[PATCH 2/3 v2] LEON3 SMP: support static interrupt affinity
Thu Oct 9 09:13:11 UTC 2014
On 08/10/14 15:49, Daniel Hellstrom wrote:
> +#ifdef RTEMS_SMP
> +/* Weak table used to implement static interrupt CPU affinity in a SMP
> + * configuration. The array index is the interrupt to be looked up, and
> + * the array[INTERRUPT] content is the CPU number relative to boot CPU
> + * index that will be servicing the interrupts from the IRQ source. The
> + * default is to let the first CPU (the boot cpu) to handle all
> + * interrupts (all zeros).
> +extern unsigned char sparc_irq_to_cpu[32];
> +#endif
I am not so fond of adding BSP specific solutions to deal with the interrupt
processor affinity.
I would rather enhance the interrupt manager extension API:
http://www.rtems.org/wiki/index.php?title=SMP#Interrupt_Support_2
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__rtems__interrupt__extension.html
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
