rtems-tester coverage patches break or1k/sis runs
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Oct 1 17:44:41 UTC 2014
Krzysztof/Hesham,
And devel@ since this needs to be public now.
I am trying to test or1ksim and sis using rtems-tester.
We need to get Krzysztof's patches merged and I am
just trying to run down all the issues I can.
You both have made some changes to the repository
and I am having issues. Krzysztof's are on a branch
for me and I have attached them. Except for the note
before the remains of the old email, all issues are
with Krzysztof's changes.
Hesham's are all committed.
$ ~/rtems-4.11-work/rtems-tools/tester/rtems-test --log=or1ksim.log
--rtems-bsp=sis --rtems-tools=/users/joel/rtems-4.11-work/tools
sparc-rtems4.11/c/sis/testsuites/samples/hello/
RTEMS Testing - Tester, v0.2.0
error: gdb.cfg:59: macro '%{_coverage}' not found
warning: switched to dry run due to errors
error: gdb.cfg:59: invalid if bool value: %if %{_coverage}
[1/1] p:0 f:0 t:0 i:0 | sparc/sis: hello.exe
When I use Krzysztof's branch with the or1ksim as shown below,
it adds a 1 to the end of the qemu-system-or32 invocation.
On 10/1/2014 11:19 AM, Hesham Moustafa wrote:
> I cloned a vanilla RTEMS tester, and it works fine with me with the
> following command
> "~/development/rtems/test/rtems-tester/tester/rtems-test
> --log=or1ksim.log --rtems-bsp=or1ksim
> /home/hesham/build/or1k-rtems4.11/c/or1ksim/testsuites/"
But it seemed to run a long time and then I killed it when
I used your command.
And when I try to run it on sis, you do need the --rtems-tools
argument to find the simulator. I don't know what the difference
for this is when doing the or1ksim. I think it should be required
for consistency.
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141001/8a38dff3/attachment-0001.obj>
