Trac patch issue was Re: Rehosting Update
Thu Nov 20 16:33:46 UTC 2014
Amar.. explicitly bringing you in since you likely missed this.
On 11/20/2014 10:17 AM, Cláudio Silva wrote:
> Hi,
> Password recovery is working correctly, but I can't access any patch
> attached to a ticket. This feature seems to be broken.
> Cláudio
> On Thu Nov 20 2014 at 15:54:58 Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>     Hi
>     https://devel.rtems.org/ is now up with our Trac instance.
>     As mentioned in a previous update, this merges Bugzilla and
>     Mediawiki. All the old content is there but it has likely moved
>     around. If you spot something broken or out of date, fix it
>     or report it.
>     Old bugzilla accounts have been migrated to Trac but the passwords
>     all need to be reset.  The accounts the account portion of an email
>     so for user at example.com <mailto:user at example.com>, it would be
>     "user". Mine is joel.sherrill
>     since I use joel.sherrill at oarcorp.com
>     <mailto:joel.sherrill at oarcorp.com>.
>     Passwords must be reset emails will go to the registered account
>     email.
>     If anyone has problems, email amar at rtems.org <mailto:amar at rtems.org>.
>     Joel Sherrill, Ph.D.             Director of Research & Development
>     joel.sherrill at OARcorp.com        On-Line Applications Research
>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>     Support Available                (256) 722-9985
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141120/500b3ac0/attachment-0002.html>
