[PATCH 49/52] samples/base_sp: Fix printf() warning
Wed Oct 8 19:16:40 UTC 2014
 testsuites/samples/base_sp/apptask.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/testsuites/samples/base_sp/apptask.c b/testsuites/samples/base_sp/apptask.c
index c39d64f..aa1da14 100644
--- a/testsuites/samples/base_sp/apptask.c
+++ b/testsuites/samples/base_sp/apptask.c
@@ -32,13 +32,14 @@ rtems_task Application_task(
   rtems_id          tid;
   rtems_status_code status;
+  unsigned int      a = (unsigned int) argument;
   status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &tid );
   directive_failed( status, "ident" );
   printf(
     "Application task was invoked with argument (%" PRIdrtems_task_argument ") "
-    "and has id of 0x%" PRIxrtems_id "\n", argument, tid
+    "and has id of 0x%" PRIxrtems_id "\n", a, tid
   TEST_END();
1.9.3
