[PATCH 1/9] Add RTEMS port of Linux I2C user-space API
Thu Nov 13 09:30:19 UTC 2014
 cpukit/Makefile.am                 |   1 +
 cpukit/configure.ac                |   1 +
 cpukit/dev/Makefile.am             |  12 ++
 cpukit/dev/include/linux/i2c-dev.h | 137 +++++++++++++++++++
 cpukit/dev/include/linux/i2c.h     | 274 +++++++++++++++++++++++++++++++++++++
 cpukit/dev/preinstall.am           |  33 +++++
 6 files changed, 458 insertions(+)
 create mode 100644 cpukit/dev/Makefile.am
 create mode 100644 cpukit/dev/include/linux/i2c-dev.h
 create mode 100644 cpukit/dev/include/linux/i2c.h
 create mode 100644 cpukit/dev/preinstall.am
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 5e0ae72..b9e9992 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -5,6 +5,7 @@ include $(top_srcdir)/automake/multilib.am
 # librtemscpu
 SUBDIRS = . score rtems sapi posix
+SUBDIRS += dev
 SUBDIRS += libcsupport libblock libfs
 SUBDIRS += libnetworking librpc
 SUBDIRS += libi2c
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index b3c818c..4242062 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -391,6 +391,7 @@ RTEMS_AMPOLISH3
 AC_CONFIG_FILES([
 Doxyfile
 Makefile
+dev/Makefile
 rtems/Makefile
 sapi/Makefile
 score/Makefile
diff --git a/cpukit/dev/Makefile.am b/cpukit/dev/Makefile.am
new file mode 100644
index 0000000..5f8fee6
--- /dev/null
+++ b/cpukit/dev/Makefile.am
@@ -0,0 +1,12 @@
+include $(top_srcdir)/automake/compile.am
+include_devdir = $(includedir)/dev
+include_dev_HEADERS =
+include_linuxdir = $(includedir)/linux
+include_linux_HEADERS =
+include_linux_HEADERS += include/linux/i2c.h
+include_linux_HEADERS += include/linux/i2c-dev.h
+include $(srcdir)/preinstall.am
+include $(top_srcdir)/automake/local.am
diff --git a/cpukit/dev/include/linux/i2c-dev.h b/cpukit/dev/include/linux/i2c-dev.h
index 0000000..c0db3fe
--- /dev/null
+++ b/cpukit/dev/include/linux/i2c-dev.h
@@ -0,0 +1,137 @@
+ * @file
+ * @brief RTEMS Port of Linux I2C Device API
+ * @ingroup I2CLinux
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifndef _UAPI_LINUX_I2C_DEV_H
+#define _UAPI_LINUX_I2C_DEV_H
+#include <stdint.h>
+ * @addtogroup I2CLinux
+ * @name I2C IO Control Commands
+ * @brief Sets the count of transfer retries in case a slave
+ * device does not acknowledge a transaction.
+ * The argument type is unsigned long.
+#define I2C_RETRIES 0x701
+ * @brief Sets the transfer timeout in 10ms units.
+#define I2C_TIMEOUT 0x702
+ * @brief Sets the slave address.
+ * It is an error to set a slave address already used by another slave device.
+#define I2C_SLAVE 0x703
+ * @brief Forces setting the slave address.
+#define I2C_SLAVE_FORCE 0x706
+ * @brief Enables 10-bit addresses if argument is non-zero, otherwise
+ * disables 10-bit addresses.
+#define I2C_TENBIT 0x704
+ * @brief Gets the I2C controller functionality information.
+ * The argument type is a pointer to an unsigned long.
+#define I2C_FUNCS 0x705
+ * @brief Performs a combined read/write transfer.
+ * Only one stop condition is signalled.
+ * The argument type is a pointer to struct i2c_rdwr_ioctl_data.
+#define I2C_RDWR 0x707
+ * @brief Enables System Management Bus (SMBus) Packet Error Checking (PEC)
+ * if argument is non-zero, otherwise disables PEC.
+#define I2C_PEC 0x708
+ * @brief Performs an SMBus transfer.
+ * The argument type is a pointer to struct i2c_smbus_ioctl_data.
+#define I2C_SMBUS 0x720
+ * @brief Argument type for I2C_SMBUS IO control call.
+struct i2c_smbus_ioctl_data {
+  uint8_t read_write;
+  uint8_t command;
+  uint32_t size;
+  union i2c_smbus_data *data;
+ * @brief Argument type for I2C_RDWR IO control call.
+struct i2c_rdwr_ioctl_data {
+  struct i2c_msg *msgs;
+  uint32_t nmsgs;
+ * @brief Maximum count of messages for one IO control call.
+#define I2C_RDRW_IOCTL_MAX_MSGS 42
+#endif /* _UAPI_LINUX_I2C_DEV_H */
diff --git a/cpukit/dev/include/linux/i2c.h b/cpukit/dev/include/linux/i2c.h
index 0000000..eacacd7
--- /dev/null
+++ b/cpukit/dev/include/linux/i2c.h
@@ -0,0 +1,274 @@
+ * @file
+ * @brief RTEMS Port of Linux I2C API
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifndef _UAPI_LINUX_I2C_H
+#define _UAPI_LINUX_I2C_H
+ * @defgroup I2CLinux Linux I2C User-Space API
+ * @ingroup I2C
+ * @brief RTEMS port of Linux I2C user-space API.
+ * Additional documentation is available through the Linux sources, see
+ * - /usr/src/linux/include/uapi/linux/i2c.h,
+ * - /usr/src/linux/include/uapi/linux/i2c-dev.h, and
+ * - /usr/src/linux/Documentation/i2c.
+ * @name I2C Message Flags
+ * @brief I2C message flag to indicate a 10-bit address.
+ * The controller must support this as indicated by the I2C_FUNC_10BIT_ADDR
+ * functionality.
+ * @see i2c_msg.
+#define I2C_M_TEN 0x0010
+ * @brief I2C message flag to indicate a read transfer (from slave to master).
+ * @see i2c_msg.
+#define I2C_M_RD 0x0001
+ * @brief I2C message flag to signal a stop condition even if this is not the
+ * last message.
+ * @ref I2C_FUNC_PROTOCOL_MANGLING functionality.
+ * @see i2c_msg.
+#define I2C_M_STOP 0x8000
+ * @brief I2C message flag to omit start condition and slave address.
+ * @ref I2C_FUNC_NOSTART functionality.
+ * @see i2c_msg.
+#define I2C_M_NOSTART 0x4000
+ * @brief I2C message flag to reverse the direction flag.
+ * @see i2c_msg.
+#define I2C_M_REV_DIR_ADDR 0x2000
+ * @brief I2C message flag to ignore a non-acknowledge.
+ * @see i2c_msg.
+#define I2C_M_IGNORE_NAK 0x1000
+ * @brief I2C message flag to omit a master acknowledge/non-acknowledge in a
+ * read transfer.
+ * @see i2c_msg.
+#define I2C_M_NO_RD_ACK 0x0800
+ * @brief I2C message flag to indicate that the message data length is the
+ * first received byte.
+ * The message data buffer must be large enough to store up to 32 bytes, the
+ * initial length byte and the SMBus PEC (if used).  Initialize the message
+ * length to one.  The message length is incremented by the count of received
+ * data bytes.
+ * @see i2c_msg.
+#define I2C_M_RECV_LEN 0x0400
+ * @brief I2C transfer message.
+struct i2c_msg {
+   * @brief The slave address.
+   * In case the @ref I2C_M_TEN flag is set, then this is a 10-bit address,
+   * otherwise it is a 7-bit address.
+  uint16_t addr;
+   * @brief The message flags.
+   * Valid flags are
+   * - @ref I2C_M_TEN,
+   * - @ref I2C_M_RD,
+   * - @ref I2C_M_STOP,
+   * - @ref I2C_M_NOSTART,
+   * - @ref I2C_M_REV_DIR_ADDR,
+   * - @ref I2C_M_IGNORE_NAK,
+   * - @ref I2C_M_NO_RD_ACK, and
+   * - @ref I2C_M_RECV_LEN.
+  uint16_t flags;
+   * @brief The message data length in bytes.
+  uint16_t len;
+   * @brief Pointer to the message data.
+  uint8_t *buf;
+ * @name I2C Controller Functionality
+#define I2C_FUNC_I2C 0x00000001
+#define I2C_FUNC_10BIT_ADDR 0x00000002
+#define I2C_FUNC_PROTOCOL_MANGLING 0x00000004
+#define I2C_FUNC_SMBUS_PEC 0x00000008
+#define I2C_FUNC_NOSTART 0x00000010
+#define I2C_FUNC_SMBUS_BLOCK_PROC_CALL 0x00008000
+#define I2C_FUNC_SMBUS_QUICK 0x00010000
+#define I2C_FUNC_SMBUS_READ_BYTE 0x00020000
+#define I2C_FUNC_SMBUS_WRITE_BYTE 0x00040000
+#define I2C_FUNC_SMBUS_READ_BYTE_DATA 0x00080000
+#define I2C_FUNC_SMBUS_WRITE_BYTE_DATA 0x00100000
+#define I2C_FUNC_SMBUS_READ_WORD_DATA 0x00200000
+#define I2C_FUNC_SMBUS_WRITE_WORD_DATA 0x00400000
+#define I2C_FUNC_SMBUS_PROC_CALL 0x00800000
+#define I2C_FUNC_SMBUS_READ_BLOCK_DATA 0x01000000
+#define I2C_FUNC_SMBUS_WRITE_BLOCK_DATA 0x02000000
+#define I2C_FUNC_SMBUS_READ_I2C_BLOCK 0x04000000
+#define I2C_FUNC_SMBUS_WRITE_I2C_BLOCK 0x08000000
+#define I2C_FUNC_SMBUS_BYTE \
+  (I2C_FUNC_SMBUS_READ_BYTE | I2C_FUNC_SMBUS_WRITE_BYTE)
+#define I2C_FUNC_SMBUS_BYTE_DATA \
+  (I2C_FUNC_SMBUS_READ_BYTE_DATA | I2C_FUNC_SMBUS_WRITE_BYTE_DATA)
+#define I2C_FUNC_SMBUS_WORD_DATA \
+  (I2C_FUNC_SMBUS_READ_WORD_DATA | I2C_FUNC_SMBUS_WRITE_WORD_DATA)
+#define I2C_FUNC_SMBUS_BLOCK_DATA \
+  (I2C_FUNC_SMBUS_READ_BLOCK_DATA | I2C_FUNC_SMBUS_WRITE_BLOCK_DATA)
+#define I2C_FUNC_SMBUS_I2C_BLOCK \
+  (I2C_FUNC_SMBUS_READ_I2C_BLOCK | I2C_FUNC_SMBUS_WRITE_I2C_BLOCK)
+#define I2C_FUNC_SMBUS_EMUL \
+  (I2C_FUNC_SMBUS_QUICK | I2C_FUNC_SMBUS_BYTE | I2C_FUNC_SMBUS_BYTE_DATA \
+    | I2C_FUNC_SMBUS_WORD_DATA | I2C_FUNC_SMBUS_PROC_CALL \
+    | I2C_FUNC_SMBUS_WRITE_BLOCK_DATA | I2C_FUNC_SMBUS_I2C_BLOCK \
+    | I2C_FUNC_SMBUS_PEC)
+ * @brief Maximum SMBus data block count.
+#define I2C_SMBUS_BLOCK_MAX 32
+ * @brief SMBus data.
+union i2c_smbus_data {
+  uint8_t byte;
+  uint16_t word;
+  uint8_t block[I2C_SMBUS_BLOCK_MAX + 2];
+ * @name SMBus Transfer Read and Write Markers
+#define I2C_SMBUS_READ 1
+#define I2C_SMBUS_WRITE 0
+ * @name SMBus Transaction Types
+#define I2C_SMBUS_QUICK 0
+#define I2C_SMBUS_BYTE 1
+#define I2C_SMBUS_BYTE_DATA 2
+#define I2C_SMBUS_WORD_DATA 3
+#define I2C_SMBUS_PROC_CALL 4
+#define I2C_SMBUS_BLOCK_DATA 5
+#define I2C_SMBUS_I2C_BLOCK_BROKEN 6
+#define I2C_SMBUS_BLOCK_PROC_CALL 7
+#define I2C_SMBUS_I2C_BLOCK_DATA 8
+#endif /* _UAPI_LINUX_I2C_H */
diff --git a/cpukit/dev/preinstall.am b/cpukit/dev/preinstall.am
index 0000000..a17d606
--- /dev/null
+++ b/cpukit/dev/preinstall.am
@@ -0,0 +1,33 @@
+## Automatically generated by ampolish3 - Do not edit
+if AMPOLISH3
+$(srcdir)/preinstall.am: Makefile.am
+	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
+endif
+PREINSTALL_DIRS =
+DISTCLEANFILES = $(PREINSTALL_DIRS)
+all-am: $(PREINSTALL_FILES)
+PREINSTALL_FILES =
+CLEANFILES = $(PREINSTALL_FILES)
+$(PROJECT_INCLUDE)/dev/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/dev
+	@: > $(PROJECT_INCLUDE)/dev/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/dev/$(dirstamp)
+$(PROJECT_INCLUDE)/linux/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/linux
+	@: > $(PROJECT_INCLUDE)/linux/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/linux/$(dirstamp)
+$(PROJECT_INCLUDE)/linux/i2c.h: include/linux/i2c.h $(PROJECT_INCLUDE)/linux/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/linux/i2c.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/linux/i2c.h
+$(PROJECT_INCLUDE)/linux/i2c-dev.h: include/linux/i2c-dev.h $(PROJECT_INCLUDE)/linux/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/linux/i2c-dev.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/linux/i2c-dev.h
1.8.4.5
