RTEMS toolchain for Epiphany?
Thu Nov 13 18:47:27 UTC 2014
Hi
I couldn't get gdb og gcc to build even for epiphany-elf but I did
include patch that I think is all that is needed for RTEMS.
I did manage to build binutils from their repo for both elf
and rtems variants.
At least it is a starting point. You can work with their
community to get their tools built as epiphany-elf and
then just change the target.
--joel
On 11/13/2014 12:22 PM, Hesham Moustafa wrote:
> On Thu Nov 13 2014 at 5:58:25 PM Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>     On November 13, 2014 11:56:32 AM CST, Hesham Moustafa
>     <heshamelmatary at gmail.com <mailto:heshamelmatary at gmail.com>> wrote:
>     >Hi,
>     >I want to let you know that I found their main repos [1] Can I start
>     >from there? Imitating what has been done with OpenRISC?
>     Basically. Except you only need their repos for binutils and gdb.
>     We use GCC and Newlib from upstream.
> Great, I am waiting for these patches.
>     I have binutils patches
>     >[1] https://github.com/adapteva
>     >Regards,
>     >Hesham
>     >On Thu Nov 13 2014 at 3:29:14 PM Hesham Moustafa
>     >On Thu Nov 13 2014 at 2:59:33 PM Joel Sherrill
>     >On 11/13/2014 8:07 AM, Joel Sherrill wrote:
>     >> On November 13, 2014 6:30:48 AM CST, Hesham Moustafa
>     >>> Hi all,
>     >>> I want to ask about the status of RTEMS toolchain for Epiphany
>     >>> architecture. I think Joel mentioned that there are some previous
>     >>> support for it; and if yes, does the toolchain need some
>     additional
>     >>> work?
>     >> To give you a quick answer, I emailed the people who did the port.
>     >There apparently is a github repo with some of it and some is
>     merged. I
>     >will dig through the emails and post the proper links.
>     >> One issue they mentioned was that the gdb port had many core/thread
>     >support that made it more than a simple port.
>     >From Jeremy Bennett:
>     >> piphany tool chain development runs on quite a tight budget,
>     and its
>     >> GDB implementation is quite complex (it has to pretend cores are
>     >> threads, when they don't completely share an address space).  So we
>     >> haven't had the effort to devote to upstreaming.  And we were
>     >> reluctant to push the simulator upstream without a GDB
>     implementation
>     >> to go with it.  You can of course access the code here:
>     >>   https://github.com/adapteva/epiphany-binutils-gdb
>     >> Epiphany GDB is still in quite substantial flux, due to the need to
>     >> support the Eclipse multicore visualizer with asynchronous and
>     >> non-stop support.
>     >The upstream gcc and newlib are OK. But since binutils and gdb are
>     >now in a single repo, it will need to come from the github site until
>     >it is merged upstream. And obviously patches just need to go upstream
>     >to whereever the code is. :)
>     >Jeremy also encouraged you to openly discuss things on their forums.
>     >He thought you would get good insight and advice there. And I don't
>     >doubt that.
>     >Thank you, I will.
>     >If it is a relatively low volume place, I may track it. But my email
>     >volume
>     >is already high and I don't have time to poke around on a bulletin
>     >board.
>     >> It will not have RTEMS as a target but that shouldn't be hard to
>     >address once we know where the master binutils, GCC, Newlib, and gdb
>     >are.
>     >So do you want me to try to build a toolchain and get you some
>     starting
>     >patches?
>     >Sure that will definitely help as a starting point. And if you are so
>     >busy, you can just drop me HOWTO  instructions.
>     >> Then you are porting.
>     >>> Regards,
>     >>> Hesham
>     >> _______________________________________________
>     >> devel mailing list
>     >> devel at rtems.org <mailto:devel at rtems.org>
>     >> http://lists.rtems.org/mailman/listinfo/devel
>     >Joel Sherrill, Ph.D.             Director of Research & Development
>     >joel.sherrill at OARcorp.com        On-Line Applications Research
>     >Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>     >Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141113/7b203d6d/attachment-0002.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141113/7b203d6d/attachment-0008.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141113/7b203d6d/attachment-0009.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141113/7b203d6d/attachment-0010.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141113/7b203d6d/attachment-0011.bin>
