[PATCH 48/52] samples/unlimited: Fix printf() warning and clean up
Wed Oct 8 20:20:03 UTC 2014
On Wed, Oct 8, 2014 at 3:16 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>  testsuites/samples/unlimited/init.c   | 23 ++++++++++++++---------
>  testsuites/samples/unlimited/system.h |  2 +-
>  testsuites/samples/unlimited/test1.c  |  2 +-
>  testsuites/samples/unlimited/test2.c  | 28 ++++++++++++++++------------
>  testsuites/samples/unlimited/test3.c  |  2 +-
>  5 files changed, 33 insertions(+), 24 deletions(-)
> diff --git a/testsuites/samples/unlimited/init.c b/testsuites/samples/unlimited/init.c
> index 06e0c3a..0fb5505 100644
> --- a/testsuites/samples/unlimited/init.c
> +++ b/testsuites/samples/unlimited/init.c
> @@ -55,20 +55,21 @@ rtems_task Init(
>  rtems_task test_task(
>    rtems_task_argument my_number
>    rtems_event_set out;
> +  unsigned int    my_n = (unsigned int) my_number;
> -  printf( "task %" PRIdrtems_task_argument " has started.\n",  my_number);
> +  printf( "task %" PRIdrtems_task_argument " has started.\n",  my_n);
Should this just be %u now, since you converted the my_number? ditto below.
>    rtems_event_receive(1, RTEMS_WAIT | RTEMS_EVENT_ANY, 0, &out);
> -  printf( "task %" PRIdrtems_task_argument " ending.\n",  my_number);
> +  printf( "task %" PRIdrtems_task_argument " ending.\n",  my_n);
>    rtems_task_delete(RTEMS_SELF);
> -void destory_all_tasks(
> +void destroy_all_tasks(
>    const char *who
> @@ -78,19 +79,23 @@ void destory_all_tasks(
>     *  If the id is not zero, signal the task to delete.
> -  for (task = 0; task < MAX_TASKS; task++)
> -    if (task_id[task])
> -      printf(" %s : signal task %08" PRIxrtems_id " to delete, ", who, task_id[task]);
> +  for (task = 0; task < MAX_TASKS; task++) {
> +    if (task_id[task]) {
> +      printf(
> +        " %s : signal task %08" PRIxrtems_id " to delete, ",
> +         who,
> +         task_id[task]
>        fflush(stdout);
>        rtems_event_send(task_id[task], 1);
>        task_id[task] = 0;
>  bool status_code_bad(
>    rtems_status_code status_code
>    if (status_code != RTEMS_SUCCESSFUL)
> diff --git a/testsuites/samples/unlimited/system.h b/testsuites/samples/unlimited/system.h
> index 911aa69..5da5d06 100644
> --- a/testsuites/samples/unlimited/system.h
> +++ b/testsuites/samples/unlimited/system.h
> @@ -24,7 +24,7 @@ rtems_task test_task(
>  void
> -destory_all_tasks(
> +destroy_all_tasks(
>    const char *who
> diff --git a/testsuites/samples/unlimited/test1.c b/testsuites/samples/unlimited/test1.c
> index 9d90af0..f02857c 100644
> --- a/testsuites/samples/unlimited/test1.c
> +++ b/testsuites/samples/unlimited/test1.c
> @@ -99,7 +99,7 @@ void test1()
>      exit( 1 );
> -  destory_all_tasks("TEST1");
> +  destroy_all_tasks("TEST1");
>    the_information->auto_extend = auto_extend;
> diff --git a/testsuites/samples/unlimited/test2.c b/testsuites/samples/unlimited/test2.c
> index 911451f..411a401 100644
> --- a/testsuites/samples/unlimited/test2.c
> +++ b/testsuites/samples/unlimited/test2.c
> @@ -95,7 +95,7 @@ void test2()
>      printf( " FAIL2 : not enough tasks created -\n"
>              "         task created = %" PRIi32 ", required number = %i\n",
>              task_count, (TASK_ALLOCATION_SIZE * 5) - TASK_INDEX_OFFSET);
> -    destory_all_tasks("TEST2");
> +    destroy_all_tasks("TEST2");
>      exit( 1 );
> @@ -112,7 +112,7 @@ void test2()
>          printf( " FAIL2 : remove task has a 0 id -\n"
>                  "         task number = %" PRIi32 "\n",
>                  remove_task);
>          exit( 1 );
> @@ -122,7 +122,8 @@ void test2()
>        removed_ids[task++] = task_id[remove_task];
> -      printf(" TEST2 : block %" PRIi32 " remove, signal task %08" PRIxrtems_id ", ", block, task_id[remove_task]);
> +      printf(" TEST2 : block %" PRIi32 " remove, signal task %08"
> +               PRIxrtems_id ", ", block, task_id[remove_task]);
>        rtems_event_send(task_id[remove_task], 1);
>        task_id[remove_task] = 0;
> @@ -144,7 +145,7 @@ void test2()
>      if (id_slot == MAX_TASKS)
>        printf( " FAIL2 : no free task id slot.\n");
>        exit( 1 );
> @@ -164,11 +165,12 @@ void test2()
>        printf( " FAIL2 : re-creating a task -\n"
>                id_slot);
>        exit( 1 );
> -    printf("number = %3" PRIi32 ", id = %08" PRIxrtems_id ", starting, ", task_count, task_id[id_slot]);
> +    printf("number = %3" PRIi32 ", id = %08" PRIxrtems_id ", starting, ",
> +           task_count, task_id[id_slot]);
>      result = rtems_task_start(task_id[id_slot],
>                                test_task,
> @@ -179,7 +181,7 @@ void test2()
>        printf( " FAIL : re-starting a task -\n"
>                id_slot);
>        exit( 1 );
> @@ -190,7 +192,8 @@ void test2()
>      NEXT_TASK_NAME(c1, c2, c3, c4);
> -     *  Search the removed ids to see if it existed, clear the removed id when found
> +     *  Search the removed ids to see if it existed, clear the removed id
> +     *  when found
>      for (remove_task = 0; remove_task < (TASK_ALLOCATION_SIZE * 2); remove_task++)
> @@ -212,9 +215,10 @@ void test2()
>        for (allocated_id = 0; allocated_id < MAX_TASKS; allocated_id++)
>          if ((task_id[id_slot] == task_id[allocated_id]) && (id_slot != allocated_id))
> -          printf( " FAIL2 : the new id is the same as an id already allocated -\n"
> -                  "         task id = %08" PRIxrtems_id "\n",
> -                  task_id[id_slot]);
> +          printf(
> +            " FAIL2 : the new id is the same as an id already allocated -\n"
> +            "         task id = %08" PRIxrtems_id "\n",
> +            task_id[id_slot]);
>            exit( 1 );
> @@ -227,7 +231,7 @@ void test2()
>      task_count++;
>    printf( " TEST2 : completed\n" );
> diff --git a/testsuites/samples/unlimited/test3.c b/testsuites/samples/unlimited/test3.c
> index 247d175..6330f3c 100644
> --- a/testsuites/samples/unlimited/test3.c
> +++ b/testsuites/samples/unlimited/test3.c
> @@ -144,7 +144,7 @@ void test3()
> -  destory_all_tasks("TEST3");
> +  destroy_all_tasks("TEST3");
>    printf( " TEST3 : completed\n" );
> 1.9.3
> devel mailing list
> devel at rtems.org
