[PATCH 48/52] samples/unlimited: Fix printf() warning and clean up
Wed Oct 8 19:16:39 UTC 2014
 testsuites/samples/unlimited/init.c   | 23 ++++++++++++++---------
 testsuites/samples/unlimited/system.h |  2 +-
 testsuites/samples/unlimited/test1.c  |  2 +-
 testsuites/samples/unlimited/test2.c  | 28 ++++++++++++++++------------
 testsuites/samples/unlimited/test3.c  |  2 +-
 5 files changed, 33 insertions(+), 24 deletions(-)
diff --git a/testsuites/samples/unlimited/init.c b/testsuites/samples/unlimited/init.c
index 06e0c3a..0fb5505 100644
--- a/testsuites/samples/unlimited/init.c
+++ b/testsuites/samples/unlimited/init.c
@@ -55,20 +55,21 @@ rtems_task Init(
 rtems_task test_task(
   rtems_task_argument my_number
   rtems_event_set out;
+  unsigned int    my_n = (unsigned int) my_number;
-  printf( "task %" PRIdrtems_task_argument " has started.\n",  my_number);
+  printf( "task %" PRIdrtems_task_argument " has started.\n",  my_n);
   rtems_event_receive(1, RTEMS_WAIT | RTEMS_EVENT_ANY, 0, &out);
-  printf( "task %" PRIdrtems_task_argument " ending.\n",  my_number);
+  printf( "task %" PRIdrtems_task_argument " ending.\n",  my_n);
   rtems_task_delete(RTEMS_SELF);
-void destory_all_tasks(
+void destroy_all_tasks(
   const char *who
@@ -78,19 +79,23 @@ void destory_all_tasks(
    *  If the id is not zero, signal the task to delete.
-  for (task = 0; task < MAX_TASKS; task++)
-    if (task_id[task])
-      printf(" %s : signal task %08" PRIxrtems_id " to delete, ", who, task_id[task]);
+  for (task = 0; task < MAX_TASKS; task++) {
+    if (task_id[task]) {
+      printf(
+        " %s : signal task %08" PRIxrtems_id " to delete, ",
+         who,
+         task_id[task]
       fflush(stdout);
       rtems_event_send(task_id[task], 1);
       task_id[task] = 0;
 bool status_code_bad(
   rtems_status_code status_code
   if (status_code != RTEMS_SUCCESSFUL)
diff --git a/testsuites/samples/unlimited/system.h b/testsuites/samples/unlimited/system.h
index 911aa69..5da5d06 100644
--- a/testsuites/samples/unlimited/system.h
+++ b/testsuites/samples/unlimited/system.h
@@ -24,7 +24,7 @@ rtems_task test_task(
 void
-destory_all_tasks(
+destroy_all_tasks(
   const char *who
diff --git a/testsuites/samples/unlimited/test1.c b/testsuites/samples/unlimited/test1.c
index 9d90af0..f02857c 100644
--- a/testsuites/samples/unlimited/test1.c
+++ b/testsuites/samples/unlimited/test1.c
@@ -99,7 +99,7 @@ void test1()
     exit( 1 );
-  destory_all_tasks("TEST1");
+  destroy_all_tasks("TEST1");
   the_information->auto_extend = auto_extend;
diff --git a/testsuites/samples/unlimited/test2.c b/testsuites/samples/unlimited/test2.c
index 911451f..411a401 100644
--- a/testsuites/samples/unlimited/test2.c
+++ b/testsuites/samples/unlimited/test2.c
@@ -95,7 +95,7 @@ void test2()
     printf( " FAIL2 : not enough tasks created -\n"
             "         task created = %" PRIi32 ", required number = %i\n",
             task_count, (TASK_ALLOCATION_SIZE * 5) - TASK_INDEX_OFFSET);
-    destory_all_tasks("TEST2");
+    destroy_all_tasks("TEST2");
     exit( 1 );
@@ -112,7 +112,7 @@ void test2()
         printf( " FAIL2 : remove task has a 0 id -\n"
                 "         task number = %" PRIi32 "\n",
                 remove_task);
         exit( 1 );
@@ -122,7 +122,8 @@ void test2()
       removed_ids[task++] = task_id[remove_task];
-      printf(" TEST2 : block %" PRIi32 " remove, signal task %08" PRIxrtems_id ", ", block, task_id[remove_task]);
+      printf(" TEST2 : block %" PRIi32 " remove, signal task %08"
+               PRIxrtems_id ", ", block, task_id[remove_task]);
       rtems_event_send(task_id[remove_task], 1);
       task_id[remove_task] = 0;
@@ -144,7 +145,7 @@ void test2()
     if (id_slot == MAX_TASKS)
       printf( " FAIL2 : no free task id slot.\n");
       exit( 1 );
@@ -164,11 +165,12 @@ void test2()
       printf( " FAIL2 : re-creating a task -\n"
               id_slot);
       exit( 1 );
-    printf("number = %3" PRIi32 ", id = %08" PRIxrtems_id ", starting, ", task_count, task_id[id_slot]);
+    printf("number = %3" PRIi32 ", id = %08" PRIxrtems_id ", starting, ",
+           task_count, task_id[id_slot]);
     result = rtems_task_start(task_id[id_slot],
                               test_task,
@@ -179,7 +181,7 @@ void test2()
       printf( " FAIL : re-starting a task -\n"
               id_slot);
       exit( 1 );
@@ -190,7 +192,8 @@ void test2()
     NEXT_TASK_NAME(c1, c2, c3, c4);
-     *  Search the removed ids to see if it existed, clear the removed id when found
+     *  Search the removed ids to see if it existed, clear the removed id
+     *  when found
     for (remove_task = 0; remove_task < (TASK_ALLOCATION_SIZE * 2); remove_task++)
@@ -212,9 +215,10 @@ void test2()
       for (allocated_id = 0; allocated_id < MAX_TASKS; allocated_id++)
         if ((task_id[id_slot] == task_id[allocated_id]) && (id_slot != allocated_id))
-          printf( " FAIL2 : the new id is the same as an id already allocated -\n"
-                  "         task id = %08" PRIxrtems_id "\n",
-                  task_id[id_slot]);
+          printf(
+            " FAIL2 : the new id is the same as an id already allocated -\n"
+            "         task id = %08" PRIxrtems_id "\n",
+            task_id[id_slot]);
           exit( 1 );
@@ -227,7 +231,7 @@ void test2()
     task_count++;
   printf( " TEST2 : completed\n" );
diff --git a/testsuites/samples/unlimited/test3.c b/testsuites/samples/unlimited/test3.c
index 247d175..6330f3c 100644
--- a/testsuites/samples/unlimited/test3.c
+++ b/testsuites/samples/unlimited/test3.c
@@ -144,7 +144,7 @@ void test3()
-  destory_all_tasks("TEST3");
+  destroy_all_tasks("TEST3");
   printf( " TEST3 : completed\n" );
1.9.3
