_simple_read_write(test_bus *bus, int fd)
+ static const char zero[] = { 0, 0, 0 };
+ static const char abc[] = { 'a', 'b', 'c' };
+ int rv;
+ char buf[3];
+ ssize_t n;
+ rv = ioctl(fd, I2C_SLAVE, DEVICE_SIMPLE_READ_WRITE);
+ rtems_test_assert(rv == 0);
+ errno = 0;
+ rv = ioctl(fd, 0xb00b);
+ rtems_test_assert(rv == -1);
+ rtems_test_assert(errno == ENOTTY);
+ errno = 0;
+ n = write(fd, &buf[0], 1000);
+ rtems_test_assert(n == -1);
+ rtems_test_assert(errno == EIO);
+ errno = 0;
+ n = read(fd, &buf[0], 1000);
+ memcmp(&bus->simple_read_write.buf[0], &zero[0], sizeof(buf)) == 0
+ n = write(fd, &abc[0], sizeof(buf));
+ rtems_test_assert(n == (ssize_t) sizeof(buf));
+ memcmp(&bus->simple_read_write.buf[0], &abc[0], sizeof(buf)) == 0
+ n = read(fd, &buf[0], sizeof(buf));
+ rtems_test_assert(memcmp(&buf[0], &abc[0], sizeof(buf)) == 0);
+static void test(void)
+ rtems_resource_snapshot snapshot;
+ test_bus *bus;
+ int rv;
+ int fd;
+ rtems_resource_snapshot_take(&snapshot);
+ bus = (test_bus *) i2c_bus_alloc_and_init(sizeof(*bus));
+ rtems_test_assert(bus != NULL);
+ bus->base.transfer = test_transfer;
+ bus->base.set_clock = test_set_clock;
+ bus->base.destroy = test_destroy;
+ bus->base.functionality = I2C_FUNC_I2C | I2C_FUNC_PROTOCOL_MANGLING
+ | I2C_FUNC_NOSTART;
+ bus->simple_read_write.base.transfer = test_simple_read_write_transfer;
+ bus->devices[0] = &bus->simple_read_write.base;
+ rv = i2c_bus_register(&bus->base, &bus_path[0]);
+ fd = open(&bus_path[0], O_RDWR);
+ rtems_test_assert(fd >= 0);
+ rtems_test_assert(bus->clock == 0);
+ rv = ioctl(fd, I2C_BUS_SET_CLOCK, 0xdeadbeefUL);
+ rtems_test_assert(bus->clock == 0xdeadbeef);
+ rv = ioctl(fd, I2C_BUS_OBTAIN);
+ rv = ioctl(fd, I2C_BUS_RELEASE);
+ rtems_test_assert(!bus->base.ten_bit_address);
+ rv = ioctl(fd, I2C_TENBIT, 1UL);
+ rtems_test_assert(bus->base.ten_bit_address);
+ rv = ioctl(fd, I2C_TENBIT, 0UL);
+ rtems_test_assert(!bus->base.use_pec);
+ rv = ioctl(fd, I2C_PEC, 1UL);
+ rtems_test_assert(bus->base.use_pec);
+ rv = ioctl(fd, I2C_PEC, 0UL);
+ rv = ioctl(fd, I2C_SLAVE, 123UL);
+ rtems_test_assert(bus->base.default_address == 123);
+ rv = ioctl(fd, I2C_SLAVE_FORCE, 456UL);
+ rtems_test_assert(bus->base.default_address == 456);
+ rtems_test_assert(bus->base.retries == 0);
+ rv = ioctl(fd, I2C_RETRIES, 1UL);
+ rtems_test_assert(bus->base.retries == 1);
+ rv = ioctl(fd, I2C_RETRIES, 0UL);
+ rtems_test_assert(bus->base.timeout == 0);
+ rv = ioctl(fd, I2C_TIMEOUT, 1UL);
+ rtems_test_assert(bus->base.timeout == 5);
+ rv = ioctl(fd, I2C_TIMEOUT, 0UL);
+ test_simple_read_write(bus, fd);
+ rv = close(fd);
+ rv = unlink(&bus_path[0]);
+ rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
+static void Init(rtems_task_argument arg)
+ TEST_BEGIN();
+ test();
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_MICROSECONDS_PER_TICK 2000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 7
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
1.8.4.5
