[PATCH 18/52] arm/shared/abort/abort.c: Fix warnings and clean up
Wed Oct 8 20:14:06 UTC 2014
On Wed, Oct 8, 2014 at 3:16 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>  c/src/lib/libbsp/arm/shared/abort/abort.c | 44 +++++++++++++++++++------------
>  1 file changed, 27 insertions(+), 17 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/shared/abort/abort.c b/c/src/lib/libbsp/arm/shared/abort/abort.c
> index a686a62..05432f8 100644
> --- a/c/src/lib/libbsp/arm/shared/abort/abort.c
> +++ b/c/src/lib/libbsp/arm/shared/abort/abort.c
> @@ -1,6 +1,10 @@
>   *  ARM CPU Dependent Source
> + *  If you want a small footprint RTEMS, pls use simple_abort.c
>   *  COPYRIGHT (c) 2007 Ray Xu.
>   *  mailto: Rayx at gmail dot com
> @@ -10,8 +14,6 @@
>   *  Copyright (c) 2002 Advent Networks, Inc
>   *      Jay Monkman <jmonkman at adventnetworks.com>
> - *  If you want a small footprint RTEMS, pls use simple_abort.c
>   *  The license and distribution terms for this file may be
>   *  found in the file LICENSE in this distribution or at
>   *  http://www.rtems.org/license/LICENSE.
> @@ -44,21 +46,26 @@
>  #define SET_REG(r, ctx, v)   (((uint32_t   *)ctx)[r] = v)
>  #define GET_OFFSET(insn)     (insn & 0xfff)
> -uint32_t       g_data_abort_cnt = 0;
> + * Prototypes
> +void _print_full_context(uint32_t);
> +void do_data_abort(uint32_t, uint32_t, Context_Control *);
> +uint32_t g_data_abort_cnt = 0;
>  /*this is a big overhead for MCU only got 16K RAM*/
> -uint32_t       g_data_abort_insn_list[1024];
> +uint32_t g_data_abort_insn_list[1024];
>  char *_print_full_context_mode2txt[0x20]={
> -   [0x0]="user",  /* User */
> -       [0x1]="fiq",   /* FIQ - Fast Interrupt Request */
> -       [0x2]="irq",   /* IRQ - Interrupt Request */
> -       [0x3]="super", /* Supervisor */
> -       [0x7]="abort", /* Abort */
> -       [0xb]="undef", /* Undefined */
> -       [0xf]="system" /* System */
> +  [0x0]="user",  /* User */
> +  [0x1]="fiq",   /* FIQ - Fast Interrupt Request */
> +  [0x2]="irq",   /* IRQ - Interrupt Request */
> +  [0x3]="super", /* Supervisor */
> +  [0x7]="abort", /* Abort */
> +  [0xb]="undef", /* Undefined */
> +  [0xf]="system" /* System */
>  void _print_full_context(uint32_t spsr)
> @@ -82,7 +89,7 @@ void _print_full_context(uint32_t spsr)
>                : [arm_switch_reg] "=&r" (arm_switch_reg), [prev_sp] "=&r" (prev_sp), [prev_lr] "=&r" (prev_lr),
>                 [cpsr] "=&r" (cpsr)
>                : [spsr] "r" (spsr)
> -             : "cc");
> +              : "cc");
>      printk("Previous sp=0x%08x lr=0x%08x and actual cpsr=%08x\n",
>             prev_sp, prev_lr, cpsr);
> @@ -102,8 +109,11 @@ void _print_full_context(uint32_t spsr)
>   * All unhandled instructions cause the system to hang.
> -void do_data_abort(uint32_t   insn, uint32_t   spsr,
> -                    Context_Control *ctx)
> +  uint32_t insn,
> +  uint32_t spsr,
> +  Context_Control *ctx
>      /* Clarify, which type is correct, CPU_Exception_frame or Context_Control */
>      uint8_t               decode;
> @@ -156,6 +166,6 @@ void do_data_abort(uint32_t   insn, uint32_t   spsr,
>      while(1) {
>          continue;
> -    return;
> +    (void) level; /* avoid set but unused warning */
I'd prefer to see this closer to where level was set.
-Gedare
> 1.9.3
> devel mailing list
> devel at rtems.org
