[PATCH 1/2] libcpu/or1k: Fix warnings.
Hesham ALMatary
heshamelmatary at gmail.com
Fri Oct 10 16:44:49 UTC 2014
c/src/lib/libcpu/or1k/shared/cache/cache.c | 16 ++++++++--------
c/src/lib/libcpu/or1k/shared/cache/cache_.h | 1 +
2 files changed, 9 insertions(+), 8 deletions(-)
diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache.c b/c/src/lib/libcpu/or1k/shared/cache/cache.c
index 039be36..d38b572 100644
--- a/c/src/lib/libcpu/or1k/shared/cache/cache.c
+++ b/c/src/lib/libcpu/or1k/shared/cache/cache.c
@@ -71,7 +71,7 @@ static inline void _CPU_OR1K_Cache_data_block_prefetch(const void *d_addr)
_ISR_Disable (level);
- _OR1K_mtspr(CPU_OR1K_SPR_DCBPR, d_addr);
+ _OR1K_mtspr(CPU_OR1K_SPR_DCBPR, (uint32_t) d_addr);
_ISR_Enable(level);
@@ -81,7 +81,7 @@ static inline void _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
ISR_Level level;
- _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, d_addr);
+ _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, (uint32_t) d_addr);
_ISR_Enable(level);
@@ -91,7 +91,7 @@ static inline void _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
ISR_Level level;
- _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, d_addr);
+ _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, (uint32_t) d_addr);
_ISR_Enable(level);
@@ -101,7 +101,7 @@ static inline void _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
ISR_Level level;
- _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, d_addr);
+ _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, (uint32_t) d_addr);
_ISR_Enable(level);
@@ -111,7 +111,7 @@ static inline void _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
ISR_Level level;
- _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, d_addr);
+ _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, (uint32_t) d_addr);
_ISR_Enable(level);
@@ -122,7 +122,7 @@ static inline void _CPU_OR1K_Cache_instruction_block_prefetch
ISR_Level level;
- _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, d_addr);
+ _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, (uint32_t) d_addr);
_ISR_Enable(level);
@@ -133,7 +133,7 @@ static inline void _CPU_OR1K_Cache_instruction_block_invalidate
ISR_Level level;
- _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, d_addr);
+ _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, (uint32_t) d_addr);
_ISR_Enable(level);
@@ -144,7 +144,7 @@ static inline void _CPU_OR1K_Cache_instruction_block_lock
ISR_Level level;
- _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, d_addr);
+ _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, (uint32_t) d_addr);
_ISR_Enable(level);
diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache_.h b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
index 5f08410..0ea939f 100644
--- a/c/src/lib/libcpu/or1k/shared/cache/cache_.h
+++ b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
@@ -6,6 +6,7 @@
#define __OR1K_CACHE_H
#include <bsp/cache_.h>
+#include <libcpu/cache.h>
#endif
/* end of include file */
1.9.3
