[PATCH 49/52] samples/base_sp: Fix printf() warning
Wed Oct 8 20:28:56 UTC 2014
Done.
On 10/8/2014 3:20 PM, Gedare Bloom wrote:
> On Wed, Oct 8, 2014 at 3:16 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>>  testsuites/samples/base_sp/apptask.c | 3 ++-
>>  1 file changed, 2 insertions(+), 1 deletion(-)
>> diff --git a/testsuites/samples/base_sp/apptask.c b/testsuites/samples/base_sp/apptask.c
>> index c39d64f..aa1da14 100644
>> --- a/testsuites/samples/base_sp/apptask.c
>> +++ b/testsuites/samples/base_sp/apptask.c
>> @@ -32,13 +32,14 @@ rtems_task Application_task(
>>    rtems_id          tid;
>>    rtems_status_code status;
>> +  unsigned int      a = (unsigned int) argument;
>>    status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &tid );
>>    directive_failed( status, "ident" );
>>    printf(
>>      "Application task was invoked with argument (%" PRIdrtems_task_argument ") "
> %u ?
>> -    "and has id of 0x%" PRIxrtems_id "\n", argument, tid
>> +    "and has id of 0x%" PRIxrtems_id "\n", a, tid
>>    TEST_END();
>> 1.9.3
>> devel mailing list
>> devel at rtems.org
