Rehosting Update
Cláudio Silva
claudiodcsilva at gmail.com
Thu Nov 20 16:17:28 UTC 2014
Hi,
Password recovery is working correctly, but I can't access any patch
attached to a ticket. This feature seems to be broken.
Cláudio
On Thu Nov 20 2014 at 15:54:58 Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> Hi
> https://devel.rtems.org/ is now up with our Trac instance.
> As mentioned in a previous update, this merges Bugzilla and
> Mediawiki. All the old content is there but it has likely moved
> around. If you spot something broken or out of date, fix it
> or report it.
> Old bugzilla accounts have been migrated to Trac but the passwords
> all need to be reset. The accounts the account portion of an email
> so for user at example.com, it would be "user". Mine is joel.sherrill
> since I use joel.sherrill at oarcorp.com.
> Passwords must be reset emails will go to the registered account email.
> If anyone has problems, email amar at rtems.org.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141120/e5fb65ce/attachment-0002.html>
