[PATCH 2/3 v2] LEON3 SMP: support static interrupt affinity
Daniel Hellstrom
daniel at gaisler.com
Wed Oct 8 13:49:37 UTC 2014
c/src/lib/libbsp/sparc/leon3/include/bsp.h | 11 +++++++
c/src/lib/libbsp/sparc/shared/irq/irq-shared.c | 38 ++++++++++++++++++++----
2 files changed, 43 insertions(+), 6 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index a4a4a6f..3bd48bc 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -222,6 +222,17 @@ extern void BSP_shared_interrupt_mask(int irq);
extern unsigned char LEON3_mp_irq;
+#ifdef RTEMS_SMP
+/* Weak table used to implement static interrupt CPU affinity in a SMP
+ * configuration. The array index is the interrupt to be looked up, and
+ * the array[INTERRUPT] content is the CPU number relative to boot CPU
+ * index that will be servicing the interrupts from the IRQ source. The
+ * default is to let the first CPU (the boot cpu) to handle all
+ * interrupts (all zeros).
+extern unsigned char sparc_irq_to_cpu[32];
+#endif
#ifdef __cplusplus
#endif
diff --git a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
index b49621f..105dcdd 100644
--- a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
+++ b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
@@ -2,6 +2,30 @@
#include <bsp.h>
#include <bsp/irq-generic.h>
+#if defined(RTEMS_SMP) && defined(LEON3)
+/* Interrupt to CPU map. Default to CPU0 since in BSS. */
+unsigned char sparc_irq_to_cpu[32] __attribute__((weak));
+/* On SMP use map table above relative to SMP Boot CPU (normally CPU0) */
+static inline int bsp_irq_cpu(int irq)
+ /* protect from bad user configuration, default to boot cpu */
+ if (rtems_configuration_get_maximum_processors() <= sparc_irq_to_cpu[irq])
+ sparc_irq_to_cpu[irq] = 0;
+ return LEON3_Cpu_Index + sparc_irq_to_cpu[irq];
+#else
+/* when not SMP the local CPU is returned */
+#ifdef LEON3
+ return _LEON3_Get_current_processor();
+#else
+ return 0;
+#endif
+#endif
static inline void bsp_dispatch_irq(int irq)
bsp_interrupt_handler_entry *e =
@@ -54,26 +78,28 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
- BSP_Unmask_interrupt((int)vector);
+ int irq = (int)vector;
+ BSP_Cpu_Unmask_interrupt(irq, bsp_irq_cpu(irq));
- return RTEMS_SUCCESSFUL;
+ return RTEMS_SUCCESSFUL;
rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
- BSP_Mask_interrupt((int)vector);
+ BSP_Cpu_Mask_interrupt(irq, bsp_irq_cpu(irq));
- BSP_Mask_interrupt(irq);
void BSP_shared_interrupt_unmask(int irq)
- BSP_Unmask_interrupt(irq);
void BSP_shared_interrupt_clear(int irq)
1.7.0.4
