[PATCH 18/52] arm/shared/abort/abort.c: Fix warnings and clean up
Wed Oct 8 19:16:09 UTC 2014
 c/src/lib/libbsp/arm/shared/abort/abort.c | 44 +++++++++++++++++++------------
 1 file changed, 27 insertions(+), 17 deletions(-)
diff --git a/c/src/lib/libbsp/arm/shared/abort/abort.c b/c/src/lib/libbsp/arm/shared/abort/abort.c
index a686a62..05432f8 100644
--- a/c/src/lib/libbsp/arm/shared/abort/abort.c
+++ b/c/src/lib/libbsp/arm/shared/abort/abort.c
@@ -1,6 +1,10 @@
  *  ARM CPU Dependent Source
+ *  If you want a small footprint RTEMS, pls use simple_abort.c
  *  COPYRIGHT (c) 2007 Ray Xu.
  *  mailto: Rayx at gmail dot com
@@ -10,8 +14,6 @@
  *  Copyright (c) 2002 Advent Networks, Inc
  *      Jay Monkman <jmonkman at adventnetworks.com>
- *  If you want a small footprint RTEMS, pls use simple_abort.c
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
  *  http://www.rtems.org/license/LICENSE.
@@ -44,21 +46,26 @@
 #define SET_REG(r, ctx, v)   (((uint32_t   *)ctx)[r] = v)
 #define GET_OFFSET(insn)     (insn & 0xfff)
-uint32_t 	g_data_abort_cnt = 0;
+ * Prototypes
+void _print_full_context(uint32_t);
+void do_data_abort(uint32_t, uint32_t, Context_Control *);
+uint32_t g_data_abort_cnt = 0;
 /*this is a big overhead for MCU only got 16K RAM*/
-uint32_t 	g_data_abort_insn_list[1024];
+uint32_t g_data_abort_insn_list[1024];
 char *_print_full_context_mode2txt[0x20]={
-   [0x0]="user",  /* User */
-	[0x1]="fiq",   /* FIQ - Fast Interrupt Request */
-	[0x2]="irq",   /* IRQ - Interrupt Request */
-	[0x3]="super", /* Supervisor */
-	[0x7]="abort", /* Abort */
-	[0xb]="undef", /* Undefined */
-	[0xf]="system" /* System */
+  [0x0]="user",  /* User */
+  [0x1]="fiq",   /* FIQ - Fast Interrupt Request */
+  [0x2]="irq",   /* IRQ - Interrupt Request */
+  [0x3]="super", /* Supervisor */
+  [0x7]="abort", /* Abort */
+  [0xb]="undef", /* Undefined */
+  [0xf]="system" /* System */
 void _print_full_context(uint32_t spsr)
@@ -82,7 +89,7 @@ void _print_full_context(uint32_t spsr)
               : [arm_switch_reg] "=&r" (arm_switch_reg), [prev_sp] "=&r" (prev_sp), [prev_lr] "=&r" (prev_lr),
 		[cpsr] "=&r" (cpsr)
               : [spsr] "r" (spsr)
-	      : "cc");
+              : "cc");
     printk("Previous sp=0x%08x lr=0x%08x and actual cpsr=%08x\n",
            prev_sp, prev_lr, cpsr);
@@ -102,8 +109,11 @@ void _print_full_context(uint32_t spsr)
  * All unhandled instructions cause the system to hang.
-void do_data_abort(uint32_t   insn, uint32_t   spsr,
-                    Context_Control *ctx)
+  uint32_t insn,
+  uint32_t spsr,
+  Context_Control *ctx
     /* Clarify, which type is correct, CPU_Exception_frame or Context_Control */
     uint8_t               decode;
@@ -156,6 +166,6 @@ void do_data_abort(uint32_t   insn, uint32_t   spsr,
     while(1) {
         continue;
-    return;
+    (void) level; /* avoid set but unused warning */
1.9.3
